Old 04-27-2018, 04:19 PM   #71
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by laextreme5 View Post
Any more info on the second ecu option?
It's being tested on a 2JZ car currently to work out the kinks, should know more very soon, just don't want to jump the gun.
Pure Automotive is offline   Reply With Quote
The Following 3 Users Say Thank You to Pure Automotive For This Useful Post:
Draco_PR23 (05-02-2018), laextreme5 (04-30-2018), mulekr1 (05-05-2018)
Old 05-04-2018, 01:24 PM   #72
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
Might do my swap locally and just wait for the ecu option
Edit; I have a spare ultra series’s manifold just like this that I paid nearly 650$ for and the reason I couldn’t use it on my other k20 project car was because it would’ve required me to remove power steering and AC. I had to purchase the smaller ultra street instead of the ultra race pictured here. Do you see that as a potential problem?
mulekr1 is offline   Reply With Quote
Old 05-09-2018, 08:12 AM   #73
Pure Automotive
Haven't gotten to addressing the AC issue, there is no power steering needed, so a custom belt setup will be needed
The Following User Says Thank You to Pure Automotive For This Useful Post:
skinnybehr (06-08-2018)
Old 05-09-2018, 09:25 AM   #74
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Originally Posted by Pure Automotive View Post
I spoke to another shop that did a one off K swap in a rocket bunny FRS, theirs was turbo and it still only weighed 2460 full interior! So imagine no turbo kit and no rb kit, I think with some lightweight wheels and brakes you're talking 2300ish, that is INSANE if it happens.
Is the weight savings really in the 100 pound range?
This reliability / power level for a gutted, stripped out track car without the need for HVAC, etc sounds mighty tempting when compared to the LS swap's weight gain over the front axles...even with the mountain of trq it brings.
How deep is the sump of the Kswap oil pan? Having less susceptibility to oil starvation in sustained corners on sticky tires is just icing on the cake if this works out
Joesurf79 is offline   Reply With Quote
The Following User Says Thank You to Joesurf79 For This Useful Post:
venturaII (05-17-2018)
Old 05-09-2018, 05:49 PM   #75
86Tony
Drives: 2015 AOZORA EDITION
If i already Have motec on my fa20 can i reuse it?
86Tony is offline   Reply With Quote
Old 05-09-2018, 09:09 PM   #76
gtengr
Drives: 2017 BRZ
The S2000 trans weighs roughly the same as the 86 trans, and the FA20 weighs ~390 lbs fully dressed. K24 with starter, alternator, and header weighs ~300 lbs. Swap the AC over and I get ~60-70 lbs difference.
gtengr is offline   Reply With Quote
Old 05-12-2018, 02:38 PM   #77
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Originally Posted by sam69 View Post
Love the idea of this so was wondering how one would comply with emissions etc .
Also which is the best model K24 engine to use if one was to do a swap as I know next to bugger all about Honda's
Idk about emissions but after a lot of researching on which to get, it looks like the K24A2 in the TSX.
https://honda-tech.com/forums/k-seri...etter-3145386/
The K24Z7 is the newest one but I didn't read too much into it, I'm guessing the K24A2 is also what Pure Automotive has as well since it has the Acura badge on it in the picture.
Alltezza is offline   Reply With Quote
Old 05-12-2018, 03:53 PM   #78
mulekr1
mulekr1's Avatar
I was personally gonna use a k20z1/k20a2 from the rsx wonder if it’ll be same shit wiring wise
Old 05-13-2018, 12:55 PM   #79
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Just so everyone knows Collins makes an adaptor to adapt the K24 to a CD-009 trans out of a 350z. The adaptor kit comes with a clutch as well. Would take a little bit of fabrication compared to the s2000 trans but is way stronger. For those guys that would want to go turbo. http://collinsadapters.com/index.php...ation-kit.html
FreshFRS is offline   Reply With Quote
The Following User Says Thank You to FreshFRS For This Useful Post:
DIY (05-14-2018)
Old 05-16-2018, 10:34 PM   #80
ballsdeep
ballsdeep's Avatar
Drives: Ocho-Seis
What kind of throttle body will be used? Does the S2000 transmission line up with the OEM FRS shifter location? OEM S2000 shifter can be used?
ballsdeep is offline   Reply With Quote
Old 05-17-2018, 04:19 PM   #81
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Like I posted earlier, HASport says a K24 with axles, manifolds, accessories and transmission weighs 413lbs. Subtract the transmission, axles and p/s pump weight from the listed K motor weight and you're looking at an easy 100 pound reduction up front of the 86 compared to the FA20. Maybe more depending on manifolds used, etc
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 05-17-2018, 05:35 PM   #82
gtengr
Drives: 2017 BRZ
You're entitled to your opinion. My research did not lead me to believe a K24 with intake, headers, AC, accessories, and swap mounts would easily weigh less than 280 lbs.
Old 05-17-2018, 09:01 PM   #83
venturaII
venturaII's Avatar
Vorshlag states the FA20 and transmission weighs 480lbs. HASport says a fully dressed engine and transmission with axles is 413, which means we start off with a difference of 67 pounds. Now subtract the weight of the Honda's halfshaft assemblies, hydraulic power steering pump, and the difference between the OEM cast iron exhaust manifold and tubular header (no getting around that in a swap like this), and you're likely close to the remaining ~30 pounds. Also, I would hazard a guess that our 90 pound transmission weighs substantially less than a fwd transaxle for a similarly powered and weighted vehicle, given the absence of a ring gear/differential assembly. Unless I'm overlooking something, all that easily adds up to a conservative 100 pounds.
Old 05-18-2018, 09:19 AM   #84
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
What would easily settle this is if they weighed the car before the swap (unless it was stock then we know the weight) and then a post swap weight. Im suspecting a 70-80lb weight reduction. All off the front end. which would be wonderful.
laextreme5 is offline   Reply With Quote
FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports NvSnickers Wheels and Tires 2 04-04-2017 10:30 PM
Obnoxious "Blank" banner ad breaking quick reply Clipdat Site Announcements / Questions / Issues 16 03-09-2017 11:44 AM
Stock pistons "rate ore hate" ? Fricke Forced Induction 35 02-25-2016 10:59 AM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
My Adventures Aboard "Our Girl" Wes B. Other Vehicles & General Automotive Discussions 3 02-04-2013 11:44 PM
