Old 04-26-2018, 10:24 PM   #15
highway7
Drives: FRS 2013
That's normal, also never seen that on another car before, but yes it's 'normal' on the FA20 and mine does it too
highway7 is offline   Reply With Quote
Old 04-26-2018, 10:39 PM   #16
Never seen a bouncing tensioner before? Most of the cars I had in the last 15 years or so do it.
Old 04-27-2018, 12:47 AM   #17
You are used to seeing either manually adjustable, or damped tensioners. All three are an equally valid approach to the problem based on where the tensioner lives in the belt path.
Tcoat (04-27-2018)
Old 02-11-2019, 09:14 PM   #18
kowalski
kowalski's Avatar
Drives: 2016 brz
Originally Posted by hyper4mance View Post
Is this normal for the tensioner pulley to wobble between the power steering pulley and crank pulley? (...) Thoughts?
Can not say for sure if it is normal. But mine does the exact same thing on a JSRC supercharged brz. It worried me a little, as I had smell some gas form the injectors on the drivers side and was checking all around for leaks, car seems to have lost a little power on low revs. But I never noticed that tensioner wobbling at idle. In fact, if you do search some videos of FA20 not every FA20 wobbles like that at idle. In any case, I am glad to know that this is no reason for concern (unless the belt starts slapping the pulley above).
kowalski is offline   Reply With Quote
Old 02-11-2019, 09:58 PM   #19
A supercharger changes the picture, [especially with respect to rough idle.] They all have a great deal of rotating inertia which will continue to pull the belt while the crankshaft is hiccuping. This causes the belt to go slack between the supercharger pulley and the harmonic balancer. I've seen belts jump and shred.
The movement in OP's clip is normal because it is periodic with respect to the entire belt.
Last edited by Ultramaroon; 02-11-2019 at 11:33 PM. Reason: included important point
new2subaru (02-11-2019)
Old 03-07-2021, 03:02 AM   #20
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I have the same issue as you regarding the lost power at low revs and the fuel smell on the driver side. Glad it is not just me. Did you ever figure out a solution? Thanks.
scion fr-s is offline   Reply With Quote
WTB: Rear Seat Belt Tensioner michaelbuccola Want-To-Buy Requests 3 06-28-2022 01:07 PM
Aftermarket pulley wobble with video killconey Engine, Exhaust, Transmission 62 02-15-2017 03:23 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 03:33 PM
Need V-belt tensioner torque value... cobrabyte Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-10-2014 11:47 AM
driver belt tensioner Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 3 07-10-2012 06:44 PM
