Old 04-25-2018, 12:18 AM   #1
vh_supra26
Site Moderator
Drives: Supra
The All-New 2019 Lexus ES: Transformed for the World
http://pressroom.lexus.com/releases/...n+lexus+es.htm
Emotional Design Reflects New Dynamic Capabilities
Introduction of the First F SPORT Model in the ES Lineup
Hybrid Model Delivers Exceptional Mileage and Improved Performance
April 24, 2018
BEIJING, April 25, 2018—After six generations of unprecedented success in the entry-luxury sedan category, the next-generation Lexus ES is forging a new, more ambitious path. Long known for its unparalleled comfort, refinement and luxury appointments, the seventh-generation ES builds on its strengths with an all-new chassis that allows for a more dynamic exterior design and the introduction of the first ES F SPORT.
Representing the third vehicle in the Future Chapter of Lexus that started with the LC coupe and LS sedan, the new ES expands that vision of the brand’s future to a broader audience. Traditional buyers will find the new ES more spacious, quieter and safer than ever before while a new generation of customers will be introduced to a sedan with sharpened performance, class-leading active safety technology and a level of craftsmanship rarely found in this segment.
The New Dimension of ES Design
Built on the all-new Global Architecture – K (GA-K) platform, the new ES pushes the limits of design in the luxury sedan class. This ES is longer (+2.6 in), lower (-.2 in) and wider (+1.8 in.) than before with wheels that have been pushed closer to the corners thanks to a two-inch longer wheelbase and wider tracks front (+.4 in) and rear (+1.5 in). Its stance and proportions reflect its newfound performance capabilities and give the ES the kind of eye-catching appearance that will make owners take a second look as they walk away.
Project Chief Designer, Yasuo Kajino, describes the look of the ES as “provocative elegance”.
“The ES has always been an elegant luxury sedan. For this generation, we have added daring design elements that challenge the traditional expectations of buyers.”
To create a dynamic yet fluid shape, Kaijino’s team used the low hood enabled by the new ES platform to produce a distinctive silhouette emphasized by an aggressive downward slant. Up front, the ES offers two dramatically different grille designs. The standard ES 350 and the ES 300h use elegant vertical bars that radiate out from the center while the ES 350 F SPORT model adopts a blacked out pattern consisting of “L”-shaped clusters with corresponding cut outs at each corner of the fascia.
In a break with ES models of the past, the seventh-generation design uses a fast roofline that emphasizes its lower stance and slippery aerodynamics. The rear end is clean and sharply chiseled, with LED taillamps that wrap around the quarter panels to provide a continuous styling line from any angle. F SPORT models add a rear spoiler, additional rear badging and a dark lower valance to further refine the look. There are three different wheel designs (standard 17-inch, two 18-inch) for the ES 350 and ES 300h while the ES 350 F SPORT gets standard 19-inch wheels with a design similar to that found on the LC coupe.
A dozen colors make up the exterior paint palette including two new shades, one green and one beige, that are anything but typical. Moonbeam Beige Metallic was designed to mimic light reflecting off fresh snow, while Sunlit Green replicates the color of ocean water brightened by the sun. F SPORT models get an exclusive Ultra Sonic Blue Mica 2.0 color that complements its high-energy design.
The Future of Lexus Interiors
When designing the look and feel of the ES’s interior, Kajino’s team started with the Lexus Future Interior concept which blends a driver-centric cockpit with a spacious and comfortable area for the front passenger. In the ES, the driver’s focus is kept on the road ahead by placing the center display screen, instrument panel and available heads up display in a tight cluster in the driver’s field of view. Front passengers, on the other hand, get a more open and spacious environment that promotes relaxation.
Rear seat passenger comfort has long been a hallmark of the ES and the seventh-generation model still prioritizes rear package capability despite the sleeker exterior roofline. A lower hip point and a carefully configured headliner preserve headroom while the longer wheelbase delivers generous legroom.
To create an entirely different appearance for the inside of new F SPORT model, an all-new kind of metallic cabin trim was developed that is unlike anything else Lexus has done before. Inspired by the making of a traditional Japanese sword, Hadori aluminum trim features fluctuating wave patterns that give it a three-dimensional appearance that varies depending on the viewing angle. The effect is subtle yet indicative of the level of detail and craftsmanship that Kajino’s team put into giving the F SPORT a unique place in the lineup. The standard ES 350 and ES 300h will continue to offer traditional materials like Matte Bamboo, Linear Dark Mocha and Linear Espresso wood which give the ES a hand-crafted appearance that luxury buyers expect in this category.
A New Era of Performance
The engineering team led by Yasuhiro Sakakibara had one clear goal when it came to the ES: transform the image of the ES. That meant turning a sedan known primarily for comfort and quietness into one that is equally capable of delivering class-leading handling and power that you can feel and hear.
According to Sakakibara, this ES was built to deliver a fundamentally higher level of performance than any of its predecessors. “We knew that this ES had to feel responsive and easy to drive, no matter what kind of road it was on and that can only be achieved with a solid foundation.”
The starting point was the newly developed GA-K chassis. It’s an exceptionally rigid front-wheel drive chassis, rivalling the GA-L rear-wheel drive platform used for the LC coupe and LS sedan in terms of torsional stiffness. Various grades of high-tensile steel reduce weight versus previous platforms while additional enhancements like an all-new multi-link rear suspension design, rack-mounted electric power steering and a V-brace mounted behind the rear seat gave the engineers the flexibility to tune the ES with a newfound level of precision.
All of the upgrades to the chassis were designed to deliver a sense of comforting predictability coupled with a feeling of quick response to every movement. Yoshiaki Ito, chief test driver for Lexus, describes the ES’s heightened level and refined definition of comfort by saying: “We want every kind of driver to feel a sense of complete control when they are behind the wheel of the ES. It’s a level of comfort that goes beyond merely delivering a smooth ride.”
For an enhanced level of dynamic performance, F SPORT models offer an Adaptive Variable Suspension (AVS) similar to that found on the LC coupe. AVS adds adjustable dampers at each corner that feature 650 levels of damping force for the ultimate in control over any surface. Another F SPORT exclusive is a Sport+ mode for the Drive Mode Select system that selects the most aggressive engine, transmission and suspension settings for maximum performance. A new Engine Sound Enhancement feature is also activated in Sport+ mode that adds an additional layer of engine noise that enhances the natural rhythms of the spirited driving.
Standard V6 Power and a New 8-Speed Direct-Shift Automatic Transmission
All ES 350s are powered by a 3.5-liter V6 that is designed to deliver commanding acceleration along with an invigorating sound. With an update to D4-S fuel injection, the impressively smooth engine now develops 302 horsepower and 267 pound-feet of torque. Both of those numbers are up significantly (+34 hp, +19 lb-ft) compared to the previous generation V6.
In addition to the boost in power, the ES 350 also benefits from a new eight-speed Direct Shift automatic transmission. It uses an ultra-thin torque converter and a multi-plate lock up clutch to more efficiently transfer power to the front wheels, and has been tuned to deliver crisp, precisely timed shifts with quick responses. With a wider spread of ratios, the new eight speed is able to utilize high torque gears on the low end for quick starts and tall gearing on the high end for optimum efficiency.
Fourth Generation Hybrid Drive System
Not to be outdone by its gasoline siblings, the ES 300h is capable of delivering exceptional fuel efficiency, responsive performance and minimal emissions for an entry-level luxury sedan. A new, fourth-generation Hybrid Drive System couples an ultra-efficient, Atkinson cycle 2.5-liter, four-cylinder gas engine with a lighter, more compact, more power dense electric motor and self-charging hybrid system. Together they deliver a combined 215 total system horsepower and a preliminary estimate of 44 mpg in combined driving.
An all-new engine, the 2.5-liter four-cylinder incorporates fast-burn combustion technology that makes it one of the most thermally efficient engines ever offered in a Lexus. The result is more power without increasing emissions or fuel consumption. Various methods were used to achieve such impressive results including straight intake ports, increased valve angles and laser-clad valve seats. A variable capacity oil pump, multihole injectors, VVTi-E on the intake valves and a variable cooling system also contribute to the engine’s impressive heat and combustion management.
Overall drivability of the ES 300h has been improved thanks to a more sophisticated hybrid system control computer that is better able to mimic the feel and power delivery of a standard gas engine. An all-new nickel metal hydride battery is smaller than before which allows it to be mounted underneath the back seat so it doesn’t infringe on trunk space.
Unparalleled Safety Comes Standard
One element of the ES that hasn’t been radically transformed is its dedication to safety. All versions of the seventh-generation ES feature the new Lexus Safety System+ 2.0 as standard equipment. Already one of the most sophisticated systems of its kind, LSS+ 2.0 adds new features that further expand its capabilities.
One such feature is daytime bicyclist detection which is part of the comprehensive Pre-Collision System (PCS). Already designed to detect an oncoming vehicle or pedestrian, the PCS system’s ability to potentially detect a bicyclist addresses a common accident scenario. PCS has also been enhanced to help better detect a pedestrian at night by increasing the radar’s sensitivity and dynamic range.
Technology That Connects and Simplifies
Staying connected has never been so important to ES owners, so there are now multiple ways to engage with technology in a safe and convenient manner. For example, the seventh-generation ES is the first Lexus product to offer Apple CarPlay™ phone functionality, enabling drivers to control their iPhones® through the dashboard display screen or with Siri Eyes Free® voice control.
The ES is also Amazon Alexa®-enabled, so drivers can use natural language commands to control a variety of functions. That functionality includes car-to-home and home-to-car commands, so owners who have Alexa enabled devices in their home can interact with their ES before they ever get behind the wheel.
On board Wi-fi powered by Verizon is also available on the ES as part of an optional navigation system that includes an easy-to-read 12.3-inch wide dashboard display. Along with its on-board data set, the navigation system is also capable of receiving over-the-air updates for improved routing and the latest Points of Interest (POIs). Models without navigation will use an 8-inch display and all interactions will be controlled through the Remote Touch Interface (RTI) trackpad.
The Next Chapter of ES
When it goes on sale in September, the 2019 Lexus ES will usher in a new era for one of the brand’s most popular models. Much like the flagship LS, the new ES sedan addresses the need to engage a broader range of customers. It delivers everything that traditional Lexus buyers expect along with elements that will draw in those who haven’t considered the brand before. Bolder styling, more dynamic performance, unique cabin materials and the latest technology add a chapter to the ES story that hasn’t been told, but that all changes in 2018.
ES 350 ES 300h
Engine 3.5-liter V6 2.5-liter four-cylinder hybrid
Layout Front-wheel drive Front-wheel drive
Transmission 8-speed automatic Hybrid
Max engine output (hp) 302
Max engine torque (lb-ft) 267
Total system output (hp) 215
Battery Type Nickel Metal Hydride
Length 195.9 195.9
Wheelbase 113.0 113.0
Width 73.4 73.4
Height 56.9 56.9
vh_supra26 is offline   Reply With Quote
Old 04-25-2018, 01:28 AM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Rollin on Michelin Primacys!! WHAT WHAT!!!
Originally Posted by humfrz
I'm old and lazy
Old 04-25-2018, 02:04 AM   #3
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Prius tires?
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 04-25-2018, 02:24 AM   #4
j3rf
j3rf's Avatar
Looks like a Lexus, no doubt about that.
13 BRZ Limited 6MT Lightning Red
j3rf is offline   Reply With Quote
Old 04-25-2018, 11:27 AM   #5
Originally Posted by LOLS2K View Post
Prius tires?
LOL. Lexus has always used Primacys. Harder to make fun of them when you say "Lexus tires" though.
Old 04-25-2018, 11:56 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ugliest Camry ever...
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Dadhawk (04-25-2018), jeffchap (04-25-2018), Tcoat (04-25-2018)
Old 04-25-2018, 12:27 PM   #7
gymratter
Drives: BMW
Originally Posted by ZDan View Post
Ugliest Avalon ever...
fixed
gymratter is offline   Reply With Quote
The Following User Says Thank You to gymratter For This Useful Post:
Yoshoobaroo (04-25-2018)
Old 04-25-2018, 12:28 PM   #8
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Meh...
Sent from my Moto G (5) Plus using Tapatalk
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 04-25-2018, 01:01 PM   #9
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
C'mon @Tcoat, you know what I was doing there. Well, you SHOULD know by now.
The Following User Says Thank You to LOLS2K For This Useful Post:
Tcoat (04-25-2018)
Old 04-25-2018, 01:10 PM   #10
LOL I most certainly did! That was why I said it wasn't as much fun as saying "Lexus" tires when trying to insult them.
Old 04-25-2018, 01:19 PM   #11
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
Made up name, created in a advertising agency boardroom then vetted by a focus group to make sure it sounded luxurious and non Asian. No thanks.
SCQTT is offline   Reply With Quote
Old 04-25-2018, 01:49 PM   #12
Ummmm... Isn't that true for all car names?
8RZ (04-25-2018), Dadhawk (04-25-2018)
Old 04-25-2018, 03:28 PM   #13
Well, not all (since we are really talking about brand). Aren't most named after their founders?
Dadhawk is online now   Reply With Quote
Old 04-25-2018, 03:32 PM   #14
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
No, actually its not.
Chevrolet, Ford, Cadillac, Chrysler, Honda, Toyota, Datsun, BMW, Audi, Harley Davidson, Yamaha, etc.
Most are historic and have ties to the original founder.
Lexus is some made up shit from the west coast to distance themselves from the disgusting nature of the Toyota nameplate. How dare the economy brand become an engineering powerhouse and dominate worldwide basic transportation and any racing they decide to participate in. Yeah, that's embarrassing, let's distance ourselves from that and make up a name that sounds like the western word for opulence.
The Following 2 Users Say Thank You to SCQTT For This Useful Post:
Dadhawk (04-25-2018), Tcoat (04-25-2018)
This is the C8 mid-engine Chevy Corvette vh_supra26 Other Vehicles & General Automotive Discussions 970 06-21-2023 10:36 PM
2019 Toyota RAV4 NemesisPrime909 Other Vehicles & General Automotive Discussions 46 12-05-2020 10:35 PM
2019 Toyota 86 TRD Edition interna CANADA 8 07-08-2018 10:02 PM
