Old 07-10-2012, 10:49 PM   #267
Don@Accelerated
Don@Accelerated's Avatar
Overall view from laying on my back. Gives you a good idea of where the piping runs. This is the 2.5" downpipe which mates to the stock catback.
Don@Accelerated is offline   Reply With Quote
The Following 11 Users Say Thank You to Don@Accelerated For This Useful Post:
Chewie4299 (07-13-2012), civicdrivr (07-11-2012), cobrabyte (07-10-2012), MannyO (07-11-2012), nix (07-12-2012), Roadstercycle (07-11-2012), rusty959 (07-11-2012), sirus (07-12-2012), TPO (07-10-2012), Turbowned (07-14-2012), wcbjr (07-11-2012)
Old 07-10-2012, 10:49 PM   #268
xcelir8brz
Drives: 2013 BRZ Limited
Originally Posted by Don@Accelerated View Post
Picture of the first half of the overpipe. This pipe is composed of thick wall .109" 304 Stainless Steel. This would be considered heavy wall tubing. Much more rigid than the .065" we usually use. Less prone to cracking and I was also very worried about sag.
This pipe is seperated mid way by vband. The original design required the motor mount bolt be removed and the engine lifted. I wasn't a big fan of this so a redesign was in order. Now it goes in and out w/ no problems. Much easier to move than the factory piece.
Sweet!
xcelir8brz is offline   Reply With Quote
Old 07-10-2012, 10:49 PM   #269
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Sitting so low, how is the oil going to return to the oil pan?
Edit: nevermind just read the last page
Silverdub is offline   Reply With Quote
Old 07-10-2012, 10:50 PM   #270
xcelir8brz
That is awesome!
Old 07-10-2012, 10:51 PM   #271
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
:happy0180:
Old 07-10-2012, 10:51 PM   #272
slow_frs
Drives: turbo scion tc
Originally Posted by jedibow View Post
that would adding hot oil to the cylinder head... Better options
Most the remote turbo kit guys do this in the v8 world, even if don doesn't do this I will extend the line to the oil cap I'm done with taping oil pans, coming from a guy who has built plenty of boosted toyotas
slow_frs is offline   Reply With Quote
Old 07-10-2012, 10:54 PM   #273
slow_frs
Scavenging pump...
Old 07-10-2012, 10:54 PM   #274
Don@Accelerated
Another view on my back. My shirt was already dirty so what the hell!!!
So you may be noticing there is no header. You would be correct. It is not required. I do like keeping the OE cat at this point. Should you chose to buy an aftermarket header. It will bolt right up in the same way with out modification. Thus far this kit is 100% zero cutting involved. From the front all the way to the back.
I've also setup at this time as well for a larger turbo A little grinder is needed for some clearance and that will bring the HP potential north of 700hp Obviously lots of other modifications would be required. This basic setup will supply up to 350hp worth of airflow.
Keep in mind this does not mean you can make 350hp. Sorry the engine is most likely not going to like that.
The Following 5 Users Say Thank You to Don@Accelerated For This Useful Post:
00NissanNinja (07-11-2012), armythug (07-14-2012), Boxer 86 (07-20-2012), Synack (07-11-2012), wcbjr (07-11-2012)
Old 07-10-2012, 10:55 PM   #275
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
you have to take into account that as the oil travels the length of the car the lines have a cooling effect, I don't believe there will be enough line to cool it off.
The return would also have to be above the pan to avoid backing up the pump.
G
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-10-2012, 10:56 PM   #276
Don@Accelerated
No thats fine. The oil by the time it reaches the cylinder head is much cooler if not cooler than the oil in the head.
The Following User Says Thank You to Don@Accelerated For This Useful Post:
jedibow (07-10-2012)
Old 07-10-2012, 11:04 PM   #277
ImAwesome
Drives: 99' M3, 13' SWP Brz
quit tempting me
ImAwesome is offline   Reply With Quote
Old 07-10-2012, 11:07 PM   #278
slow_frs
G
a good scavenging pump 2-5gpm will not back up.... put the pump close to the turbo and let it do its job those suckers FLOW
Old 07-10-2012, 11:09 PM   #279
slow_frs
don i dont see the wastegat... but i assum it will be on the over pipe correct?
Old 07-10-2012, 11:12 PM   #280
Don@Accelerated
Wastegate is just not in those pictures. I opted for a different one this time around (Tial MVS)
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
