Old 04-07-2018, 09:40 PM   #295
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
I'm going to do some datalogging in the next couple of days to take a look at AFR vs Commanded AFR. Been doing some WOT runs with IAM at 1 and rarely ever get any FLKC, and if I do it's been -.65 for a split second but not enough to lower IAM. Top end feels stronger than the previous V2 tune I was running. Using 93 Octane. Loving the V4!
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 04-08-2018, 08:50 PM   #296
Firecruiser
Drives: 2014 brz
Is there a reason that the new tunes have all of the camshaft/crankshaft position codes disabled? I see it is also disabled in the v2 A01I based tunes but not in the v2 B01D tunes.
Firecruiser is offline   Reply With Quote
The Following User Says Thank You to Firecruiser For This Useful Post:
Somerandom18 (04-08-2018)
Old 04-08-2018, 11:25 PM   #297
Somerandom18
Drives: 2017 manual BRZ
Also curious. My guess was they add enough timing to trigger a CEL but who knows.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 04-09-2018, 02:42 PM   #298
elBarto
elBarto's Avatar
Drives: Toyota GT86
Those are disable in a stock A01I rom, since the V4 tunes are based upon Euro/Aus Rom's they are disabled with the V4 US versions as well. (AT = A01I , MT = A01G).
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 04-10-2018, 01:00 PM   #299
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Can they be added back on the user side? Would we even want to mess with it? I know the camshaft position sensor can be a problem with early zenkis
Old 04-10-2018, 03:04 PM   #300
stlgrym3
Just flashed to v4.03 Stage2+ after installed Tomei EL header yesterday. So far so good, knock on woood X 3. Haven’t been on open road yet thanks to weekday LA traffic, but the car definitely feels quicker off the line, and even without UEL’s Subaru rumble, it sounds so nice pairing with my Greddy SP catback. Big props to Shiv for releasing v4.03 which now supports 2017 AT.
stlgrym3 is offline   Reply With Quote
Old 04-10-2018, 03:27 PM   #301
sandy s
Drives: 86 gt
O K It looks like these new tunes will only work on US cars.Is that correct??? Can I do anything to download them on a new in Japan car??
sandy s is offline   Reply With Quote
Old 04-10-2018, 03:46 PM   #302
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Working on re-scaling the MAF for a Perrin intake for the Stage 2+ E85 tune, is there any easier way to copy & paste all the values? I feel like I'm missing something, the copy/paste function is not working inside ROM Raider and going one by one is not, uhh, ideal.
Lincoln Logs is offline   Reply With Quote
Old 04-10-2018, 05:43 PM   #303
elBarto
elBarto's Avatar
Drives: Toyota GT86
Can't see why not. Just put them in 'On'.
The Following User Says Thank You to elBarto For This Useful Post:
finch1750 (04-10-2018)
Old 04-10-2018, 05:45 PM   #304
elBarto
elBarto's Avatar
Drives: Toyota GT86
Open your rom, open the V4 rom and copy paste the following tables:
Originally Posted by Kodename47 View Post
Just so the info is here as well.
The Stage 1 MT has 10 changed tables:
2x MAF Correction After Start (Cold Start Adjust)
5x Idle Speed Changes (Cold Start Adjust)
Target Throttle Plate Angle (Only changed above 6400)
Ignition Timing Post Start (Cold Start Adjust)
P0420 Code is disabled
The Stage 2 has, in addition:
Open Loop Fueling (Richer at high load low RPM, Leaner at high load high RPM)
LTFT Limits (Reduced to +/-2%)
Base Timing B (Less Timing at high load high RPM)
Knock Correction Advance (More Timing at high load high RPM)
Timing Comps Per Cylinder A & B (Now all 0)
FBKC Range (Enabled now set above 3k RPM)
Intake and Exhaust AVCS Changes
The AT is pretty much the same as the above, just no P420 defined and P0700 code is disabled.
Save and flash
Old 04-10-2018, 05:56 PM   #305
nocoolname
Defs are different so you can't open both tunes at the same time. I just copied from my original tune into excel, changed defs and opened the v4 file. Checked the table to make sure it looked right then copied and pasted from excel.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 04-10-2018, 06:47 PM   #306
Jasonb
Drives: 17 Series Yellow BRZ
My guess is because of the cold start delete.
Jasonb is offline   Reply With Quote
The Following User Says Thank You to Jasonb For This Useful Post:
finch1750 (04-11-2018)
Old 04-10-2018, 09:45 PM   #307
John27
Drives: scion fr-s
when i start car in morning sometimes when putting the car reverse rev start to flux between 1k-700 any one else have this problem but after one min the car goes to normal and have no problem with car ?
John27 is offline   Reply With Quote
Old 04-10-2018, 09:56 PM   #308
N_AL_spyder
Drives: 2013 10-series, 2004 MR-2
I've seen the same thing, but it happened after warm and hot start for me.
Sent from my SAMSUNG-SM-J120A using Tapatalk
N_AL_spyder is offline   Reply With Quote
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
