go_a_way1
Old 05-03-2018, 03:56 AM   #4481
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
This thread is going cold...
How is everybody’s week going eh?
Almost Friday...
________
~refer to username~
idkwhatimdoing is offline   Reply With Quote
The Following User Says Thank You to idkwhatimdoing For This Useful Post:
weederr33 (05-03-2018)
Old 05-04-2018, 11:13 AM   #4482
max20s14
Drives: 14' Raven M/T - 02' is300
I want a JRSC... anyone regret this for their DD
max20s14 is offline   Reply With Quote
Old 05-04-2018, 11:38 AM   #4483
amcp1
Drives: frs
I've had the kit on my dd for the past 8k miles. No regrets and I enjoy the car everytime I'm behind the wheel.
amcp1 is offline   Reply With Quote
The Following User Says Thank You to amcp1 For This Useful Post:
Jackson Racing (05-17-2018)
Old 05-04-2018, 11:38 AM   #4484
CSG Mike
CSG Mike's Avatar
The regret is usually not doing it earlier.
Old 05-04-2018, 11:42 AM   #4485
milanojess
milanojess's Avatar
Drives: 2013 FRS
My only regret was that I couldn’t/didn’t do it sooner.
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
The Following User Says Thank You to milanojess For This Useful Post:
Old 05-04-2018, 12:13 PM   #4486
milanojess
milanojess's Avatar
Drives: 2013 FRS
Exactly!
Old 05-04-2018, 12:26 PM   #4487
idkwhatimdoing
smh ya’ll can’t even say good mornin to a real 1
________
~refer to username~
Old 05-07-2018, 03:07 PM   #4488
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
I just noticed that I have a nice little dent in my inlet pipe. I have seen others mention clearance issues between this pipe and the rotrex unit on this kit.
What are some possible solutions for this that others have tried and can I order a replacement for just that one dented pipe?
Anomie is offline   Reply With Quote
Old 05-07-2018, 03:46 PM   #4489
CSG Mike
CSG Mike's Avatar
Unclamp the hose clamp that holds that pipe to the final hose going into the throttle body. Pull the pipe out about 1/2 an inch. Re-clamp. Problem solved
Old 05-08-2018, 12:20 PM   #4490
stlgrym3
Is C30 a better choice for me than C38 if I have no intention to upgrade the pulleys? However, I do have intention to use my tomei EL header with custom tune with the JRSC. Is it true that C30 has more power down low than C38? I just don’t want to spend the same amount of money ($100 difference or so) for a less capable/ older version supercharger.
stlgrym3 is offline   Reply With Quote
Old 05-08-2018, 12:25 PM   #4491
idkwhatimdoing
Just get the C38. You won’t regret it.
________
~refer to username~
Old 05-08-2018, 12:30 PM   #4492
stlgrym3
________
~refer to username~
Yeah, that’s what I’m leaning, don’t care if C30 suits me perfectly fine now, but with the C38 it’ll be nice to know the potentials there if I need it.
Old 05-08-2018, 12:56 PM   #4493
idkwhatimdoing
You should probably think of it this way: two motors make the same power, but one motor has half the displacement and half the number of cylinders than the latter. Which one will be more reliable?
An eight cylinder cranking 400 pounds at the flywheel will, generally, be working a lot less than a four cylinder making the same figures, under the same aspiration.
The C38 has plenty of potential (most of the time the unit is under-spun) and I don’t think anyone on this forum has even hit the ceiling with one.
________
~refer to username~
Old 05-08-2018, 02:26 PM   #4494
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
They make the same power. The Dyno's are nearly identical. Just get the C38, so if for any reason, in the future you want to upgrade.
JDMChris is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
