#197 | |
Drives: Grey GT86
What are your thoughts on the Audi TT RS, which is a direct Cayman S competitor? Based on the same platform as this tedious POS: ![]() Care to explain where the TT RS is compromised by being based on the same platform as that thing Not as good as the Cayman S maybe, but then neither is anything else for £50k.Ultimately you're still not getting what "platform" means in 2018. Look back at the pictures of the Passat and TT chassis, and see how little is common to those cars, which share the same platform. A tiny section between the A-pillar and the front axle. Do you genuinely believe that sharing that little with an Impreza is going to compromise the BRZ's dynamics? Especially given that the platform will already be based around a horizontally opposed longitudinal engine? |
| The Following User Says Thank You to spikyone For This Useful Post: | Tcoat (04-25-2018) |
#198 |
Drives: '15 BRZ RA
@spikyone Yes I believe that it would be compromised. Don't forget that a next gen 86/BRZ should be somehow better and the level of the current car is already pretty high! I know many people locally that would never look for an Audi TT RS and they have one or even more BRZ's in their collections. It isn't a coincidence that so many people praise this platform and saying it is one of the best money can buy unless you go into very high cost territories. Check an opinion here:
"That car makes incredible fun, is really good balanced and I'm not thinking of anything that I would change if it was my car. And that happend so good as never before. And the last car which I find really cool was the Porsche Carrera GT who cost 450.000€" |
#199 | |
TRACKBREAD
Your belief has no basis is reality. The MQB based TT is by FAR the best handling car out of the 3 generations, and is the lightest as well. Even Clarkson, who hates FWD based cars and their handling, lauded the new TT on how the front end grip is fantastic to bite in and then the rear is just loose enough to hang it out. Arguably the TT now is so good BECAUSE of the intensive platform sharing, as it gained a lot from the Golf R. VW doesn't put their best engineers on the R8 or the Chiron. They put their best engineers on the Golf, and that benefits all its platform-mates. Sent from my iPhone using Tapatalk |
| The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
#200 | |
| The Following User Says Thank You to funwheeldrive For This Useful Post: | Tcoat (04-25-2018) |
#201 |
And a couple of hundred threads here on how to change just about every aspect of the car. Not to mention that if you leave it almost stock then you are told you know nothing about cars.
| The Following User Says Thank You to Tcoat For This Useful Post: | bkharmony (04-25-2018) |
#203 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Monster Raving Loony ParTay!
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Tcoat (04-25-2018) |
#204 | |
Drives: '15 BRZ RA
#205 |
Drives: brz 2017 hksv2
if the chassis wasn t a compromise they would have worked around a carbon fiber chassis and worked around it to compensate for the slighty higher center of gravity it gives compared to the aluminum chassis we got, like a 4C
| The Following User Says Thank You to tomm.brz For This Useful Post: | Yoshoobaroo (04-26-2018) |
#206 | |
Drives: 2018 BRZ Limited, 2017 Sportage
The problem is that I do understand your concepts and in a theoretical world, they make sense. Taking the "I have superior knowledge to you" approach in your arguments, and dismissing factual inconsistencies is the hallmark of fake news. You can't take a theory and try to rationalize the surrounding facts to fit the theory. This is the antithesis of basic scientific method. Logical argumentation should be devoid of emotional bias. Personally, I'd like to support your theories because that would mean Subaru will continue to support the BRZ over time. But I cannot try to rationalize facts that don't fit that theory with, again, fake news. Furthermore, logic dictates that a new sports car design would probably be better without the limitations of an AWD platform with cars that are not designed for sports car handling and proportions. Given the facts we know (and not assumptions that have no Subaru delineated factual basis), there is absolutely no reason to believe that the global platform will be used for the new 2021 BRZ. If you don't understand the difference between deduction based upon delineated facts versus theory that requires the rationalization of facts, I just can't help you.... |
| The Following User Says Thank You to rvoll For This Useful Post: | nikitopo (04-26-2018) |
#207 | |
Drives: '15 BRZ RA
More details here: http://www.gt86ownersclub.co.uk/foru...8.html?KW=#top |
#208 | |
2) The Global platform is reported by Subaru as being used in their full range of cars from "A subcompact hatchback to a seven passenger SUV". It is not theory that it will be a scalable platform. This is well documented and irrefutable. 3) You have expressed nothing but an "I have superior knowledge" attitude and dismissed every factual piece of evidence placed in front of you. Your frequent "Ask an engineer" statements fly out the window as soon as an engineer answers. Now they are "Ask an engineer that agrees with me only". 4) Toyota does not have to "bend to the will" of Subaru. They tasked Subaru with much of the original design. Much of that design and even some of the actual parts are used in the new platform. Subaru will play a major role in designing any new version. The Lead Engineer is exactly that the lead. There will be a large team that actually performs the work. That team will consist of both Toyota and Subaru employees. That is presuming that both companies stay involved. 5) The new platform and any other platform can be used with any form of drive train. This has been done hundreds of times on the same model car over the decades. Because it is primarily designed for one drive system does not automatically rule it out for all others. 6) All of the speculation (no theory has been presented) has been based upon "delineated facts". Just because you disagree with or don't understand those facts does not mean that the logic is wrong.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | weederr33 (04-26-2018), Yoshoobaroo (04-26-2018) |
#209 | |
Subjective opinions are subjective.
#210 |
i would trade my brz for a 4c instantly lol.
but well.. i m poor and anyway, @nikitopo i dont really care what a guy who changed car think, it s his own business, i answered to you about the chassis. there is a compromise and it is the money for how good our chassis (i love it personally) it s still a 30k € car, there will always be a margin to improve it |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Tcoat (04-26-2018) |
