View Poll Results: What to do?
Just bed in new pads. 1 12.50%
Resurface rotors. 2 25.00%
Replace rotors. 5 62.50%
Other. 0 0%
Voters: 8. You may not vote on this poll
Old 05-09-2018, 02:44 AM   #1
mkodama
86 Challenge
Drives: 2017 BRZ
To resurface rotors or not?
I overheated my pads at a trackday, have a pulsating pedal that hasn’t gone away with street driving or trying to bed the brakes again, and I have new track pads to go on. Brake system is currently stock performance package brembos and replacement rotors are $400 each so hesitant to just replace the rotors.
Do I just put on the new pads and bed them? Do I spend the time and money to have the rotors resurfaced? Other ideas?
mkodama is offline   Reply With Quote
Old 05-09-2018, 03:29 AM   #2
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
new rotors
google 'cementite'. it doesn't go away with turning the rotors.
thomasmryan is offline   Reply With Quote
The Following User Says Thank You to thomasmryan For This Useful Post:
Tristor (05-09-2018)
Old 05-09-2018, 08:08 AM   #3
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
If it is confirmed whether these PP Brembos are standard STi sized, something like this would be a good replacement.
https://www.oakos.com/CEN-125-47019.htm
or
https://www.oakos.com/CEN-121-47019.htm
Centric blanks in 5x100 STi dimensions for ~100 or 180 a set. They also carry rears.
Edit: this thread indicates that standard STi rotors should be compatible
http://www.ft86club.com/forums/showthread.php?t=122138
yelsew is offline   Reply With Quote
Old 05-09-2018, 10:40 AM   #4
86league
Drives: '13 BRZ Limited
I had pulsating pedal with my rotors after a track day (stock brakes) - had them turned and now have 7 track days (one was very wet however - so count it as 6) on them since with no issues...
Before I had them turned, I thought maybe it was just uneven transfer. I tried re-bedding them : no help. Bought garnet sand paper and spent a bunch of time sanding the rotors to remove any deposits : no help. Had them turned : pulsation was gone.
This was stock brakes on my '13 and Carbotech XP10 pads. Before this experience I pretty much thought pulsation was always uneven transfer and very unlikely a warped rotor. Now - as mentioned above - might have been cementite but very superficial, or slight warping... YMMV.
86league is offline   Reply With Quote
Old 05-09-2018, 11:09 AM   #5
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
BBK Time!!!
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI
Open Flash Unequal Length Header
Invidia N1 CatBack
InstaGram: 49RJ
EffaressNOOB is offline   Reply With Quote
Old 05-09-2018, 11:54 AM   #6
wbradley
Sarcastic SOB
wbradley's Avatar
It's a lot less expensive to try machining first.
Recommendations on where to check/resurface rotors? stockysnail Northwest 4 05-18-2017 02:57 PM
Looking for OEM rotors RickyRacer Canada Classifieds 2 09-14-2016 05:25 PM
Resurface tail lights? Rifle Cosmetic Modification (Interior/Exterior/Lighting) 7 09-24-2015 03:10 AM
Lancer Evolution XI (Resurface) Whitigir Other Vehicles & General Automotive Discussions 9 03-14-2014 06:36 PM
FS: GTS rotors yomchi1989 Australia Classifieds 0 01-05-2013 12:33 AM
