Old 12-31-2017, 07:27 PM   #743
arthur93
Drives: Toyota 86 GTS
Apologies if this is posted in the wrong thread but considering I have these wheels I believe it is relevant.
I am considering getting mud flaps now that I have the 17x9 +35 RPF1s. The two options I am considering are the OEM ones and rally armor. Two questions;
1. Those with OEM; is it providing enough protection; don't care about water and rain as that is not their purpose. Concerned about rocks.
2. Those with RA mud flaps; do you have any issues with clearance. For me, main concern is with speed bumps.
Check out my build: http://www.ft86club.com/forums/showthread.php?t=122736
Instagram: artym93
arthur93 is offline   Reply With Quote
Old 12-31-2017, 08:19 PM   #744
churchx
churchx's Avatar
Drives: 2014 GT86
2. You shouldn't have any clearance problem with either due geometrical clearance on speed bumps, it goes right after wheel after all. But i had some issues with RA when backing up or going over (for eg. parking) road kerb, as RA's metallic piece is below bumper line, and if you bend by it, there is chance to break out mounting bolts. They should have positioned it a bit higher, so that only bendable flap part is below bumper.
Old 12-31-2017, 08:41 PM   #745
arthur93
Thanks for the info. In regards to this metallic piece, I am gathering this should only be an issue of reversing as the force will be trying to pull it off the car. Am I correct with that assumption?
Instagram: artym93
Old 01-01-2018, 07:06 PM   #746
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
why are you using such huge tyres btw?
Surok is offline   Reply With Quote
Old 01-01-2018, 07:14 PM   #747
arthur93
I don't think they are that huge. Most run a 40 profile on a 17" with 245 width. Adds an extra 12mm sidewall and about 24mm to overall diameter.
Reason being;
1. Increased ground clearance; I am running a splitter that sticks out quite a bit. On stock wheels and tyres from time to time scrapped a bit, but now I haven't had any issues
2. Wanted to fill the gap between tyre and wheel arch without dropping the height too much
3. Love chucky sidewalls!!
4. Speedo as 100km/h was over stated by 5km/h. Going to a bigger diameter reduces this difference.
Instagram: artym93
The Following 2 Users Say Thank You to arthur93 For This Useful Post:
Surok (01-01-2018), Wise (01-07-2018)
Old 01-07-2018, 01:32 AM   #748
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I'm running the OEM mudguards and I find them fine for deflecting road crud and rocks from hitting the door and side of the car.
Wise is offline   Reply With Quote
The Following User Says Thank You to Wise For This Useful Post:
arthur93 (01-07-2018)
Old 03-21-2018, 12:32 AM   #749
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
So I've read most of this thread. I'm going to get some 17x9s et35 with 245/40 or 255/40 autocross tires (e.g. RE71R or similar).
The reason I'm going with this size is because I'm going with a supercharger soon and want the extra tire. However, I don't want to be forced into coilovers yet (eventually I'll go there). Am thinking of going with lowering springs as a stopgap.
I definitely want to dial in as much negative camber as I can with bolts (hopefully close to 2 degrees). My question is, would it be a bad idea to go with 255 in terms of rubbing? It seems lots of people run 245s on the stock strut with lowering springs and camber bolts, but couldn't find many people running 255 lowered on stock struts.
Also, and I correct in saying that there wouldn't be any issues with 245 or 255 on 100% stock suspension?
BR-ZED is offline   Reply With Quote
Old 03-21-2018, 03:54 AM   #750
carlovestela
Drives: 2015 Firestorm FRS
Yes. They said it will fit stock suspension.
Ill do 245/40/17 with 17x9+38.
Maybe -1.5 or -1 camber on front
And no camber bolts.
Stock suspension with trd springs
carlovestela is offline   Reply With Quote
Old 04-05-2018, 10:42 PM   #751
BR-ZED
BR-ZED's Avatar
Noticing that there is some misinformation out there.
I thought the 17x9 et 35 RPF1s were 16 lbs.
But Subispeed/FT86SF says they are 18 lbs
http://www.subispeed.com/enkei-rpf1-...6#.WsbcUojwZPY
Oakos says 15.65 lbs
https://www.oakos.com/ENK-379-790-8035GG.htm
Enkei doesn't list it
http://enkei.com/wp-content/uploads/2015/07/RPF1.pdf
Which one is it?
Old 04-05-2018, 11:22 PM   #752
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
Which one is it?
Hmmm. Maybe something about the discontinued ones made them heavier? Or their scale was off. :-P
http://www.ft86speedfactory.com/enke...l#.WsblXR5Okoc
Look at the scale in the photo in the link. 15.95 lbs.
I dunno...
Sent from my P008 using Tapatalk
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
The Following User Says Thank You to coryandy For This Useful Post:
BR-ZED (04-06-2018)
Old 04-11-2018, 02:44 PM   #753
pedroFRS
Drives: 2016 SCION FRS
Originally Posted by kimchangil424 View Post
Another pic
Is that a square setup (17x9 +35 all around)? That looks great and I don't see any poking on the front (at least on this picture). What size are the tires?
pedroFRS is offline   Reply With Quote
Old 04-11-2018, 03:18 PM   #754
pedroFRS
Originally Posted by octavio.molina.1985 View Post
Attachment 89391n
Just got mines installed last week. 17x8.0 and 17x9.0 (rear) . The wheels don't poke out and don't rub either. Ride feels awesome !
What tires size are you running?
Old 04-12-2018, 11:36 PM   #755
Wise
Circle Work Clerk
Anyone know if there are any new options for Big Brake kits besides the AP Racing Sprint?
I remember reading a few years back that the AP was the only kit that fit and even then it only had about 2mm clearance.
kevaughan (04-11-2022)
Old 04-14-2018, 07:00 AM   #756
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
The narrow Wilwoods fit too.
SUB-FT86 is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
