#71 |
#72 |
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#73 | |
#74 | |
Drives: 2013 Scion FR-S Series 10
I think we also need to look at how the weight over the front axle, tire size, and suspension geometry affects forces going to and from the road and back through your body. Has anyone ever replaced the rack in these cars? Gone full manual steer without any electric or mechanic buffer? When talking steering feel, what exactly do we mean? I hear this a lot and I've never quite understood. I get loads of vibration and impact harshness through the rim. Going over uneven tarmac and elevation changes seems to affect the force of inputs required to turn the wheel. If I'm going around a bend a high speeds and have a lot of compression on the suspension on one side the steering will fight back a little. Going over wet roads or roads with dirt or sand from construction leaves the wheel feeling completely numb. Where I will contend it falls short, and seems to be an issue for a lot of electric assist racks, is that you can "outrun" the system if you crank the wheel too fast left to right. Then when the car settles and you make slower inputs, things seem heavier. Maybe the system is stepping in to assist when doing that? |
| The Following User Says Thank You to mazeroni For This Useful Post: | Tcoat (05-08-2018) |
#75 |
Not really sure what experience some here have had with non assisted steering but it was/is far from all fun and games.
Vehicles that had steering with great road "feedback" that I have drove. Hit a nickel laying on the road and break both your arms ![]() Can go straight for miles. Turns were a bitch. ![]() Is that a 1/2 inch wide crack in the road? OK lets just follow it and see where we go. ![]() You want to turn while sitting still? LOLOLOLOLOLOLOLOLOL suuuuuure.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#76 | |
Hmmm... Stiffening that coupling would decrease the servo response to the faster steering input.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (05-08-2018) |
#77 |
Drives: 2017 86GT
#78 |
I was sticking with alphabetical to see how close it came to getting all the letters. Just a couple more special editions and they could make it.
#79 | |
Or cause the wheel to jerk as it overcomes it. Or simply burn out or at least overheat the servo.
#80 |
I'll happily drive this... manual steering and doesn't seem to be a pain in the ass despite having no assist.
| The Following User Says Thank You to mazeroni For This Useful Post: | humfrz (05-08-2018) |
#81 |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Apart from all this talk of wires...
I find the feel and weight of the steering (made better with quality 225 wide rubber) one of the best things about my car. Braking, sliding, ‘powersliding’ etc are all easy to feel and modulate and I always know where the wheels are pointing and what they’re doing.
I like driving!
#82 |
*sigh* no
#83 | |
Famous Potatoes
Drives: '15 ultramarine
| The Following User Says Thank You to Sapphireho For This Useful Post: | 86 South Africa (05-09-2018) |
#84 |
Only happy when it rains.
Drives: series.blue
| handbrake wire and reverse wire location Australia gt86 | rsingh | Electronics | Audio | NAV | Infotainment | 0 | 01-16-2017 09:12 PM |
| Help me identify this wire! Extra wire around battery after clutch job | YouShallKnow | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 12-09-2014 02:04 PM |
| Swapping steering wheels with a new tC steering wheel. | jonathan9573 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-20-2013 11:45 PM |
| Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 04:52 PM |
| Reverse Wire Tap wire Location? | Norkoastal | Electronics | Audio | NAV | Infotainment | 2 | 10-19-2012 10:22 AM |
