Old 05-09-2018, 08:09 PM   #18873
Ashikabi
Ashikabi's Avatar
Originally Posted by notout86 View Post
I asked Whiteline by email
"We have a 2013 Toyota GTS86 auto with torsen diff. I experience driveline lash sometimes and would like to reduce it without introducing harshness or increasing noise (or at least only slightly.) I do not compete. I am thinking of replacing just one pair of diff bushes rather than all four which seems simple but would like your advice.
ONLY WITH YOUR PERMISSION I will be posting your reply on forums.
Here's their great reply
"If you are looking for a compromise between reduced driveline lash without too much added stiffness, our differential bushing inserts are a good choice. Part number KDT925 includes polyurethane inserts that fill the voiding of the factory rubber. The kit contains inserts to stiffen the outrigger bushings and the cradle mounted differential bushings. An added benefit to this kit is that it is a somewhat easier install and is a more affordable alternative to complete polyurethane replacements. If you would rather use full polyurethane replacement bushings, the outrigger bushings (KDT923) would most likely be the first to deteriorate and would therefore be the best to immediately replace. They are also the easier to install of the two bushings. If you are looking to do any work on the car’s differential bushings, we recommend replacing the cradle bushings (KDT924) as well if the car is already going to be taken apart and worked on. Feel free to share this information and please reach out if you have any other questions!"
What does drive line "lash" feel like?
Old 05-09-2018, 08:47 PM   #18874
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I changed my oil today. I switched to Mobil 1. Tomorrow, clutch fluid change, I have some RBF600 left over, might as well.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
MJones_RB (05-11-2018)
Old 05-10-2018, 12:29 AM   #18875
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Installed a Seicane Android headunit yesterday; today I'm trying to get the door speakers up and running. No such luck yet...
Old 05-11-2018, 11:48 AM   #18876
arxm
Drives: 2013 FR-S, 2023 BRZ
Good for you man. But really I don't see why you can't put in a "bigger" battery. Hell, Braille or whoever night have a lighter battery with more hours on it. But it'll cost a couple hundred bucks. The cheapest option is probably to chain in a lan and garden battery but the "best" one imo is to just get a whole new one with more hours
I popped the hood and there seems to be a considerable amount of room around the battery so im gonna measure it up and find the largest capacity battery that will fit in there, I will post up what I find in here in case anybody else wants to do the same.
Im also going to try and put a wireless charging mat inside my center console so I have less wires everywhere
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 05-11-2018, 11:50 AM   #18877
Ashikabi
Ashikabi's Avatar
The likely problem you'll have is the battery tie downs won't allow for a larger size. Also the plastic tray. Might have to relocate it to the trunk
Old 05-11-2018, 03:19 PM   #18878
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Got a new part.
Nice, doing the smaller clutch slave cylinder mod. Let us know how you like it!
MJones_RB is offline   Reply With Quote
Old 05-11-2018, 03:36 PM   #18879
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
It's when you get off the gas and immediately back on it and you can feel the drivetrain rocking back and forth, jerking the car forward and back.
Old 05-11-2018, 04:48 PM   #18880
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Headlight blackout and halos!! So worth the effort. Put the winter tires back on though... Selling the summer wheel/tire combo to get something lighter.
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
Astroboy (05-12-2018), RallySport (05-12-2018), zeal86 (05-11-2018)
Old 05-12-2018, 08:34 PM   #18881
arxm
might just custom fab something, ill see when i get to that, still a few things on my list
Old 05-12-2018, 08:38 PM   #18882
Astroboy
Astroboy's Avatar
Drives: None
I am jealous of red 86 owners. I should have gotten red . It looks so sexy
Sent from my LG-H871 using Tapatalk
Astroboy is offline   Reply With Quote
Old 05-13-2018, 04:14 PM   #18883
DefMunkie
Drives: 2017 86
Added tint, installed drop in K&N, Perrin Intake tube, and OFT with Stage 1 4.03 installed this weekend
DefMunkie is offline   Reply With Quote
Old 05-13-2018, 09:20 PM   #18884
PacManTheRS1.0
PacManTheRS1.0's Avatar
Drives: 2015 Scion FR-S Release Series 1.0
Red brake calipers!
"I am not designed to come second or third. I am designed to win." - Ayrton Senna
PacManTheRS1.0 is offline   Reply With Quote
The Following 4 Users Say Thank You to PacManTheRS1.0 For This Useful Post:
Crashdummy (05-14-2018), MJones_RB (05-16-2018), stranger things (05-14-2018), TorontoNat (05-14-2018)
Old 05-13-2018, 09:55 PM   #18885
Looks nice!
Good looking pond in your front yard .....
PacManTheRS1.0 (05-13-2018)
Old 05-13-2018, 11:57 PM   #18886
mattyice
Drives: FRS RS1
Great pics! Love the RS1's. Nice house and garage BTW
mattyice is offline   Reply With Quote
