| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#16 | |
Drives: 2014 BRZ Limited
The TPMS sensors look like this:
![]() If you realize that long part is a valve stem, it should be pretty obvious how this is installed inside the rim. See that number on the right hand side? That's the address that tells the body control module how to talk to that sensor. The BCM only stores one set of sensor addresses at a time and doesn't store old ones if you replace your TPMS sensors. When you first get one of these cars new, there's one of these in each full sized rim/tire. If you install aftermarket rims, you have several options: 1. You can just ignore them, in which case you'll get a TMPS light on the dash. Thank the US federal government for that. 2. You can swap your original TPMS sensors to the new rims. This requires your tires to be removed temporarily from your old rims to retrieve them. Once the new rims rotate a few times, the car will recognize its old friends still programmed into the body control module. 3. You can get another set of TPMS sensors (new or used) and have them programmed to the car in place of the originals, leaving your original sensors in the original rims. Most tire shops can program in the new addresses when they install the tires, or you can do it yourself with something like an ATEQ Quickset tool. Techstream is also alleged to be able to do it, but I haven't used it myself. However, to do that, you or the installer needs those numbers on the sensors to be able to address them in your body control module. If you buy a set of rims and tires that already have the sensors inside them, but you don't have the numbers, the installer has to pull the tires off to get that number. The car can't just "detect" those numbers if they're not already in its memory. If you just install rims and sensors without addressing them, you'll get the federal government light on your dash. Thanks Obama. Quote:
Are you getting the original rims and tires with the car? If the original sensors are still in them, ask him if he has the numbers of those original sensors. If he does, they can be programmed in without having to take the tires off the rims. Some of us use something like that ATEQ Quickset tool I mentioned above to program the TPMS system ourselves. It will store four sets of TPMS sensors in it. When I put my rims on my car, I got a second set of sensors and stored both sets in the ATEQ so I can flash them back quickly if I ever need to swap back to the stock rims. If you're getting the original rims and tires and the seller used something like that to program them himself, he may have the addresses still stored in the tool. If you want your own ATEQ, they're about $120 new, but occasionally they pop up on Ebay for $50. Might be. None of it is really as complicated as it seems. It's just a mystery to most people because most people don't mount their own tires and never even see the sensors. |
| The Following 4 Users Say Thank You to extrashaky For This Useful Post: |
#17 | |
Drives: Scion FR-S
It's cost me about 130.00 to transfer the sensors from my stocks to aftermarket. Not sure the average. But yes the car can only save one set of (4wheels) Sent from my iPhone using Tapatalk |
#18 | |
Drives: 2017_86 2016_frs 2007_335i
#19 | |
The valve core inside the stem is most likely replaceable. Those are usually just standard generic Schrader valves that screw right in and out. Auto parts stores and even WalMart carry little kits with replacement cores and a little tool to remove and install them. Be sure to let the air out completely before unscrewing a valve core and wear eye protection or at least turn your face away. Unscrewing one with pressure remaining behind it is a good way to shoot your eye out. |
#20 | |
my 2017 86 has those tpms , i finally decided just use the oem tpms which is one piece type. so i need use the oem valve stem tooo. let me know if anyone has find a sensor fit those valve stem come with rpf1
#21 |
Drives: 2014 brz
| TPMS Sensors - What to Buy? | Stang70Fastback | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 01-31-2016 01:01 PM |
| OEM TPMS Sensors | airwak | Wheels and Tires | 3 | 08-16-2015 04:14 PM |
| FS: oem tpms sensors (four) | redlined600 | Wheels and Tires | 0 | 07-03-2015 09:17 PM |
| TPMS Sensors.. | Dave-ROR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 04-08-2014 01:22 PM |
| Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? | Ahz | Issues | Warranty | Recalls / TSB | 9 | 11-06-2012 08:25 AM |
