Old 05-05-2018, 11:43 PM   #18859
Brink
Drives: 2017 BRZ
Originally Posted by Aipex8 View Post
Did a little clutch pedal tuning with the MTEC clutch spring and some adjustment to get it flush with the brake pedal.
Also, added the Perrin trunk handle.
Two quick, inexpensive mods that make a huge difference! Clutch feels sooo much better now, and I can close my trunk without touching the paint/wing!
Can you actually close the trunk using just that handle, without touching the trunk lid or wing? Seems like you'd have to throw the trunk down pretty hard to accomplish that.
Brink is offline   Reply With Quote
Old 05-06-2018, 02:00 AM   #18860
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I always just close the truck with my hand on the license plate, never touch paint.
Old 05-06-2018, 02:35 AM   #18861
Aipex8
Drives: 2017 Toyota 86 860 Special Edition
You have to swing it with a little force, but not as hard as you'd think.
Aipex8 is offline   Reply With Quote
Old 05-06-2018, 02:59 PM   #18862
arxm
Drives: 2013 FR-S, 2023 BRZ
just curious if anybody has fit a larger battery in their car, I dont just mean like with more CCA but a battery with more amp hours, i think the stock battery is something like 40. I tried looking but most guys here get smaller batteries lol
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 05-06-2018, 03:58 PM   #18863
Ashikabi
Ashikabi's Avatar
I thought you drove it every day so it wasn't gonna be an issue lol. So long as it has the same dimensionss it'll work. Or use 2. Or use a charger
Old 05-06-2018, 06:09 PM   #18864
Maybe it's like closing the bolt on an M1 rifle, without a round being loaded.
Ya, gotta be quick and your timing just right ...... or you wind up with an "M1 thumb".
Ouch!
86Ryan (05-07-2018)
Old 05-07-2018, 12:37 AM   #18865
notout86
Drives: GTS 86 auto
Originally Posted by new2subaru View Post
Installed White differential inserts. It's amazing what some poly can do for feels. I'm very pleased with these and the rear subframe inserts.
Steering rack is next!
You may have put me onto something that has bothered since new. I have noticed what I thought was due to the tailshaft flexing winding up and unwinding.... a sort of errr errr errr in second gear on small acceleration around a sweeping corner. Maybe it is soft diff mountings. I'd appreciate thoughts people.
I am not into racing and would only tolerate a slight increase of harshness if that is inevitable.
Note that our car is auto with torsen diff.
GTS86 Auto (Australia)
Old 05-07-2018, 10:47 PM   #18866
arxm
I am now self employed so I dont have to drive as much lol, plus in the winter the car battery was already weakish in the cold, might just have to find excuses to drive more lol
Old 05-07-2018, 10:52 PM   #18867
Ashikabi
Ashikabi's Avatar
Good for you man. But really I don't see why you can't put in a "bigger" battery. Hell, Braille or whoever night have a lighter battery with more hours on it. But it'll cost a couple hundred bucks. The cheapest option is probably to chain in a lan and garden battery but the "best" one imo is to just get a whole new one with more hours
Old 05-07-2018, 11:32 PM   #18868
DefMunkie
Drives: 2017 86
Finally got my plates.
DefMunkie is offline   Reply With Quote
Old 05-08-2018, 08:34 PM   #18869
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Got a new part.
MJones_RB (05-11-2018)
Old 05-09-2018, 01:38 AM   #18870
mtran
mtran's Avatar
Finally got around to installing my front lip this past weekend
mtran is offline   Reply With Quote
The Following 4 Users Say Thank You to mtran For This Useful Post:
Bounxou (05-09-2018), HachiRokuX (05-09-2018), humfrz (05-09-2018), RallySport (05-16-2018)
Old 05-09-2018, 01:49 AM   #18871
hmmm....... looks good ........ what kind is it ..??
I'll bet that would look nice on my white FR-S ........ IF I could stay back from the parking stops ......
Old 05-09-2018, 08:01 PM   #18872
notout86
Drives: GTS 86 auto
I asked Whiteline by email
"We have a 2013 Toyota GTS86 auto with torsen diff. I experience driveline lash sometimes and would like to reduce it without introducing harshness or increasing noise (or at least only slightly.) I do not compete. I am thinking of replacing just one pair of diff bushes rather than all four which seems simple but would like your advice.
ONLY WITH YOUR PERMISSION I will be posting your reply on forums.
Here's their great reply
"If you are looking for a compromise between reduced driveline lash without too much added stiffness, our differential bushing inserts are a good choice. Part number KDT925 includes polyurethane inserts that fill the voiding of the factory rubber. The kit contains inserts to stiffen the outrigger bushings and the cradle mounted differential bushings. An added benefit to this kit is that it is a somewhat easier install and is a more affordable alternative to complete polyurethane replacements. If you would rather use full polyurethane replacement bushings, the outrigger bushings (KDT923) would most likely be the first to deteriorate and would therefore be the best to immediately replace. They are also the easier to install of the two bushings. If you are looking to do any work on the car’s differential bushings, we recommend replacing the cradle bushings (KDT924) as well if the car is already going to be taken apart and worked on. Feel free to share this information and please reach out if you have any other questions!"
The Following User Says Thank You to notout86 For This Useful Post:
trvth (05-15-2018)
