, dpfarr
Old 04-26-2018, 04:07 PM   #2787
Greenbean
Drives: 2017 series yellow BRZ
Originally Posted by gtengr View Post
Nice! I didn't see the new blower on their website. Anyone else heard anything?
they do not look any different and they dont sell them separate. it was a very minor change that you cant notice by looking at it. It was just the wiring to the alternator it hit.
Greenbean is offline   Reply With Quote
Old 04-26-2018, 04:34 PM   #2788
gtengr
Drives: 2017 BRZ
Yes I meant the kit/part number. The Jeg's website only shows the 2012-2015 kit.
gtengr is offline   Reply With Quote
Old 04-26-2018, 08:02 PM   #2789
Greenbean
if you call edelbrock they will give you the new part number even the edlebrock website is not updated to say 2013-2017 it still says up to 2016
Old 04-30-2018, 12:46 AM   #2790
86fun
Drives: 2013 FRS
The last few times I drove and got on the throttle when the car wasn't quite warmed up it flashed a CEL and went away. Then the other day it just stayed on. I didn't notice a lot of difference driving and waited to get home to check it. DTC was Cylinder #2 Misfire. Got me wondering if I got one of the engines that had a poorly gapped cam angle sensor... but my VIN is way past the highest in the identified range, yet I still have a 2013 FRS. Anyway, I have one of those OBDLink Blutooth readers and reset the code. After doing this the engine was running like absolute crap, bogging, missing, very low power, even a small backfire, and the exhaust note was really loud. At first I thought my Edelbrock lost it's belt!.. but I could still hear it whining. I was stuck driving around town for a few hours with it like this. Near the end of my errands, having stared and stopped the car several times, the car started working perfectly again. That's when it dawned on me, the code reset I did with the OBDLink must have reset the ECU completely and it needed to relearn the throttle/cam timing again... oops! Just wanted to tell my story and share that if your car runs like crap after an ECU reset... even just resetting the DTC's, it's going to drive terrible for quite a while as the engine relearns some things.
Any ideas on the #2 Cylinder misfire?
86fun is offline   Reply With Quote
Old 04-30-2018, 12:34 PM   #2791
CSG Mike
CSG Mike's Avatar
The learning goes away with a reset, but it should not run like crap. If it runs like crap, and then eventually goes away, there is a problem there that the ECU is eventually learning and compensating for.
You need to get your car checked out by a qualified shop.
Tcoat (04-30-2018)
Old 05-05-2018, 02:46 PM   #2792
kidgogeta
Drives: FRS
Any new updates or upgrades on the Edelbrock? Haven't been on forums forever but been running edelbrock kit without issues for past year now.
Current setup is just- edelbrock kit +JDL UEL header, 3" perrin running 265whp on 6AT tuned by Bob at Drift Office
Took it to drag strip yesterday for shits ran 14.01 @ 101 mph all night, was trying so hard to break into 13's lol the 6AT really holds me back can't launch for shit
kidgogeta is offline   Reply With Quote
Old 05-06-2018, 03:16 AM   #2793
djenousis
Drives: 2015
I had a similar issue, can't remember all the details as it's been many months but my problem was an o2 sensor/aftermarket header issue.
2015 Subaru BRZ
djenousis is offline   Reply With Quote
Old 05-11-2018, 05:04 PM   #2794
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Here's an update on throttle issues...
So, this week, I got into the car and immediately felt something was not right. The idle was all over the place and would bog down and then spring up and then bog down and spring up and so on. I tried to drive it to work...as I have had this happen so many times now, I just live with it when it happens...and I got about a mile down the road and it was so bad, I had to pull over. I let it idle for a few minutes and it stabilized enough that I tried driving it to work. On the highway it was ok, but not really stable, as even cruise control was moving. This went on for two days and then it threw me a check engine light. I continued to drive...I know, I shouldn't do that...and it would not let me engage cruise control at all. Finally I stopped at home, shut down the engine, started her back up and the check engine light was gone. I put in the OBDii dongle to see what Torque would tell me and, just as many times before, it showed a Throttle Position Sensor issue. I cleared the code and shut down. I started it back up and immediately it was better. Next morning, I got in the car and prayed for no more issues and it started up, revved to 2,000rpm, brought the revs down to 950rpm and settled...very smooth, very normal. I drove the car and it seemed like it had a dead-spot at take up, so I had to give it extra throttle to start-off or it would stall. Drove to work and it seemed back to normal, except for the dead-spot. Next day or so it went back to normal and no issues.
All this is observation. I am not sure what causes it, but it happens often and is worse with AC on. I still think it is a low voltage or battery issue, so I am going to get a new battery after a business trip and will update you at that time. It could be that it is having to learn throttle position all over again, following low voltage states, but this is all guesswork.
I am not looking for answers or suggestions, but I thought it was useful information for someone
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 05-11-2018, 07:39 PM   #2795
CSG Mike
CSG Mike's Avatar
A weak battery can cause all sorts of weird issues with this platform, and is not unique to the Edelbrock in any way.
Also, any CEL = no cruise control. If you try, it comes on yellow instead of green.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
funwheeldrive (06-22-2018), paiceyfan (05-11-2018), sato (05-11-2018)
Old 05-11-2018, 08:29 PM   #2796
sato
sato's Avatar
Drives: Dodge Patitas
Might be off topic, but this platform doesn't like leaving some OBD devices connected for too long. Had a CEL issue a while back, but was quickly resolved by removing the OBD Bluetooth adapter.
Sent from my Pixel 2 using Tapatalk
sato is offline   Reply With Quote
Old 05-11-2018, 08:50 PM   #2797
CSG Mike
CSG Mike's Avatar
That's a bad OBD2 port. Common on 2013's
funwheeldrive (06-22-2018), sato (06-04-2018)
Old 05-11-2018, 10:31 PM   #2798
paiceyfan
paiceyfan's Avatar
Interesting... because I have a cheap OBDii dongle and it would throw CEL codes occasionally and I now do not leave it plugged in.
Sent from my Moto G (5) Plus using Tapatalk
Old 05-19-2018, 03:07 AM   #2799
Wraith272
Drives: 2013 Subaru BRZ
I thought I'd chime in here as I've been experiencing the same throttle issues as you and taiguy. My throttle almost always has a slightly dead spot at the beginning of pedal travel, causing low speed driveability issues especially in traffic. It will also however occasionally start surging at idle up to about 1500 or 2000 rpm and then drop to about 500 and try to catch itself but sometimes stall out, this seems to happen if I drive the car for more than an hour or if it's driven in heavy traffic but never lights a CEL.
I did try a throttle body cleaning and the dead spot at the top of the pedal felt immediately better, maybe even completely fixed for a time, but definitely gets less responsive again if the idle issues surface.
Would LOVE to find a fix for these issues as Seattle area rush hour traffic is brutal enough driving a manual without battling an inconsistent throttle and occasional stall.
Wraith272 is offline   Reply With Quote
Old 05-21-2018, 01:50 PM   #2800
shr133
shr133's Avatar
Drives: 2013 FRS
Both issues are mapping most likely. The idle surge can happen if you change the intake, one of the maps is going too lean when you let off the throttle. The supercharger will make it worse. "assuming everything is connected and running correctly" and it's worse after a reflash, I'm narrowing it down and I almost got rid of it...
On acceleration there is a delay or hesitation or soft spot because of the transient delta1 and delta2 maps are still stock and need to be bumped up 3-5% on a N/A car and I would think a few percent more with the supercharger..
The transient map is the accelerator pump for FI... Start with a 3-4% bump and go from there. A little change makes a huge difference. Too much and it will feel flat. Will make the car feel much much better...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
The Following User Says Thank You to shr133 For This Useful Post:
sato (06-04-2018)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
