Old 05-01-2018, 11:08 AM   #1
mkodama
86 Challenge
Drives: 2017 BRZ
First things that fail tracking a performance package BRZ
The brake pads and CENTERCAPS.
The pads overheat and give a warped rotor feeling bad enough to end a track day; a little surprising on stock Michelin Primacy HP tires. The real surprise is the front center caps fell out but not the rears; my theory is the front brakes make enough heat to relax the centercap retaining tabs.
This was track day #6 in the BRZ at Laguna Seca and the problems only started showing up when my instructor had me braking harder.
Time to look into new pads!
mkodama is offline   Reply With Quote
The Following User Says Thank You to mkodama For This Useful Post:
Tristor (05-01-2018)
Old 05-01-2018, 11:10 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I always remove the center caps anyway, because weight reduction!
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 4 Users Say Thank You to 8RZ For This Useful Post:
JoeC (05-01-2018), mkodama (05-02-2018), nikitopo (07-28-2018), Tristor (05-01-2018)
Old 05-01-2018, 12:25 PM   #3
CSG Mike
CSG Mike's Avatar
Center caps are always supposed to be removed for track use.
And yes, OEM brake pads are always insufficient.
I've posted thousands of times, that with even the most basic instruction, you will not have enough brake pad, Performance Package Brembos or not.
Street pads belong on the street. Track pads belong on the track.
PM me and lets get you a proper set of brake pads.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
mixxxx (05-01-2018), mkodama (05-02-2018), strat61caster (05-01-2018), Tristor (05-01-2018), Turbowned (07-27-2018)
Old 05-01-2018, 12:47 PM   #4
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
You're rocking stock pads after six track days?!
I'm amazed that thing slows down at all at this point. Good to know though. I'll remove my caps next month.
mistople is offline   Reply With Quote
The Following 3 Users Say Thank You to mistople For This Useful Post:
CSG Mike (05-01-2018), mkodama (05-02-2018), strat61caster (05-01-2018)
Old 05-01-2018, 07:24 PM   #5
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Losing center caps is not specific to the brz. I lost both front caps on my previous car (rsx).
The front wheels were too hot to touch. I came to the same conclusion: The plastic get so hot that the tabs gets soft.
nico_rsx is offline   Reply With Quote
The Following User Says Thank You to nico_rsx For This Useful Post:
Old 05-02-2018, 01:56 AM   #6
mkodama
86 Challenge
Drives: 2017 BRZ
Will do!
Performance package brakes aren’t full on track brakes, but they are pretty damn sweet. 6 track days, 7800 miles, and pads still have >50% material remaining. Same goes for the Michelin Primacy HPs, lol.
Old 05-02-2018, 09:41 AM   #7
Lex_K
Drives: 987S, e46, mkv, frs
Some clubs make you remove the center caps. It is not because of the heat, the wheels actually deform enough due to forces on them during track days and make the center caps pop out.
Lex_K is offline   Reply With Quote
The Following User Says Thank You to Lex_K For This Useful Post:
Old 05-02-2018, 09:42 AM   #8
8RZ
The Gunshine State
8RZ's Avatar
Wouldn't you say the heat contributes to the deformation? Also could depend on alloy of the wheel.
Current DD: M235i
Old 05-02-2018, 09:53 AM   #9
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
The wheel itself has enough thermal mass and surface area for cooling that it does not heat up much. Your plastic center cap itself is more likely to heat up than the ~20lb aluminum wheel.
Just think about how tough welding aluminum is, getting heat to stay in the metal is a pain thanks to its ridiculously high rate of heat transfer (silver and gold are about the only materials better than aluminum at moving heat energy).
I have partially melted center caps at the track, the thin plastic doesn't hold up to the heat well.
14stu is offline   Reply With Quote
Old 05-02-2018, 09:54 AM   #10
8RZ
The Gunshine State
8RZ's Avatar
Makes sense, aluminum cools rather quickly as well.
Current DD: M235i
Old 05-02-2018, 11:27 AM   #11
mistople
mistople's Avatar
I have those brakes. I smeared the pads after one day. More power to you!
Old 05-02-2018, 12:28 PM   #12
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
I have a performance package BRZ I just took out for its first track day yesterday at Sonoma. Winmax W6 pads worked fantastic, easily out-braking the stock tires. I didn't have time to flush the brake lines so I was using stock fluid and I didn't get much pedal mush at all after 7 sessions, so the brake kit is managing heat pretty well. Also had the Jackson DR/OC and temps maxed at 230 F which I was very happy with.
I also didn't remove my caps and didn't even notice if they were still on, I'll have to check LOL.
Horrid_Funk is offline   Reply With Quote
The Following User Says Thank You to Horrid_Funk For This Useful Post:
CSG Mike (05-02-2018)
Old 05-02-2018, 01:27 PM   #13
CSG Mike
CSG Mike's Avatar
You might be surprised at how hot the wheels get.
Carefully put your hand close to a wheel next time you come off track!
Leonardo (05-04-2018), mixxxx (05-02-2018)
Old 05-02-2018, 02:17 PM   #14
14stu
14stu's Avatar
I've nearly burned my hand trying to check tire pressures immediately after coming off track, so I'm painfully aware of how hot rotors get. But the wheels themselves shouldn't heat up too much (not enough to thermally expand enough to loosen a center cap.).
The thermal camera videos of brake cooling tests show the rotor behind the wheels glowing hot and the wheels in front dark and cool but the scale could be too high to read the wheel temps.
I'll have to take some temperature readings next time, I'm not nearly as sure the wheels don't get that hot anymore. I know they could very quickly because I've changed wheels in between sessions and while the tires were warm the wheels weren't.
Sent from my SM-G935V using Tapatalk
2017 BRZ Performance Package DD Build mjanmohammad Member's Car Journals 230 11-01-2023 12:31 PM
Looking for Brz OEM 17 wheel for performance package khcho19 Want-To-Buy Requests 1 04-27-2018 11:09 AM
WTB: BRZ Performance Package wheels funwheeldrive Want-To-Buy Requests 2 01-14-2018 02:29 PM
Performance Package 86? masahiro Scion FR-S / Toyota 86 GT86 General Forum 10 11-01-2017 05:29 PM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 10:04 PM
