Old 11-12-2017, 11:41 AM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
Racecomp Engineering Tarmac 2 coilovers. $1,500
These are in very good condition and have about 24,000 miles on them. I have been using them with RCE street camber plates, but they are also compatible with OEM tophats.
One of the rear shafts is slightly shorter than the other. It was damaged and professionally repaired/machined. This has absolutely zero impact on performance and has caused me no problems. There is one small downside to this, though: when adjusting the rear shocks one needs to use an allen wrench instead of the supplied knob, as it takes a little more reach than what the knob provides. I've been using them like this for a while without issue, but want to ensure whoever ends up with these has a good buying experience and there are no surprises.
$1,500 plus shipping from Denver (80126).
Pat is offline
The Following User Says Thank You to Pat For This Useful Post:
idkwhatimdoing (02-28-2018)
Old 01-07-2018, 06:10 PM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Highly-regarded T2s still for sale in excellent condition.
Pat is offline
Old 02-27-2018, 05:03 PM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
Still available.
Pat is offline
Old 03-29-2018, 04:38 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
Anyone?
Pat is offline
Old 04-07-2018, 02:25 PM   #5
Ry.ruzn
Ry.ruzn's Avatar
Originally Posted by Pat View Post
Anyone?
PM me price for shipping to 19403. Might be able to work something out as I need to replace my coils from a hydroplane. Look forward to hearing from you.
Ry.ruzn is offline
Old 04-07-2018, 06:10 PM   #6
redlined600
redlined600's Avatar
Drives: Fr-s
Free bump. I can't believe these are still for sale, good deal!
redlined600 is offline
The Following User Says Thank You to redlined600 For This Useful Post:
Pat (04-08-2018)
Old 04-08-2018, 01:53 PM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
That's what I thought. I'm a bit surprised I still have them.
Sent from my SM-G950U using Tapatalk
Pat is offline
Old 04-17-2018, 06:32 PM   #8
Pat
Pat's Avatar
Drives: 2023 BRZ
TTT
Pat is offline
Old 04-17-2018, 09:13 PM   #9
i8ur911
Drives: 17 BRZ Series.Yellow
What spring rates are these (400/400, 500/500 or 600/600)? Can you explain more about the repaired damper?
Sent from my Pixel using Tapatalk
i8ur911 is offline
Old 04-18-2018, 10:35 AM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
The springs are the standard 400 at all four corners. The repaired damper was damaged during initial installation. It was over-torqued and damaged about six threads up the threaded section. It was professionally repaired and has not been a problem since.
Pat is offline
Old 04-18-2018, 09:29 PM   #11
i8ur911
Thanks for the info and explanation.
Trying to figure out how the "shortened" damper effects things........
Zooming in to the photo you can see the height difference. Trying to wrap my head around what that would do "in the car"....??? My original thought is changes the overall stroke (compression and rebound), changes the stack height and changes the helper spring height? Not a suspension guru, but seriously considering these and just running everything out.
Thoughts?
i8ur911 is offline
Old 04-19-2018, 12:04 AM   #12
Robbie
In the slipstream
Thoughts?
The damper is the same length. The stud is shorter. That’s all. The coil overs work great. I sold them to Pat and did the fix. It’s solid.
Robbie is offline
The Following User Says Thank You to Robbie For This Useful Post:
Pat (04-19-2018)
Old 04-19-2018, 06:56 PM   #13
i8ur911
Thanks for chiming in Robbie! Much appreciated.
i8ur911 is offline
Old 06-05-2018, 12:16 PM   #14
Pat
Pat's Avatar
Drives: 2023 BRZ
Still available.
Pat is offline
FS: Racecomp Engineering Tarmac Zero coilovers, standard & Swift springs NLSP Canada Classifieds 39 09-17-2016 11:44 PM
FS: Racecomp Engineering Tarmac Zero coilovers, standard & Swift springs NLSP Brakes, Suspension, Chassis 14 09-17-2016 11:44 PM
Racecomp Engineering Tarmac Zero jason t Brakes, Suspension, Chassis 0 03-03-2015 11:16 AM
Racecomp Engineering Tarmac 3 Clubsport Coilovers (3 way damping adjustable) Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 12-11-2014 11:56 PM
RaceComp Engineering Tarmac Zero coilovers jack43 Brakes, Suspension, Chassis 5 10-03-2014 04:17 PM
