Old 05-06-2018, 06:05 PM   #1
lorip713
Trunk won’t open
2013 FR-S. About 2 weeks ago, I bought some bushes for the yard. One tipped over on the drive home. I cleaned out a couple small pieces of mulch from the trunk latch. Now, I can’t open the trunk. When you press the trunk release on the dash or use the remote, you can hear it click like it’s going to open. I have been trying to pull it open as hard as I can but it won’t budge. Is there a way to pop it open without going to an auto body shop or the dealer? Thanks.
lorip713 is offline   Reply With Quote
Old 05-06-2018, 06:07 PM   #2
Use the physical key to unlock it. On the drivers side rear you will find a button. Push that and all should be good again.
humfrz (05-06-2018), Leonardo (05-06-2018), Tristor (05-11-2018), winstonscifi (05-06-2018)
Old 05-06-2018, 06:09 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I unhooked the plug on the back of that button.
Valet my car... Ha, that will never happen!
I LIKE TIRES!
Old 05-06-2018, 06:16 PM   #4
YIKES ....... that was FAST .....
Old 05-06-2018, 06:36 PM   #5
But, some places, they will not let you park your own car ....... well, maybe that isn't so ...... in Oregon ......
Leonardo (05-07-2018)
Old 05-06-2018, 07:18 PM   #6
lorip713
Thanks for the replies but I should’ve mentioned in my original post that I did try to open it with the key and it won’t open.
Old 05-06-2018, 07:40 PM   #7
hmmm.......Bubba suggests you spray the key (or inside the lock) with WD-40 or silicone spray and run the key in and out of the lock a few times (maybe the tumblers are stuck). Also, push the trunk lid up and down when you're trying to unlock it.
Come back.
Old 05-06-2018, 07:41 PM   #8
Brink
Drives: 2017 BRZ
Yeah you said it clicks when you push the trunk release, as I recall it doesn't actually click if the security button has been engaged. Sounds like there's probably something stuck in the trunk latch preventing it from opening all the way. Have you tried having someone else push the trunk release and immediately pulling the trunk open yourself? I think the release just disengages the latch briefly so it may be a 2 person job to force it open.
Brink is offline   Reply With Quote
The Following User Says Thank You to Brink For This Useful Post:
Old 05-06-2018, 08:06 PM   #9
OK push down firmly on the lid as you unlock it.
Old 05-06-2018, 08:37 PM   #10
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Not to take issue w/ Humfrz, but do NOT use WD40 on your locks, unless you want to have to use it constantly from now until you bury your car. WD40 is a "works now for lubrication" product, but makes things way worse in the long run. It's a great cleaner, and it's also good for creating a barrier against water, but it's a terrible long-term lubricant.. it gums up, attracts dirt, and makes things worse. For locks, use graphite.
If your back seat is not firmly latched (and mine usually isn't), try yanking the back seat down, then crawling into the trunk and using the emergency white/yellow-ish manual release tab right near the latch. If/when you do eventually get your trunk open, don't latch your back seat anymore.. just in case!
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following 7 Users Say Thank You to MuseChaser For This Useful Post:
Brink (05-06-2018), funwheeldrive (05-09-2018), humfrz (05-07-2018), Leonardo (05-07-2018), Spuds (05-07-2018), Tristor (05-11-2018), winstonscifi (05-06-2018)
Old 05-07-2018, 12:58 AM   #11
Originally Posted by MuseChaser View Post
Not to take issue w/ Humfrz, but do NOT use WD40 on your locks, unless you want to have to use it constantly from now until you bury your car. WD40 is a "works now for lubrication" product, but makes things way worse in the long run. It's a great cleaner, and it's also good for creating a barrier against water, but it's a terrible long-term lubricant.. it gums up, attracts dirt, and makes things worse. For locks, use graphite............
Well, now, MuseChaser ...... since it's a slow day, here in Puyallup, I did some research on the concept of using WD-40 in door locks.
It appears that about 50% of the internet posters say it's good ...... and 50% say don't use it in locks.
Hell, MuseChaser , I donno , I'm going back to Bubba and suggest he stick to 3in1 oil or coal oil ........
Old 05-07-2018, 09:59 AM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
He's right Humfz, fish oil is good for getting tar off your car, and keeping Polaris missiles from rusting. Do not put in locks.
humfrz (05-07-2018)
Old 05-07-2018, 12:06 PM   #13
OK, folks ...... I concede ........ no more WD-40 in locks.
I'll go back to the old fashioned way ....... just heat the key up with a cigarette lighter before inserting ......or, if you don't smoke ...... just spit on the key .......
Old 05-07-2018, 12:19 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
I LIKE TIRES!
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
Brink (05-07-2018), MJones_RB (05-07-2018), Tristor (05-11-2018)
Trunk won't open gmanvilla1@gmail.com Issues | Warranty | Recalls / TSB 14 10-22-2022 10:09 PM
Trunk won't pop open Reflex Issues | Warranty | Recalls / TSB 36 01-02-2021 03:16 PM
Trunk Won't Open with Either Key Fob or Dash Trunk Release Ehokana Issues | Warranty | Recalls / TSB 15 04-08-2017 03:22 PM
Trunk will not open BAE Issues | Warranty | Recalls / TSB 14 06-04-2013 04:21 PM
Trunk won't open Sparda29 Issues | Warranty | Recalls / TSB 13 01-11-2013 11:10 AM
