Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-20-2018, 06:40 PM | #1 |
Drives: WRB BRZ
Need HELP. Car doesn't turn on
I need your help. My car is not turning on at all. It doesn't crank and accessory doesn't turn on. I was installing my coilovers and I accidentally hit the positive with my wrench. I have checked the fuses unless I missed something and the battery is at 14v. Even took out the terminal and sanded a bit then put it back but I still can't turn it on. What else can I check to fix this? Thank you
I wasn't sure where to post this. |
04-20-2018, 06:49 PM | #2 |
Drives: 2013 frs
Did you check the fuses on the terminal? There are 2 iirc that could be your problem
The Following User Says Thank You to sid94 For This Useful Post: | Erick KY (04-20-2018) |
04-20-2018, 08:50 PM | #3 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Yes, check these 2. Fusible link block comes as an assembly with both fuses. Part# 82211CA010
The Following 3 Users Say Thank You to BirdTRD For This Useful Post: |
04-20-2018, 09:38 PM | #4 |
LMGTFY
Drives: 13 FRS, 91 Miata
Check ALL the fuses first then get back to us.
Under hood and in car. |
04-21-2018, 09:18 AM | #5 |
Drives: WRB BRZ
thank you everyone. it was the fuse on the terminal. good thing it's a cheap part.
Similar Threads | ||||
Winjet doesn't know direction to turn for adjustment on headlights. Anyone here know? | Username | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-05-2016 03:54 PM |
LED stripe doesn't turn on on my FR-S | Terruko | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 09-09-2016 11:01 PM |
Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 06:47 PM |
Why doesn't traction/stability control actually turn off? | Ganthrithor | BRZ First-Gen (2012+) -- General Topics | 84 | 09-13-2015 01:37 PM |
