Old 10-05-2016, 09:57 AM   #211
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
yeah, you might wanna run some basic diagnostics... there's a serious issue there unless you've managed to mount a stock 17" wheel as your pulley on you C38
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 10-07-2016, 08:53 PM   #212
Dru670
Drives: 2016 Scion FR-S
Originally Posted by VABeachBRZ View Post
That seems a little low to me. What fuel type
91 oct and I live in Vegas and was told we have shitty gas. Only fuel up at Chevron and Shell. Been given 2 other tune revisions since the last dyno. Can't wait to get it on the Dyno again and see what's up.
Dru670 is offline   Reply With Quote
Old 10-07-2016, 09:02 PM   #213
Dru670
Lol
Old 03-30-2018, 10:32 PM   #214
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
I hate to thread jack, but this thread seems dead anyways. Can anybody provide evidence that running the HBP with the C38 setup on a stock engine is reliable and safe? It seems with E85 this shouldn't be a problem, but how about on 93?
Thanks!
majixmatrix is offline   Reply With Quote
Old 04-02-2018, 04:59 PM   #215
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Thanks!
As long as it has a reliable tune, it will be reliable.
JDMChris is offline   Reply With Quote
Old 04-02-2018, 08:01 PM   #216
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Thanks!
It may be negligibly different than a LBP. Take TJ Hunt’s car. The car made like 10whp more with a HBP on 91 with like 10 extra psi. I don’t know if he went with a lower compression built motor, so that could be a difference besides a conservative tune, or if he did a super conservative tune, but I doubt there is much overhead for a more aggressive tune.
In terms of hp, a HBP will do very little to put extra forces on the motor, but it could be less reliable because there may be more heat generated, and more extreme to how much timing is pulled, etc that may prove less efficient or be stressful on the motor in other ways. I’m not sure if the motor has a max that it will retard timing, such that, there could be a problem for the motor if weather, heat, bad fuel, or whatever the situation would dictate that the motor would need to retard timing only to already be at its max; that could be bad.
Old 04-07-2018, 02:25 PM   #217
majixmatrix
BRZ Wannabee
Max C38 Potential?
Thanks for the input! It seems the main concern is proper cooling, and I would honestly feel safe with a stock block on E85 up to redline with the C38 and HBP considering my car is currently my A to B daily with occasional AutoX.
I'm very interested however in the peak power potential from the C38 kit. Does a 90mm pulley exist? Previously in this thread some maths were done to determine that a 100mm pulley could not be used up to 9K RPM, but if you built the block and tossed in some stiffer valve springs, wouldn't it make sense to rev up to ~8K RPM? This would still leave some headroom/potential for the listed max RPM of the C38 (which already has a safety factor built in I assume?)
8,000 (RPM) X 1.419 X 7.5 = 85,140 (C38 RPM)
The fantasy of using up the room on the stock RPM gauge kiiiiinda turns me on. It's their fault for putting 9K RPM on there!! Teases...
9000x1.29x7.5 = 87075
9000x1.419x7.5 = 95782
Not enough for the 100mm pulley
Old 04-07-2018, 09:15 PM   #218
CSG Mike
CSG Mike's Avatar
It sure does!
https://www.counterspacegarage.com/jr-rs-gt86
CxG (04-13-2018)
Old 04-07-2018, 10:04 PM   #219
majixmatrix
BRZ Wannabee
Old 04-19-2018, 09:01 PM   #220
stlgrym3
which kit is more reliable pairing with stock engine and its components? c30 or c38? what is CARB tuned anyway? is that another custom tune? i'm really interested in getting JRSC in the near future.
stlgrym3 is offline   Reply With Quote
Old 04-19-2018, 09:11 PM   #221
CSG Mike
CSG Mike's Avatar
Equally reliable.
CARB tune is the california legal calibration which is what you need to keep your car 50 state legal, with forced induction.
Old 04-19-2018, 09:17 PM   #222
stlgrym3
Equally reliable.
is CARB tune another ECU flash similar to the jackson racing Ecutek tune tuner shop puts out? but instead of help the performance it helps your car passes SMOG check?
Old 04-19-2018, 09:43 PM   #223
CSG Mike
CSG Mike's Avatar
It is the proper calibration for the supercharger, as provided by Jackson Racing, that also allows your car to pass smog checks.
Old 05-01-2018, 03:11 PM   #224
Rederick
Drives: 2017 BRZ PP, 88 Yota 4x4 SC'd
Any reason this kit wont work on the 2017s? Also if the user has their own ECUTEK cable and license, is it possible to get just a tune sent for the CA 50 state?
Rederick is offline   Reply With Quote
FS Bay Area: 2013 Subaru BRZ-L SWP 6MT - Jackson Racing Supercharger - 50 state legal spitz Cars for Sale/Trade 3 02-04-2016 11:59 PM
Jackson Racing CARB supercharger+oil cooler LA blahblah Engine, Exhaust, Bolt-Ons 9 12-30-2015 12:33 AM
(SOLD) 2014 Scion FRS (w/Jackson Racing SC - CARB Legal) - $25,000 - Irvine, CA *LongFella Cars for Sale/Trade 27 04-11-2015 12:35 PM
Best CARB legal SC kit? Jackson? Oem reliable block rebuild? Cayman killer? Yui-Chan Forced Induction 179 03-04-2015 07:50 PM
