#15 |
Verus makes a ECU and fuel rail bracket cover that saves 5 pounds. Probably more than a cf hood would at 1/8th the price
#16 |
TRACKBREAD
carbon fiber hood vs carbon fiber trunk which saves more weight?
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Tcoat (04-13-2018) |
#17 | |
Little Member
Drives: Bloo - The 13' BRZ
| The Following User Says Thank You to yelsew For This Useful Post: | Tcoat (04-13-2018) |
#19 | |
I am just a bit dense.
#20 |
TRACKBREAD
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Tristor (04-18-2018) |
#21 |
So did I which was why I was baffled.
| The Following User Says Thank You to Tcoat For This Useful Post: | Tristor (04-18-2018) |
#22 |
Drives: 2014 Scion FRS (Asphalt)
You'd probably only see weight savings with dry carbon fiber hoods, such as the one from Amuse... but that costs $5k. Seibon has one too for close to $2k. Weight savings is roughly 5lbs from stock.
Wet carbon trunks generally do save more weight relative to a wet carbon hood... which like many others have stated weigh more.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | Tristor (04-18-2018) |
#23 |
The steering wheel actuator reduction does not work as good as the 170lb passenger delete mod!
| The Following 2 Users Say Thank You to Grady For This Useful Post: | Irace86.2.0 (04-19-2018), Tristor (04-18-2018) |
#24 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following User Says Thank You to MisterSheep For This Useful Post: | Tristor (04-18-2018) |
#26 |
Killed Scion
My stock trunk with Sard wing and oem carpet was 22lbs
#28 |
Drives: FR-S,GTI
You want to save weight? Go on a diet and drive around with less gas in the tank. And drain the windshield washer fluid.
Costs nothing. |
| Seibon Carbon Fiber OEM Hood Install w/ Weight Comparison and PICS! | TyperRspec789 | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 02-12-2023 05:15 AM |
| Seibon carbon fiber trunk or hood | Yes | Want-To-Buy Requests | 1 | 10-17-2017 03:07 PM |
| FS: Seibon CSL-Style Carbon Fiber Trunk Lid / Seibon VS Style Carbon Fiber Hood | FRSPhil | Exterior Parts (Aero, Lighting, Etc.) | 24 | 07-29-2015 12:31 PM |
| Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser | Mr.Frs | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 04-08-2015 10:51 AM |
| Carbon Fiber Hood/Trunk | lunchbox | BRZ First-Gen (2012+) — General Topics | 64 | 01-06-2012 11:03 AM |
