#519 | |
Drives: Q5 + BRZ + M796
CSG Mike posted this on 3-6-18:
http://www.ft86club.com/forums/showp...&postcount=454 I was reading this today: https://www.sema.org/files/attachmen...black-book.pdf Quote:
#520 | |
Drives: FRS, Supra, Colorado D, GLC63
There have been more delays, and thats all I can really say. |
#521 |
Oh, sad, but thanks for the update. You meant CSG Mike’s post from 3-6-18 was of a pic from Harrop’s IG from 2015? I guess I missed that. Maybe he was subtly saying that they have been to the lab before with setbacks. Kinda crazy that they were at the lab in 2015, and it is 2018 now with no CARB. Considering they passed Australia’s emissions, the CARB standards must really be a jump in difficulty. Hopefully it won’t be another three years.
#522 |
I am thinking of getting a Delicious Tune. I am going to run the 85mm pulley or 11-12psi, I think. In my research people are saying I need to upgrade my MAP sensor because DT uses the MAP to tune instead of the MAF, and the stock MAP sensor is apparently rated to 1 bar or 14 psi, but can't really manage that pressure. Is this true?
#523 | |
Drives: '17 BRZ PP, old Legacy SSs and SVXs
#524 | |
DT sells a 10 psi MAP sensor and a 4 bar MAP sensor. I got an email back from DT which says I'll need the 4 bar sensor to cover the 85mm pulley, so I will have to buy that too when I get my license and tune. |
#525 | |
Here is a copy of the items I bought from Neil: Harrop SC Tuner Kit Harrop Australia Supercharger Kit (no tuning)-FRS/BRZ *Delicious Tuning Harrop Tune Kit* -Delicious Tuning Edelbrock Tune -Delicious Tuning Flex Fuel Kit (OEM Fuel Lines) -Delicious Tuning Flex Fuel Mounting Bracket -Delicious Tuning Flex Fuel Badge -Delicious Tuning Injector Hard Connector set -Deatschwerks 700cc Injector -Deatschwerks DW300c Fuel Pump -EcuTeK ProECU Cable Kit -EcuTeK ProECU License -Quick Disconnect Fuel Line Tools Delicious MAP 11 PSI MAP Sensor |
#526 | |
#527 | |
The only real differences between the Edelbrock and Harrop kits (that I can see) is the pulley size (effects boost level), the choice and location of the MAP sensor (effects scaling), the surface area of the air filter, and a possible difference in intercooling efficiency (effects?). So, I'm guessing the initial base map only differs in MAP scaling. |
#528 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#529 |
Drives: '14 981CS, '99 NB1
The MAF scaling will be dramatically different.
#530 |
Drives: 2013 Black FR-S
16 psi with stg2 cams on E67
#531 |
#532 | |
Engines like flow. As long as the whole system is setup and tuned correctly, more flow will yield more power.
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 04:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
