Old 05-06-2018, 10:58 AM   #1
Stevenfu
Anyone tried Lexus CT200h f-sport wheels?
I knew these ones exist since my last car was a CT200h...
https://parts.lexus.com/p/Lexus__CT-...TR2076110.html
There is some disagreement on how much they weight, but I would think they are on par with OEM wheels, and since they are OEM I would assume they are reasonably strong.
On paper, they look they should fit FRS, also with less offset(+36), they should look more flush than OEM, although not all the way.
But a quick search did not find any result on this forum or Google, wondering has anyone tried them before?
Curious whether they would fit without any issue, and particularly, how they would look on a Raven FRS.
Stevenfu is offline   Reply With Quote
Old 05-06-2018, 11:15 AM   #2
Stevenfu
Quick PS looks good to me.
Old 05-07-2018, 11:17 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If they are truly a Toyota/Lexus product, the center bore of the wheels will be 54.1mm. You'll need to have the wheels machined out by at least 2mm to fit the FRS/BRZ.
Old 05-07-2018, 11:41 AM   #4
Stevenfu
ah... I guess that's why nobody bothered, saw some CT200h/prius using FRS wheels but none the other way around, and now it makes sense.
Old 05-07-2018, 12:24 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Machining the inside of the wheel would be best.
But you could also run a spacer if you really wanted to just slap the lexus wheels on. 6mm-7mm is about the length of the hub flange. My 5mm spacer almost covers it.
I can't get this out of my head....
via Imgflip Meme Generator
I LIKE TIRES!
Old 05-07-2018, 12:44 PM   #6
Tokay444
Anti stance.
Tokay444's Avatar
Then you're lug-centric. No thanks.
# Lexus F-Sport Style Instrument Cluster Gauge Face (For 86, FRS, BRZ) # JW89225 Interior Parts (Incl. Lighting) 7 09-12-2016 03:44 PM
Lexus F-Sport Meet ichitaka05 CANADA 4 06-24-2015 03:15 AM
Lexus CT200h F-sport vh_supra26 Other Vehicles & General Automotive Discussions 41 08-08-2013 11:51 AM
Lexus F SPORT Meet in Las Vegas Flipside909 Other Vehicles & General Automotive Discussions 0 07-18-2012 01:50 PM
