Old 04-06-2018, 12:43 AM   #1
iceblaze
Drives: 2014 Scion FRS MT,2017 Toyota 86 AT
Slight front wheel bounce on sharp right turn?
Hey all,
I have a 2017 Toyota 86 with Tein Flex Z coilovers, Perrin endlinks, and TRD sway bars. I've also had my cars corner balance/alignment/suspension adjusted professionally. It is lowered a bit. However, I've notice that on some sharp right turns which have a slight bit of downhill grade, my front passenger wheel/suspension feels like it bounces or lumpy once or twice before it corrects itself. It happens whether I accelerate into the corner or not. Does anyone possibly know what this could be/how to correct? Perhaps its just the road thats bad or uneven? Thanks
iceblaze is offline   Reply With Quote
Old 04-06-2018, 12:56 AM   #2
Originally Posted by iceblaze View Post
Hey all,
I have a 2017 Toyota 86 with Tein Flex Z coilovers, Perrin endlinks, and TRD sway bars. I've also had my cars corner balance/alignment/suspension adjusted professionally. However, I've notice that on some sharp right turns which have a slight bit of downhill grade, my front passenger wheel/suspension feels like it bounces or lumpy once or twice before it corrects itself. It happens whether I accelerate into the corner or not. Does anyone possibly know what this could be/how to correct? Perhaps its just the road thats bad or uneven? Thanks
That would be my guess .......
Old 04-06-2018, 05:23 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
How much camber?
I've noticed some odd feelings while turning over uneven roads at slow speeds when you start running more than about -2 degrees up front.
ineedyourdiddly
iceblaze (04-08-2018)
Old 04-08-2018, 12:42 PM   #4
iceblaze
How much camber?
Good call.. I'm -1 degrees.. That may have something to do with it, along with the uneven-ness
Old 04-08-2018, 09:54 PM   #5
strat61caster
Nah I'm with hmfrz, you stiffened the cars suspension up quite a bit, more feedback from the road now
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
humfrz (04-09-2018), wparsons (04-08-2018)
Old 04-09-2018, 11:19 AM   #6
Racecomp Engineering
If it bounces and oscillates excessively after a bump, that means it needs more damping. The inside (unloaded) wheel should be able to handle a bump without bouncing excessively. Depending on your coilovers, just a few clicks stiffer might do it, but this very much depends on your coilovers and how they adjust.
If setting your coilovers stiffer doesn't help, or makes things worse enough in other ways (too harsh, compromised balance) then you may just have to take a different line through the corner.
- Andrew
iceblaze (04-09-2018), strat61caster (04-09-2018)
Old 04-09-2018, 12:43 PM   #7
norcalpb
norcalpb's Avatar
I would try your stock front endlinks again. My Perrin endlinks would bind all the time and it made me question why they put a bushing style endlinks on a rotating strut.
The Following User Says Thank You to norcalpb For This Useful Post:
iceblaze (04-10-2018)
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 06:47 PM
Help! Slight vertical bounce with new wheels/tires SilverTipp Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-06-2015 11:48 AM
Greddy SP Elite + EVS Evasive Motorsports Front Pipe = Slight Boxer Rumble sidnacious Engine, Exhaust, Transmission 22 07-30-2015 07:47 PM
Sharp grease lines Tiremonkey0824 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 09-24-2012 01:29 PM
