| Software Tuning Discuss all software tuning topics. |
Stalling at idle after startup (see logs)
I've been having an issue with the car stalling at idle shortly after startup, but it seems to only happen during warm startups. If the car has not been started for a few hours and is cold, then startup and idle is fine.
I've made 2 EcuTek logs .csv, so can someone check those and provide an insight as to why this might be happening? Also, very rarely does is save itself from stalling and if I rev the car a few times is seems to then idle normal without stalling. - RaceROM version: 24256
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock Last edited by Eazy-V; 04-03-2018 at 05:52 AM. Reason: Adding more details |
#2 |
Drives: brz 2017 hksv2
Much better if you upload your logs on Datazap.me
so everyone can see them Can t really help you, anyway I see a huge heat soak... coolant more than 100°C , air intake more than 60°C... really rich afr too did you run you car hard and then suddenly turned it off? maybe your tune doesnt run the radiator fan in a efficient way for your turbo mods.... Last edited by tomm.brz; 04-03-2018 at 06:08 AM. |
#3 |
Drives: 2013 Asphalt FRS
Who tuned the car
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#4 |
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock |
#5 | |
#6 |
The easy fix is call delicious tuning and order a tune. they are spot on.. but most likely the tuner who tuned your car did not sync the di with the pi they HAVE TO BE calibrated together.......
#7 |
Thanks for the info, so what that affect cold start? The issue doesn’t occur on cold start and only warm start.
#8 |
Drives: FT86
Have a look at the maf offset after start tables
| The Following 3 Users Say Thank You to steve99 For This Useful Post: |
#9 |
Steve is on to something also that could cause the issue. The reason the inj have to be syncd is when it switches between the pi/di the transition has to be smooth. if you have the scaling off one will be dropping a measured amount then switch to a different amout and the ecu/motor cant understand whats happening try to compensate and stall
| The Following User Says Thank You to FRS Justin For This Useful Post: | Eazy-V (04-08-2018) |
#10 |
Thanks for the info, will look into those.
I want to add that if I rev the car/save it from stalling 3-5 times, it will then not stall again for that drive cycle. Also, I have a ACT prolite flywheel, so not sure if that is affecting it since I can’t remember when the issue first arose.
#11 | |
Drives: FT86
get the car going and let it idle for a few minutes Check the AFR should be around 14.7 Check Long term Fuel trims if not disables should be below 10% Check idle vacuum should be around -20inHg or -9 psi If trims way high or idle vacuum low then you likely got intake or exhaust leak Check catch cans , brake booster, pcv valves , bov and all vaccumm lines and the evap purge solenoid |
#12 | |
#13 |
The plot thickens...
When I was testing WOT it would bog down like a fuel or boost cut at 10-11psi. I tried it again and same thing. No CEL or error codes during this, but I do get random Too Rich Left Bank 1 code P0172 when car dies during idling. The boost controller settings are the same since last Dec which have boost cut off at 13.5psi and I tried raising that to 17psi too. Now, here’s what makes this even more weird, the issue above only started after I replaced a dying battery a week ago, but the idle stall issue was occurring for a while.
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock Last edited by Eazy-V; 04-08-2018 at 10:57 PM. Reason: Correction |
#14 |
Huge E85 fan!
Drives: 2016 Scion FRS
what injectors are you running?
| Automatic Frs stalling | Abe1120 | Issues | Warranty | Recalls / TSB | 44 | 09-11-2020 07:35 AM |
| OFT Stage 2 UEL Help. Rough Idle Stalling | shellslinger | Software Tuning | 11 | 03-05-2017 09:33 AM |
| Bad Idle, stalling, clutch chatter, gear lockout, failed clutches: My story and fix | Pneub | Engine, Exhaust, Transmission | 11 | 08-05-2016 10:29 AM |
| Stalling, Misfiring, poor idle.. Car is at Toyota, hopefully some results soon | WTF | Issues | Warranty | Recalls / TSB | 12 | 06-14-2014 10:40 PM |
| Not stalling? | grgonium | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 11-17-2012 10:26 AM |
