Old 05-02-2018, 08:42 PM   #1
Willie Swoopes
Junior Pizza Joe
Willie Swoopes's Avatar
Drives: 2017 BRZ Limited Manual WRB
Bright Lights! 2017 LEDs
I like the way my MY2017 headlights are clear and bright.
But,
I keep getting people flashing their headlights at me as if I have my high beams on. Which I don't.
Anyone else having this issue?
Yes, I know, the punch line is "your wife has been flashing her headlights at me all night..."
Bill
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too.
Willie Swoopes is offline   Reply With Quote
Old 05-02-2018, 08:51 PM   #2
monkeybike
Drives: 86
Have you checked the angle and tried adjusting them?
monkeybike is offline   Reply With Quote
Old 05-02-2018, 09:07 PM   #3
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
But,
Bill
Yes, every time that I drive at night at least a few cars flash their brights at me as if I have my brights on. I think it’s mostly that they are used to seeing the dim Halogen bulbs in other cars and assume that we have our brights on because of the brilliant white light from the LEDs.
The 17 BRZs have auto leveling headlights... though I suppose you could still choose to manually adjust them under the hood. I’m not inclined to adjust my headlights to where I can’t see as well just because other drivers are getting their panties in a wad
NCtoBRZ is offline   Reply With Quote
The Following User Says Thank You to NCtoBRZ For This Useful Post:
spike021 (05-02-2018)
Old 05-02-2018, 10:15 PM   #4
monkeybike
Drives: 86
Never been flashed in a '17+ 86 with LEDs.
Old 05-02-2018, 11:25 PM   #5
NCtoBRZ
Kangaroos have no headlights to flash at you...
monkeybike (05-03-2018)
Old 05-03-2018, 12:32 AM   #6
monkeybike
Drives: 86
Old 05-03-2018, 01:18 AM   #7
RBman
Drives: 2017 BRZ Limited PP
Not every night, however, it does happen to me occasionally.
Sent from my SM-G950U using Tapatalk
RBman is offline   Reply With Quote
Old 05-03-2018, 01:36 AM   #8
mkodama
86 Challenge
Drives: 2017 BRZ
Happens on occasion. A lot of people just don't understand light very well.
mkodama is offline   Reply With Quote
Old 05-03-2018, 02:13 AM   #9
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Literally it happens to me every night on the interstate -- People pump their brake lights to let me know, to which I respond with a quick 2x flash of the high beams and then they seem to get it.
Even had a current-gen STI pump their brakes at me because of the LED headlights.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 05-03-2018, 02:30 AM   #10
ctmandu
ctmandu's Avatar
Drives: 2017 860
my 2017 has never had anyone flash me, maybe yours are off a bit and need to be checked for right height.
2017 Toyota 860
ctmandu is offline   Reply With Quote
Old 05-03-2018, 04:38 AM   #11
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Taxi's have done the same to me a few occasions and I'm just running the OEM HIDs... Though mine is MY2013...
(Note: Almost always during rainy days at night, I wonder if the shape of our headlight plastic cover + the refraction of the rain has anything to do with it... I also find that if your headlight plastic cover isn't clean, it refracts light all over the place.)
Thinking back now, I should have flashed them back lol
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 05-03-2018, 05:12 AM   #12
ShansBRZ
Drives: 2017 brz
Sounds like they just need to be adjusted down a little bit. General rule of thumb is a 2” drop at 25’ but in our cars I think a 1” drop would be good enough since it sits so low.
ShansBRZ is offline   Reply With Quote
Old 05-03-2018, 05:51 AM   #13
Willie Swoopes
Junior Pizza Joe
They don’t seem to be up high. There is a distinct cut off line that shines along the tree lines and houses. It appears to be below the other drivers windshield level generally, but we do have a lot of hills here in SE PA.
I just think they are really bright. Is that something that can be adjusted? I looked online and in the manual but didn’t see anything.
Maybe I should rub some mud across the lenses.
Bill
Old 05-03-2018, 09:22 AM   #14
reebis
reebis's Avatar
Drives: 2020 STI Limited
I've been flashed a few times in mine as well, but not enough for me to crawl under the hood and try to adjust the headlights. It seems to be a somewhat common thing with the 17+ BRZs.
reebis is offline   Reply With Quote
Super bright leds fog light kit Gunman Cosmetic Modification (Interior/Exterior/Lighting) 10 05-24-2018 11:48 AM
FS: Helix Clear Sides with Bright White LEDs Asphalt~86 Exterior Parts (Aero, Lighting, Etc.) 3 12-04-2013 10:08 PM
