Old 04-24-2018, 05:31 PM   #1
okenso
Drives: 2016 FR-S
Question TPMS Help - OEM Winter, Aftermarket Summers
Hello, I've scoured the internet and this forum, but this TPMS stuff still does not make any sense to me.
I have a 2016 FR-S with OEM rims/sensors that have winter rubber on them.
I also have Niche Targa M129 rims with summer rubber on them, and WURTH 315 MHZ TPMS sensors inside those.
When I put my winter's on back in Fall 2017, I had to bring my tires into Toyota to get them reprogrammed (or something else? the light was on, they fixed it and now it's gone). From what I understand, I'll have to do the same thing with my summers now that I want to put them on, because apparently the FR-S can't learn another set. Is this correct?
So from my understanding, I can change my wheels myself every Fall/Spring and bring the car into Toyota to have them re-program (is this right?) the sensors, and pay half an hour of service.
Is there a TPMS tool that I can buy and do this myself? I've read that there's sensors that can hold 2 sets of codes for winters/summers, but I haven't found a definitive guide for my car.
If I can't do this myself, should I just bite the bullet and get Toyota to replace my aftermarket rims sensors with cloned ones that match my winter sensors? It seems like such a waste, considering they'd have to take the wheels apart and there's nothing wrong with the sensors inside there.
I appreciate any help you guys/gals can offer. What tools would I need? I'm in Canada, by the way.
Also, I've never heard of anyone else having this problem, is this a Toyota thing? My brother is a big car nut and has owned everything from Porsche's, Camaros, AMG Mercedes to Lancers and Accords and he never had this issue. As much as I love the look of my car, I probably would have not purchased it if I knew this would be a seasonal hassle.
okenso is offline   Reply With Quote
Old 04-24-2018, 05:50 PM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
It's a Subie thing. They don't like to have different set of TPMS. There is a TPMS tool that help program, so you don't have to waste more money going to the dealership... but it's not 100% work (I stand corrected)
What I usually do is, I have TPMS on my summer set and don't have any TPMS on winter set and Beastronix's 86Nanny. As long as you don't drive 25 miles, TPMS light doesn't turn on. When I come back home, my summer tire is in the garage, so it reset itself and TPMS light turns off when I start up my car next time. Even if it does goes on, I have 86Nanny to reset it for me whenever I want to.
JMon85 (04-24-2018)
Old 04-25-2018, 04:23 PM   #3
okenso
Drives: 2016 FR-S
thanks for the reply!
My wheels aren't stored at my home as I'm in a small apartment without a garage, I don't think my setup will work like yours does. I'd really like to keep both TPMS going for my winter/summer set incase I pick up a nail or something, I've seen awful crashes because a tire gives out. Do you know which tool wasn't 100% guaranteed to work, so I can avoid it?
Anyone else have any ideas?
Old 04-25-2018, 05:09 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'm about to get summer and track wheels and tires, I'm just gonna let the light come on and keep an eye on tire pressures manually like I've done for every other car I've ever owned... TBH I'm disappointed in the system, it would be useful to me if it displayed the pressure but alas it does not.
Old 04-25-2018, 05:09 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Crashes due puncture may happen when it's sudden and major damage to tire, letting almost all air out at one go while you go at fast speed. TPMS won't save you from such, just another warning light on dash when your car is crashing. It may help finding out about punctures that pass out air gradually which i hardly doubt to cause sudden crash.
If TPMS matters to you, just get some tool/solution to reset yourself instead of going to dealership. Probably most options will be payware though. But at least one-time, instead of paying that twice each year at dealership.
Old 04-25-2018, 06:26 PM   #6
tobin
tobin's Avatar
Drives: '13 BRZ
ATEM Quickset
tobin is offline   Reply With Quote
Old 04-25-2018, 07:35 PM   #7
Firecruiser
Drives: 2014 brz
Originally Posted by tobin View Post
Relatively easy to use. I highly recommend it for anyone who has kept sensors in two sets of wheels.
Firecruiser is offline   Reply With Quote
The Following User Says Thank You to Firecruiser For This Useful Post:
Qadthane (04-26-2018)
season, swap, tire advice, tpms
FS: Konig Zero-In 17x7 +40 wheels, TPMS, Stock Summers (~10k mi) mezdup Wheels and Tires 2 05-11-2014 12:29 AM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 08:11 AM
Winter's back to Summers Pforwell CANADA 7 03-10-2013 10:51 PM
Do I Really Need TPMS with my After Market Winter Package? Zagmeister Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 12-17-2012 09:47 PM
