Old 04-25-2018, 05:51 PM   #1
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Belt Tensioner Pulley Wobble
Is this normal for the tensioner pulley to wobble between the power steering pulley and crank pulley? Could it be misfiring despite no code showing up? I'm concerned that it could be DI seals or the camshaft position sensor out of whack.
[ame="https://www.youtube.com/watch?v=uudLANdap_U"]https://www.youtube.com/watch?v=uudLANdap_U[/ame]
Some background - the car was warmed up at idle. I'm concerned since I had a p401 code pop up - misfire cyl 1. Since then I've swapped cyl 1 and 3 coils to see if that was the culprit and been driving on it for 2-3 weeks, no more CEL since then. I did have p351 code about a year ago - ignition coil malfunction, and replaced cyl 1 coil as a result of it. So swapping the newer cyl 1 coil to cyl 3 seems strange that it fixed the issue (so far). Thoughts?
hyper4mance is offline   Reply With Quote
The Following User Says Thank You to hyper4mance For This Useful Post:
kowalski (02-11-2019)
Old 04-25-2018, 08:56 PM   #2
Well, first off, I don't believe the pulley movement has anything to do with your past/present electrical problems.
I wouldn't worry about that much pulley movement ...... I'd just keep an eye on it.
Of course, @Ultramaroon would recommend replacing the idler pulley ......
Bubba would just give it shot of oil ......
hyper4mance (04-26-2018), mswbrz (03-08-2021)
Old 04-25-2018, 09:59 PM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
If it was deviating out out of plane I'd worry a lot more.
Each cylinder does not provide exactly the same impulse in their cycle.
At an idle, the difference is exacerbated even more than at higher output.
The idler was put in there to smooth out exactly those impulse differences.
If you're tuning it, find out which system is under performing and boost it a little.
edit: It's not going to break anything.
The Following 2 Users Say Thank You to bcj For This Useful Post:
hyper4mance (04-26-2018), Tcoat (04-25-2018)
Old 04-25-2018, 10:04 PM   #4
It is doing exactly what it was designed to do. Zero issues there.
hyper4mance (04-26-2018), jordan7831 (09-23-2018), ls1ac (04-26-2018)
Old 04-25-2018, 11:05 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
looks normal to me. Misfires on the other hand is not related to a pully.
If your still worried about replace it. It's cheap and a quick 10 minutes of your life. Unless it goes sideaways. Which it might. But that's just me.
Old 04-25-2018, 11:08 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Your cheap and a quick 10 minutes of my life?
Old 04-25-2018, 11:57 PM   #7
Wut?
Absolutely nothing wrong there. Don't fuck with it.
humfrz (04-26-2018)
Old 04-26-2018, 12:37 AM   #8
Wut?
Well, OK ......however, if the OP's pulley flies apart ....... it's on you .......
Old 04-26-2018, 12:42 AM   #9
NO!...NO! ........Spuds, NOT you ......... just slowly put the wrench down and close the hood .......
Old 04-26-2018, 12:51 AM   #10
You told him not to worry about it. Too bad for you.
humfrz (04-26-2018)
Old 04-26-2018, 02:42 AM   #11
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Eh.... any action is better than no action. Right?
Now, just hold off a tad bit... let's see where this goes.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
humfrz (04-26-2018), Spuds (04-26-2018)
Old 04-26-2018, 09:35 AM   #12
hyper4mance
Thanks for your input everyone, I just thought it was moving more than normal. I got a bit paranoid since getting the CEL's. Better safe to ask than sorry.
The Following 2 Users Say Thank You to hyper4mance For This Useful Post:
Tcoat (04-26-2018), Ultramaroon (04-27-2018)
Old 04-26-2018, 10:36 AM   #13
Nobody has really answered your second question though. If moving the pack seemed to work it may have just been a connection issue. Try moving it back again and see what happens.
Old 04-26-2018, 11:35 AM   #14
hyper4mance
Okaly dokaly. Working on the other cars this weekend, so prob wont get around to this one for another week or two. Hopefully I'll remember to keep you posted.
Tcoat (04-26-2018)
WTB: Rear Seat Belt Tensioner michaelbuccola Want-To-Buy Requests 3 06-28-2022 01:07 PM
Aftermarket pulley wobble with video killconey Engine, Exhaust, Transmission 62 02-15-2017 03:23 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 03:33 PM
Need V-belt tensioner torque value... cobrabyte Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-10-2014 11:47 AM
driver belt tensioner Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 3 07-10-2012 06:44 PM
