| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: 2013 frs red
I live in soflo and the difference in temp between morning and afternoon can be substantial. E85 seems to soften the blow somewhat but I can still feel the difference.
#16 |
Its a lot more and maybe since this is the smallest engine I have ever owned I never experienced such an impact on the other cars I have had.
#17 |
I am going to check my filter and make sure its still fine. I was asking to make sure no one else has experienced this issue and maybe there was something more specific causing it.
#18 |
The Dictater
Drives: '13 Red Scion FRS
+1 for heat and humidity. I feel the same thing in the summer.
#19 |
I do as well. Both days.
| The Following User Says Thank You to Tcoat For This Useful Post: | Yoshoobaroo (04-12-2018) |
#20 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
Unfortunately there could be a dozen different reasons why a car feels off on any given day. Weather is certainly a factor, as many have mentioned, and probably the most easily forgotten one. There's also your air filter, fuel filter, or any other number of consumable things involved in your running process. You could get as many different answers as people you ask. My thoughts went to possibly getting a bad batch of fuel, which is always a possibility even from known brands that are supposed to be higher quality. And there's no remedy for that except to run through the tank and hope the next fill isn't the same or worse.
As long as it's not a gross loss of pep, I wouldn't sweat it or think the car's getting old already at 30k. Heck, @Tcoat is in the six-figure mileage club and (I think?) still even on his original spark plugs.
-O/D
2016 FR-S, Hot Lava |
#21 | |
I have the TRD drop in filter and clean it about every two months or so. It has been almost plugged solid on occasion and I really hadn't noticed any serious drop in power. Maybe just a slight reduction in throttle response but nothing that worried me enough to check earlier than I had planned. These cars are so tightly monitored that I would think any fuel filter issues would throw a CEL if it was enough to impact driving but since I have never seen a CEL for any reason on mine I can't be sure. A mildly bad batch of fuel could certainly be part of it and that issue I did have once. If that was the case though it would run the same all day and not well in the morning and worse in the afternoon. I know on the very rare occasions we get a really hot and humid day I can notice a slight decrease in "pep" but I have had that with other cars in the past so I was aware of what was going on. My old Talon TSi HATED hot humid weather and had a significant decrease in power whenever it went over 80 outside.
#22 |
I need to check my K&N filter. I have not cleaned it in a while.
#23 |
Drives: 2013 Scion FR-S Series 10
I'm in the camp of having noticed and been surprised by the difference of "pep" between temperatures and humidity. But I'm not sure I'd say there was ever much of a measurable difference in terms of acceleration.
Someone over on the MK6 GTi forums (when I had that car) posted dyno results from the same dynometer between a hot and humid day vs a cool day with almost no humidity. They found that the WHP changed nearly 30 hp. (the motor was said to actually produce up to 230 at the crank compared to the listed 200.) I can attest to how shit the car felt on 90+ degree days. So on cooler days you got the full 230-ish. So that sort of goes to show, at least in the case of a FI motor that requires lots of air volume, how weather can affect things. But density of air wouldn't be as important on an NA motor, and thus heat wouldn't play as big of a role, right? You put a new intake and filter on the GTI and you get 10 hp. On the FA-20 you get what, like 1 hp? |
| The Following User Says Thank You to mazeroni For This Useful Post: | sato (04-14-2018) |
#24 | |
The difference between changes those two car's intakes are the results of equipment efficiently not air density. The GTI intake sucks (or doesn't depending on how you use the word) so changing it has more impact than the Twins one which is simply better to start with.
#25 | |
#26 |
Drives: Dodge Patitas
One way or another, most of us have felt the difference in performance one day or another. Kinda reminded me that it's time to check my air intake filter.
Also, this is another fine example of threads which make me like this forum so much. I expected somebody reply to OP instructing just to slap a turbo on it, or blame the "torque dip". Instead, we got sensible, useful and palpable information re: GTI (despite no evidence was posted). Thanks for posting! |
| The Following User Says Thank You to sato For This Useful Post: | Tcoat (04-14-2018) |
#27 |
Drives: 2015 FR-S
I felt the same thing in Florida and being my 3rd year in to get a better feel for the car, I noticed it runs much stronger during winter here.
#28 |
Small displacement woes
| Car feels loose | Riftur | Off-Topic Lounge [WARNING: NO POLITICS] | 233 | 02-06-2018 10:27 AM |
| Am I the only one that feels bothered by this (R.S 1.0) | 1GiantTurtle | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 12-11-2014 09:18 PM |
| 18's or 19's ... What looks and feels best on FR-S. | Jon1084 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 65 | 07-19-2013 07:42 PM |
| Everything else feels like driving a bus! | BRZnut | BRZ First-Gen (2012+) — General Topics | 42 | 01-21-2013 09:30 PM |
| Feels like christmas! | yeabude | BRZ First-Gen (2012+) — General Topics | 3 | 06-11-2012 02:59 PM |
