#477 |
Drives: 2014 Scion FRS (Red)
So just installed ohlins v2. With adjustments to everything recommended in the manual, my rears sit a little higher , about 1 cm than the front. Normal?
#478 |
Drives: 2014 GT86
ajc209: IF range big enough to cater. And then there are bits that spring rates are halved (which makes it less believable) and then even they themselves say that better not use springs firmer then by 35% without revalving.
Imho simpler to label off this kit permanently as "Road" only, or for tracking only on limited grip tires, and if anything from non-discontinued Ohlins offering is worth considering for track use on sticky tires, r compounds, then maybe only their japanese BTO set of 88.2N/mm 9kgf/mm - 68.6N/mm 7kgf/mm rates. IIRC they are still being sold on their online auction sites .. no clue on possible shipping/import/warranty issues though, if going this way. |
#479 |
Drives: '15 BRZ RA
@Scracho Why don't you check the Sachs performance coilovers that have Front 38.50N/mm and Rear 42.50N/mm? These rates are more appropriate for track comparing to the front biased rates of Ohlins. Going much more stiffer it'll ruin the dual characteristic of your car being road and track friendly.
PS: I've seen your track video trying to outrun a Cayman GT4. You would not have a better chance with a Pilot Sport 4 tire, when the GT4 has a Pilot Sport Cup 2 tire. Your first priority should be to change the tires to a better compound. The latest Advan A052 tires from Yokohama are quite capable and with even more friendly road manner than the Cup 2. Sachs coilovers are enough to handle these tires in stock size, if you don't mind some body roll ... |
| The Following User Says Thank You to nikitopo For This Useful Post: | Scracho (04-22-2018) |
#480 |
Drives: GT86 Cosworth
Quick Google will show shock dyno for the mi20 with a 250-300% change in low speed damping from -20 clicks to 0 clicks.
On stock 60N it feels to damped to me at -5clicks. I go faster on smooth tracks at -8clicks. On bumpy track I use -12 which is my fast road. These are front setting, I tend to get a couple clicks more at the back as they get softer. Sent from my SM-G935F using Tapatalk |
| The Following User Says Thank You to ajc209 For This Useful Post: | Scracho (04-22-2018) |
#481 | |
Drives: 2018 Subaru BRZ
LOL! That GT4 was playing nice with me and to be fair my tire pressures might have been too high on a cold day. The track wasn't holding any temperature either with the wind that day. I haven't decided on tire just yet, but it will be a sub 200 UTQG rating. I'm going to throw dice in the wind here and try my luck with higher spring rates... Stay tuned!
On my fourth 86... and everything in between
| The Following User Says Thank You to Scracho For This Useful Post: | nikitopo (04-22-2018) |
#482 | |
| The Following User Says Thank You to ajc209 For This Useful Post: | nikitopo (04-22-2018) |
#483 | |
Drives: '13 FRS - STX
I don't remember what the fender heights are off the top of my head, but I think lowering evenly is the way to go. |
#484 | |
Thanks. I'll leave it as such. I followed the manual exactly. Looks pretty close lol
Thanks Quote:
#485 | |
1.9Hz natural frequency is generally considered quite high for a road car after all... Last time I spoke to the person in question they were looking to releasing a kit with just top mounts allowing the user to pick spring rates within a certain range, but he did confirm they set the damping on the MI20 with room on both sides to allow significantly stiffer or softer springs without too much trouble. RCE quite liked thed the MI20 on 8kg springs and standard valving and I believe they still ran them at 6-8 clicks for track...i.e. not full stiff.... There's the info anyway, people can ignore it if they want. |
#486 | |
| The Following 2 Users Say Thank You to Scracho For This Useful Post: | ajc209 (04-23-2018), strat61caster (04-23-2018) |
#487 | |
Drives: 2013 Firestorm FR-S
It's interesting how three of the largest, and most respected, Euro* performance suspension companies (Ohlins, KW, Bilstein, and SACHS) all ended up with similar spring rates on their road and track style coilovers for the application.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | nikitopo (04-23-2018) |
#488 | |
Sachs, KW & Bilstein ship a stiffer rear spring than front. Ohlins has always had a softer effective rear than front even on the mi20 kit, and they're swedish. |
| The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (04-23-2018) |
#489 |
Drives: '23 BRZ
#490 |
My point being of going to significantly softer rates, not necessarily the relation of front to rear rates. And I mistakenly used German when I really meant Euro, basically just in contrast to the various Asian suspension companies, or US rebox/custom adaptation setups, which seem to keep stiffer setups overall.
| The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post: | nikitopo (04-23-2018), strat61caster (04-23-2018) |
| ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 06:00 AM |
| >> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! | Circuit Motorsports | Brakes, Suspension, Chassis | 90 | 08-16-2013 01:39 PM |
| Ohlins Road & Track Coilovers - IN STOCK!!! | RallySport Direct | Brakes, Suspension, Chassis | 7 | 05-28-2013 05:11 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| Ohlins Road & Track Subaru BRZ and Scion FR-S | HP Autowerks | Brakes, Suspension, Chassis | 0 | 04-24-2013 04:27 PM |
