#1191 | |
AutoX Nut
Drives: 2020 Toyota Supra
My benchmark is against my fellow SSC competitors (we've been averaging 5-7 locally) and myself. There have been a couple events where I didn't even have to look at the other SSC times to know I was off pace. I'm just having trouble placing the car where I want sometimes and I'm going back and forth between understeer and oversteer (within the same run). I'm sure most of it is on me, but I honestly don't remember struggling with this kind of inconsistency when I competed with the twins in 2012 - 2016. Like I said, I'll just keep at it and thankfully we have a good local SSC group where we can share ideas and feedback. Your idea about riding in other cars is good one, and maybe some of us SSC guys can trade cars for Seat Time Only runs. Thanks for the feedback and thoughts. |
#1192 | |
Drives: 2016 Scion FRS
So how do you benchmark yourself if you are the only car? Don't say co-driver because it is hard to put good drivers in slow cars, even when they DO pax well. |
#1193 | |
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
I get what you're saying. You have to be able to verify against consistent national level type people, that show up in the same car week to week, that just arrive and drive, that don't tinker and adjust their cars. There are very few national level people that do that. Which is what makes it hard. If they adjust or change their car week to week, you're fighting a moving target when you attempt to compare. The only thing left is you against the course. You gotta find that time out there, not vs others.--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
#1194 |
Drives: 2013 FRS White w/ cone marks
I think you might be looking at a different "Spec Twin" than we are. We're talking about SSC class in SCCA Autocross
| The Following 2 Users Say Thank You to chkltcow For This Useful Post: | rice_classic (04-25-2018), strat61caster (04-25-2018) |
#1195 | |
Drives: Nevermorange FRS
It's funny cuz it's true. Moved to a more applicable thread. But, I still bring up good points.
PRO86 | WTCC | STL
#1196 |
Bring out your dead
Finger Lakes Champ Tour reg opened last night and it hasn't sold out yet. 150 entrants with only 2 in SSC so far....
--kC
#1197 | |
...but your competition is always going to be a moving target. It isn't really like golf or bowling by yourself or drag racing test & tune. Locals for me this year are basically really inefficient, busy, time consuming test and tunes, without the opportunity to really test anything. Pay $45 and give up 13 hours to take 6 runs, maybe. This probably won't help my consistency or sorting the car at all, but I think I may skip all locals. Anyway... Replaced a couple wheel studs, tightened all my suspension bolts, moved the front bar to stiff, gonna revisit higher pressures, got my muffler on, so I'm ready for Blytheville. Last edited by steverife; 04-26-2018 at 10:24 AM. |
#1198 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I would try to get the car to where it is at least predictable for you and your driving style first.
FWIW; of the 4 SSC cars I have driven, Malcom's car, with both bars set to stiff, had the sharpest edge. Keeping it on the edge was more challenging than the other examples. It wasn't a huge difference from my soft/soft setup, but it required me to pay a little more attention to my inputs. Also, after doing another local with a tighter course, I think I will stick with the stiff setting for the rear bar for now. (Front still set to soft) |
#1199 |
Drives: '15 STX
After the Crow's weekends, Soft/Hard is what I preferred. It's what I was on for both Pros, now. You can lean on the car harder in corner entry without so much punishment. It's also more willing to rotate with throttle lifts and it takes small line adjustments without complaints.
Hard/Hard is really tight and the car is super sharp, but it also punishes you with understeer if you increase intensity. Was on that for the Tour. |
#1200 | |
Bring out your dead
Does the bar make setting the shocks irrelevant? --kC
#1201 | |
Drives: '15 STX
The shocks are the best part of the package, aside from being the OE body height. At hard/hard the shocks become a little less relevant but they're still useful. |
#1202 |
Drives: None
Fun weekend in Blytheville. Here's what we ran
Started Saturday Bars: Soft/Stiff Fronts: Full Soft Rears: 1.5 turn from soft Pressure: 35/34 ended up at (switched to this Saturday afternoon) Bars: Soft/Stiff Fronts: .5 turn from soft Rears: 1.5 turn from soft Pressure: 32/32 Kevin was monitoring tire temps and 32/32 is what we settled at to get even temp across the tire.
'16 FR-S SpecFRS.com
#1203 | |
2013 FR-S Whiteout / SSC
How does the Blytheville surface compare to Lincoln? |
#1204 | |
Drives: 2013 FRS
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
| my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 09:23 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 11:20 AM |
