Old 05-07-2018, 07:50 PM   #183
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
@tehShirt this doesn’t look too bad
Drambeenie is offline   Reply With Quote
Old 05-07-2018, 07:58 PM   #184
Brink
Drives: 2017 BRZ
Originally Posted by BirdTRD View Post
Finally took the plunge. Lots of work but worth it. Thanks @BRZen for the inspiration!
Another mesh grille joins the club!
Brink is offline   Reply With Quote
Old 05-09-2018, 04:41 AM   #185
BRZen
Looks great against the silver!
BRZen is offline   Reply With Quote
Old 05-09-2018, 08:25 AM   #186
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
I agree, they did a good job. Would be interesting to see someone keep the mustache, but replace the horizontal bars with the honeycomb.
tehShirt is offline   Reply With Quote
Old 05-09-2018, 08:46 AM   #187
Drambeenie
Drambeenie's Avatar
For sure. I'd like to keep the foam crash protection.
Old 05-11-2018, 05:24 PM   #188
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Here's some more angles of the grill after I installed the plate re-locator. Something to keep in mind as you're lining up the grill to minimize the amount you have to cut away to install the post. I got lucky, only 1 horizontal needed to be removed.
BirdTRD is offline   Reply With Quote
Old 05-13-2018, 08:58 PM   #189
brehio
brehio's Avatar
Drives: 2014 Subaru BRZ
Anyone willing to post a link to where they bought the mesh? Looks so so much better than stock imo. Seems like a cheap mod that really changes the look of the car. Both you guys said huge time consumer, but can it be done in one day? Also, what did you guys use to glue it to the bumper and how is it holding up on the roads?
Thanks
Austin Brehio Racing
My build thread
brehio is offline   Reply With Quote
Old 05-14-2018, 12:56 AM   #190
Brink
Drives: 2017 BRZ
Thanks
I got this mesh (16x48 black version):
https://www.customcargrills.com/prod...rod=Brick-Mesh
Looks like the other guys doing this got mesh in a different pattern, they're more of a honeycomb shape. Since mine is a '17 BRZ the front bumper is a bit different so there was no glue involved - I can't speak to what glue to use or how long that part of it takes. One thing to keep in mind though is you will most likely want to do something with the crash beam - paint, plasti-dip, something like that. It's ugly otherwise. Got my mesh grille done without doing anything to the crash beam at first and was happy with it for a bit before I got tired of looking at it and had the bumper taken off again to plasti-dip the crash beam. Here's a pic of a crash beam in stock form, before painting it. BirdTRD's post has a nice picture of the after, so you can see the mesh grille with a nice black crash beam like you'll probably want to go for.
Old 05-14-2018, 08:13 AM   #191
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Thanks
For the mesh I used https://www.ebay.com/itm/152828435566 the material itself is 1/4" thick. The "honeycomb" openings are 1-1/4" across and 1/2" high, which looks to be a bit larger than the one @BRZen used.
For the adhesive I used JB Kwik and you'll used most...if not all of the 10 oz size. https://www.amazon.com/J-B-Weld-8270...=jb+kwik+10+oz
I'll put some tips and lessons learned up in a bit.
Old 05-14-2018, 09:20 AM   #192
JoeC
Drives: Subaru BRZ Limited
why did did you plastidip the crash beam? isn't it just going to start peeling before too long?
Also, why are there all those tabs around the edge visible still?
JoeC is offline   Reply With Quote
Old 05-14-2018, 10:32 AM   #193
Brink
Drives: 2017 BRZ
Thought the plastidip would hold up better than paint against rock chips etc from road debris. It's just a thin coat so hopefully doesn't start to peel too quickly. The tabs are visible because that's actually what my mesh is attached to, it's not glued in like the others you've seen on here. The '17 bumper has the stock grille attached to those tabs and the grille just pops out so the mesh was basically just tied onto the tabs. Earlier model year BRZs wouldn't have had those tabs to begin with.
Old 05-14-2018, 10:46 AM   #194
JoeC
It's a paint that's marketed as easy to remove, I wouldn't expect too much.
I understand now. thanks for the clarification. I think I'd either paint the tabs black or trim them off entirely.
Old 05-14-2018, 12:16 PM   #195
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
this is interesting, i think i may have to do this to my brz now... My crash bar got replaced by a JDL bar and I do have a big fat intercooler.... so this may be a win win. lol
pgranberg11 is offline   Reply With Quote
Old 05-14-2018, 04:39 PM   #196
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Here are some tips for doing a good job.
Take your time cutting out the mustache and grill using a series of passes with the Dremel tool, first pass getting the bulk out of the way then subsequent passes to get the finished edge "perfect".
Use the right cutting bit...and a cut off wheel is not the right bit. (see pic below for correct bit)
Use 2 hands on the Dremel tool with the lower hand also braced against the material as it can and will walk on you. Practice on the scrapped mustache. I found that attacking the plastic at an angle (not 90 degrees) gives you more control. I also used several hand tools, (a rasp, file, sharp blade, sandpaper etc.) to get a clean, straight finished edge.
I used the actual bumper as my "mold" and used a heat gun and weights to get the mesh to form flush to the cut edge prior to gluing. Let the glue set up and cure with the weights still in place. JB Quik takes 6 minutes to set and 4-6 hours to cure so you have to work fast to apply it but let it fully cure before moving on.
Prep the inside surface of the bumper where the JB Quik will adhere. JB Quik doesn't "stick" well to smooth surfaces so besides cleaning the surface, gouge the crap out of it to give it some structure to grab onto. The honey combs on the mesh will serve as the structure on the grill half of things.
I initially glued the bottom edge of the mesh to the lower portion of the bumper cover but that interfered with black plastic "shelf" (for lack of a better word) that sits below the radiator/AC condenser and wouldn't let me install the lower bumper push pins as the holes didn't line up. I ended up cutting 20 mm off of the bottom of the mesh (as you see it in my pics) to allow that shelf piece (which is 20 mm thick) to slide under the mesh and allow the bottom pin holes to line up. I hope that makes sense.
swap brz front end with fr-s? koyv90 Scion FR-S / Toyota 86 GT86 General Forum 17 02-07-2012 03:23 AM
Subaru BRZ Front End...is...ugly? hybrid4g BRZ First-Gen (2012+) — General Topics 65 02-04-2012 11:33 AM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 02:08 PM
Comparing front end of the FR-S/FT-86 to BRZ DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 66 11-21-2011 05:26 PM
Buy this front bumper for G37 Coupe? WhatIs86For Other Vehicles & General Automotive Discussions 12 02-26-2011 02:24 AM
