Old 04-11-2018, 08:18 PM   #1
J41v33
Drives: fr-sexy
Unhappy open flash tablet overheating
(title correction: open flash tablet not turning on due to warm weather)
So Ive recently ran into a very annoying problem with my tablet.
I purchased my tablet during the winter, and its been pretty cold in California until recently. Its been 80+ degrees the past few days, and every time i get into my car to plug my tablet in, it goes into usb mode as if it was connected to a computer. This only happens when its over 80 degrees outside. It plugs in and turns on no problem in the morning before i go to work.
I'm guessing that the circuit board inside the tablet is warping in the warm temperature causing something to short and its causing the tablet to think its in usb mode. The only way to make it work is to cool the tablet down with my AC blasting for 15 minutes.
You would think that a tool used to tune a car and monitor a car would be able to withstand inside car temperatures.
I already contacted OFT on their new support site a couple days ago and haven't gotten a response. I've also contacted FT86speedfactory where i purchased it and they're trying to contact OFT as well since the last time I emailed OFT about something they never got back to me.
Does this happen to anyone else?
J41v33 is offline   Reply With Quote
Old 04-11-2018, 08:24 PM   #2
ATaraxias
Drives: 1994 Geo Metro Hatchback
Yes, my OFT flashes the following warning at me when it gets too hot.
ATaraxias is offline   Reply With Quote
The Following 2 Users Say Thank You to ATaraxias For This Useful Post:
BirdTRD (04-12-2018), SkyeHack (04-12-2018)
Old 04-11-2018, 08:40 PM   #3
J41v33
Drives: fr-sexy
No way! I never get that warning.
Old 04-11-2018, 08:47 PM   #4
ATaraxias
Have you found yourself granny-shifting or not double-clutching like you should be? Those are often related issues here.
Old 04-11-2018, 10:16 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Is that you ludwigmiles?
86geek (04-14-2018), BirdTRD (04-12-2018)
Old 04-11-2018, 10:52 PM   #6
Teseo
Drives: frs
I always leave my oft on the glove box and when use it for data logging i use a cellphone mount where is atached near of the AC vent
Old 04-12-2018, 06:09 AM   #7
J41v33
Drives: fr-sexy
I never double clutch, could that be the issue? Omg thanks for the help! I’ll go on YouTube right now and learn. Thanks!
Old 04-12-2018, 07:56 AM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Careful that 100 shot of NOS doesn't blow the welds on the intake.
Old 04-12-2018, 08:12 AM   #9
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Why don't you try Fat Burger from now on?
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
Yoshoobaroo (04-12-2018)
Old 04-12-2018, 08:51 AM   #10
Submarinesonce
Drives: Frs
mine stays in the glovebox unless its being used to flash or log
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 04-13-2018, 06:35 PM   #11
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Oft is a joke in my worthless opinion
mswbrz is offline   Reply With Quote
Old 04-13-2018, 07:12 PM   #12
Yoshoobaroo
TRACKBREAD
You're entitled to your opinion.
Doesn't change the fact that it's the only well supported open source tuning solution for this platform. The maps are well tested and the datalogging setup works well. That and it's 1/3 the price of this platform's default solution.
I trusted OFT to tune both my turbo BMWs, no reason why this application is any different.
Old 04-13-2018, 09:53 PM   #13
steve99
Drives: FT86
Most devices are manufactured in several temperature grades. Broadly accepted grades are:
  • Commercial: 0 ° to 70 °C
  • Industrial: -40 ° to 85 °C
  • Military: -55 ° to 125 °C
Leaving a electronic device in full sun in summer inside locked car is likely push the boundary on standard LCD screens
Typically, standard LCD character and graphics modules provide a temperature range of 0°C to +50°C. However, several display manufacturers offer extreme temperature models with operating temperatures of -40°C to +80 or +85°C.
https://www.digikey.com.au/en/articl...e-temperatures
Old 04-14-2018, 12:44 AM   #14
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Lmfao! Haven't heard that name in a long time!
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
oft, open flash tablet, overheating
My experience with Shiv & his products at Open Flash Tablet / Open Flash Header TouchMyHonda User/Vendor/Sponsor Reviews, Feedback, Comments 5 10-23-2015 10:57 AM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
