Old 04-27-2018, 12:14 PM   #29
I was thinking the same
LOL. Do you guys surf everyday? Do you talk like Spicoli? Have you had extensive plastic surgery?
8RZ (04-27-2018)
Old 04-27-2018, 12:20 PM   #30
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Hockey is the one with the long poles and the hard flat thing right?
I did a dance of joy when Toronto lost the other day because I was sick of listening to nothing but them at work or on the radio.
Here in San Jose there are many people who claim to be hockey fans. You ask them to name other teams besides the Sharks and they cant. You ask them how the playoffs are structured and they can't tell you. you ask who won the cup last year and they can't tell you. They sit at Sharks games sipping drinks and chatting with friends until a fight breaks out. It's just a status symbol to be able to say "I go to Sharks games. It's hillarious.
Tcoat (04-27-2018)
Old 04-27-2018, 12:20 PM   #31
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Like ya.
Tcoat (04-27-2018)
Old 04-27-2018, 12:24 PM   #32
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Everyday bruh
Old 04-27-2018, 12:24 PM   #33
Like ya.
finch1750 (04-27-2018), Sapphireho (04-27-2018)
Old 04-27-2018, 06:35 PM   #34
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
While we're on the topic, was there a time frame for the "early 2013" models that had these issues vs others? I'm a 2013, but I'm under the assumption mine was towards the end of that production run as I have the newer styled touch screen head unit. I'm pushing towards 50k with nothing but an emission issue and a leaky drain plug that was my fault.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 04-27-2018, 07:30 PM   #35
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
I'm guessing the previous owner beat the shit out of the car, then sold it off with a ticking time bomb. Perhaps even knowingly.
You can't blame Toyota/Subaru for a failing engine that has close to 100k on it already.
If the car was new off the lot yeah sure maybe, but it wasn't. You bought the cheapest BRZ you could find. What did you expect?
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 04-27-2018, 08:32 PM   #36
You can GE va good idea of the production range from looking at the VINs that are covered in the early TSBs.
VoltsFRS2013 (04-27-2018)
Old 04-27-2018, 08:41 PM   #37
VoltsFRS2013
In the video that the OP made, the first TSB about the "sowing machine" effect I'm definitely a victim of, but I don't personally think its that huge of a deal.
Old 04-27-2018, 08:47 PM   #38
I think you may be better off to go and read the TSBs yourself. Totally disregard everything from that video since the fact can be very hard to separate from the fiction. Much of what he says will just feed the paranoia of people.
Old 04-27-2018, 09:15 PM   #39
VoltsFRS2013
Oh for sure, i thought the little rattly knocker noise from that TSB was actually normal. When the OP posted that his car was at 90 some thousand not first owner it was kind of a meme from the first place, but that was the only thing said that made me a bit concerned
Old 04-27-2018, 09:31 PM   #40
ermax
ermax's Avatar
Originally Posted by ShiftingLanes View Post
I bought a 2013 BRZ with 93K miles on it at the end of March. Fast forward 6 days later and it broke! It has been at the dealership for a while now and what they tell me is that the valve rocker arms have broken. I haven't seen the parts for myself and I'm not sure if there are any other problems within the engine.
So during this downtime I decided to make an update video to my #drivermod build and list out 5 major (and not so major) problems that I've encountered. Please give it a watch (and if you can tolerate it consider subscribing!!! )
Episode 2:
I will most likely do another one of these videos in the future with updated problems and solutions. I'm curious to know if these 5 problems are in line with what you all have experienced (I did use FT86club as the basis for most of these) and just how often this actually happens. If you've experienced any of these please let me know how you handled it.
Here are the top 5 problems I talk about:
1. Valve Rocker Failure
2. Rod Knock / Spun Bearing
3. Coil Pack failure
4. Fuel Pump Chirping
5. Camshaft Position Sensor
Welcome to the forum. One thin I learned real quick around here is you can’t say anything negative about this car without a lot of blowback. People seem to downplay the frequency of these problems. For example the injector seal problem. Seems everyone who has done a rebuild discovers their seals are bad even though they didn’t have symptoms. I suspect a lot of people roll around with bad DI seals but not bad enough for the popping sound and then post on the forums about how they haven’t had seal problems. Then you add to the fact that people seem to not drive this car regularly so we are just now starting to see the masses reaching the 100k mark.
Anyways, add my 2013 to the list of Twins with rod bearing problems. Mine went yesterday morning on the way to work. I started the engine pull this afternoon and hope to have the block split by the end of the weekend. What problem have you had with yours?
The Following User Says Thank You to ermax For This Useful Post:
ShiftingLanes (04-27-2018)
Old 04-27-2018, 09:40 PM   #41
ShiftingLanes
ShiftingLanes's Avatar
Drives: 2013 Subaru BRZ Premium WRB
Sorry to hear that! Mine is still sitting at the dealership. The last update was on Tuesday (4/24) and it was still waiting on parts to get delivered.
I can't say if mine has a bearing problem or not, it certainly made a rod knock sound right when it died. I had not heard of that sound throughout my short ownership which makes me think that the bearings were ok... but I can't say for sure.
ShiftingLanes is offline   Reply With Quote
Old 04-27-2018, 09:47 PM   #42
There is nothing wring with discussing the issues. The problem lies in people that state it is most or even all the cars. The serious issues are much rarer than this forum would make them seem. There are maybe 30 cases of rod bearing failure reported here. Even then the vast majorly of those issues are restricted to the very early cars. There are still more of those early cars driving around that never had problems. Too bad you had the issue since it sucks but that does not mean that everybody will.
HunterGreene (05-01-2018), reeves (04-27-2018), VoltsFRS2013 (04-27-2018)
brz, drivermod, problems, shiftinglanes
Major service Fletchlives78 AUSTRALIA 18 03-08-2017 05:22 AM
Need advice - major problems with Hotchkis kit GSX-R35 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 11-18-2016 02:48 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
Major Mods.. Jaden Scion FR-S / Toyota 86 GT86 General Forum 72 08-28-2015 10:16 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
