#15 |
Drives: Toyota 86 GT
I finally got around to going for a decent drive with the Whiteline gear installed.
When you push hard in the standard car the suspension and tyre run out of talent at roughly the same time. The front outer tyre loads up and starts to scrub as the shocks compress and sit on the bump stops. With the front and rear bars set in their neutral positions the spring rates are effectively increased. This, with the increased castor and neg camber increases the limits of what the suspension can handle. Cornering speed is increased and now the main limiting factor is the tyres. Once I get wider stickier tyres I can harden both the front and rear bars because they're adjustable ![]() In terms of normal driving there isn't a noticeable increase in road noise from the stiffer strut tops. The suspension does feel stiffer over bumps but it still remains composed. It's definitely upgrades I'll be recommending to my customers. Rear bushes: ![]() Rear bar adjustment:
#16 |
Boostin'
Drives: FRS-T
So when are all the parts comming out?
#17 |
#18 |
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
awesome mate. watching this with a keen eye. so what exactly has your car had thrown at it at this point in time? id really like the methodically change suspension components that will improve handling rather than just throw parts at the car so your insights are helpful.
#19 | |
Current the 86 is fitted with 20mm front bar, 16mm rear bar, rear pineapples, front camber bolts and front strut tops. What I found interesting is that they are sure they can improve the handling even more. Hope they don't mind me mentioning it...but they're looking at making billet lower rear arms :-) |
#20 |
Attack By Demons
Drives: 2022 BRZ (pre ordered)
could you send me a price for those rear camber kit for the BRZ please when there for sale i'm very very interested!
#attackbydemons #imcomingbackbish
#21 | |
#22 | ||
The rear pineapples are inserts that fit into the standard subframe bushes. It's a cheap and easy way to stiffen up the rear end and stop it walking side to side.
explaining them.
#23 |
oh yeah thats what I thought, thanks for the video. Are they planning on doing anything like that for the front subframe or is it not as much of an issue? (thinking for people who dont necessarily want to drift).
#24 |
The front suspension attaches to a crossmember which is attached to the chassis, with no bushes between. But they will make a poly bush to replace the rubber front control arm bush. I'll let you know when it's available.
#25 | |
Drives: Blue BRZ
#26 | |
I would think if you lowered the subframe you would change the rear suspension geometry but not the ride height. Things like camber/caster change on bump. The height is determined mainly be the suspension uprights. Sure to be corrected if I'm wrong. |
| The Following User Says Thank You to 86drift For This Useful Post: | Ben_G (07-12-2012) |
#27 | |
Drives: Blue BRZ
Trying to scour the whiteline site now to see if they have anything about this.... EDIT - So after some quick searching, it seems that the consensus is that ride height doesn't change because the subframe is effectively "hung" from the chassis.... which i still can't picture in my mind, since I can only image that the body sits on the subframe.... either way, not a big deal.... Thanks for the quick response earlier.... Last edited by Ben_G; 07-12-2012 at 07:09 PM. |
#28 |
@Ben_G these inserts will not change the height of the subframe in relation to the chassis because the car has a floating rear subframe. basically a small steel insert in a large rubber bush but only the small insert meets with the body, not the bush itself. So effectively these inserts are bringing a larger surface area of at the mounting points into contact with the subframe which reduces wiggle. Its difficult to explain but i hope that makes it a bit easier to understand.
@86drift so the front crossmember is solid mounted to the chassis? How is it attached? |
| The Following User Says Thank You to spiller For This Useful Post: | Ben_G (07-12-2012) |
| Whiteline|Cusco|TEIN|Perrin|KW & More! All your suspension needs here @ CMS | Circuit Motorsports | Brakes, Suspension, Chassis | 64 | 12-18-2012 02:25 PM |
| Boston Motorsports: >>>Whiteline Suspension Components! | Boston Motorsports | Brakes, Suspension, Chassis | 6 | 07-24-2012 01:07 PM |
| Whiteline Sway Bar Links at Redline360 | Redline360 | Brakes, Suspension, Chassis | 0 | 06-28-2012 10:44 PM |
| Whiteline alignment products | Nardi330 | AUSTRALIA | 4 | 06-16-2012 03:25 AM |
