Old 07-10-2012, 08:04 PM   #43
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by cobrabyte View Post
Thanks for reminding me about the Fumoto valve. I had one on my Elise and, especially for that car, it makes oil changes soooo much easier. Ordered!
I suggest you setup an Amazon Associates account and link to the Amazon product page. That way you can earn a little cash on an excellent recommendation!
You're welcome.
The Amazon thing is an interesting idea, but I don't feel it's appropriate. I give advice because I want to contribute to the community. So I wouldn't feel right using links that I would profit from.
The Following 3 Users Say Thank You to Draco-REX For This Useful Post:
iBRZ (11-26-2012), Sportsguy83 (07-10-2012), zoomzoomers (09-13-2012)
Old 07-10-2012, 08:37 PM   #44
b1pkkf26
Drives: 2005 civic, FR-S
I have a dumb question, the manual stats 5.2 liter and I just did a oil change. I fill it up 4.4 liters and ran it for a few min. The dipstick shows full, should I top it off? I did buy a extra 1 liter bottle just in case.
Thanks in advance.
b1pkkf26 is offline   Reply With Quote
Old 07-10-2012, 08:41 PM   #45
Draco-REX
Corner Junkie
Draco-REX's Avatar
Thanks in advance.
Monitor your oil level when you fill up. Take the level after pumping gas to make sure you have as much in the sump as possible.
Old 07-10-2012, 09:33 PM   #46
b1pkkf26
Thanks for your reply, I did drive it for a few km to pick up grocery and recheck it. It still shows full, will check it again on my next gas refill.
One last question on the dipstick, im not really good at reading it, when I check the oil it does go pass the second dot till the end, so I should be good right?
Old 07-10-2012, 09:39 PM   #47
Draco-REX
Corner Junkie
Draco-REX's Avatar
Thanks for your reply, I did drive it for a few km to pick up grocery and recheck it. It still shows full, will check it again on mg next gas refill.
One last question on the dipstick, Blythe really good at reading it, when I check it the oil does go pass the second dot till the end, so I should be good right?
Correct. The range between the dots is 1L with the top dot being full.
Old 07-10-2012, 10:05 PM   #48
b1pkkf26
Sweet, thanks again.
Old 07-17-2012, 04:25 PM   #49
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Thanks again for the thread. I've picked up that drip pan and jug. Wish I had the drip pan during the last oil change...had a bit of a mishap and still have some cat litter on the garage floor to help with the spill hah.
So is there any consensus on whether the regular Fumoto F-108 or the F-108S is the better option?
Phaedrus29 is offline   Reply With Quote
Old 07-17-2012, 04:52 PM   #50
Mr. Mcoupe
Mr. Mcoupe's Avatar
Drives: ExigeS,M3,S2k,MCpe,MR2T,T4R,Sienna
I have used this Low Profile Oil and Fluid Receiver to much success.
http://www.griotsgarage.com/product/...ortby=ourPicks
Current: 19 GT-R[]17 M2[]17 WRX[]14 T4R[]12 NV2500[]07 Exige S[]07 S2k[]05 M3[]03 M3[]02 MCoupe[]94 MR2T[]93 MR2 T[]92 MR2 T[]91 MR2 T[]95 SC400[]
Gone but not forgotten: 04 STI[]05 MR2 Spyder[]04 S2k[]03 IS300[]90 MR2[]
Mr. Mcoupe is offline   Reply With Quote
Old 07-18-2012, 07:23 PM   #51
wrxneffect
wrxneffect's Avatar
Drives: 13 BRZ Ltd 6MT(sold), 03 WRX (RIP)
I bought a F-108 valve for my BRZ and installed it during my first oil change. I didn't go with the N or S as I don't usually attach a hose to drain the oil. On my WRX I also had the Fumoto valve with out the nipple as well. I think which one you get will be a matter of personal preference.
Last edited by wrxneffect; 07-18-2012 at 07:25 PM. Reason: Found out what the S desgination was
wrxneffect is offline   Reply With Quote
Old 07-22-2012, 10:35 AM   #52
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Filter magnet: Not really an oil *change* item, but something that can prolong the life of your engine. It's a powerful magnet that attaches to the side of your filter. It will attract metal particles and hold them to the side of the filter. Because it's magnetic and not another filter, it can attract and hold particles below the filter's threshold (20 microns usually). Those using the Subaru 130 filters (Purlator PL14459) will want the FilterMag SS300, and those using the Subaru 160 filters or the Purolator PL14612/610 on their other Subarus will want the FilterMag SS250. These have much more surface area to grab particles than a magnetic drain plug, and will see every drop of oil that runs through the engine. Oil flows from outside the filter media to the center of the filter and out the large hole in the middle. So these will capture metal before it reaches the filter media.
Do both FilterMAGs fit the initial filter?
kwood9000 is offline   Reply With Quote
Old 07-22-2012, 10:40 AM   #53
Draco-REX
Corner Junkie
Draco-REX's Avatar
The initial filter is the larger 130.
The Following User Says Thank You to Draco-REX For This Useful Post:
kwood9000 (07-22-2012)
Old 07-22-2012, 10:45 AM   #54
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
Just wanted to thank you for this thread - it made shopping for my first oil change super easy
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
Old 07-22-2012, 12:37 PM   #55
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Would you suggest using the smaller one after the initial one?
Memphis is offline   Reply With Quote
Old 07-22-2012, 12:45 PM   #56
Memphis
Memphis's Avatar
F108S: Oil Drain Valve with Short Nipple (16mm-1.5): I got this one before I saw your post. Is that ok?
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
