Old 04-06-2018, 12:46 PM   #281
My Key
My Key's Avatar
Drives: 2017 Toyota 86 - Raven
Originally Posted by elBarto View Post
It was pulled from the 4.02 update because the problem still isn't fixed.
Ahhhhhh.... That explains it. Thought I was taking crazy pills
Sent from my SM-G955U using Tapatalk
My Key is offline   Reply With Quote
Old 04-06-2018, 12:59 PM   #282
tomm.brz
Drives: brz 2017 hksv2
So I think I've found out why the V4 K00D tune didn't work:
K01E is an MT Rom.
So I've created a K00D rom based upon the V3 version for a member on the Facebook group (he also gave me the V3 tune + def's).
If anyone wants to be a guinea pig also, pm me.
If it works, I will put them up for download.
Can't test them myself since I have an Euro MT car.
Don t think the v3 are euro-based like the v4's so i dont know if it's good..
Old 04-06-2018, 01:34 PM   #283
elBarto
elBarto's Avatar
Drives: Toyota GT86
It's the changes of V4 copied to the V3 rom. The V3 rom is a real US AT rom
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 04-06-2018, 02:18 PM   #284
tomm.brz
ah ok i misunderstood what you wrote in the other post
Old 04-07-2018, 04:27 AM   #285
tha_alkaholiks
tha_alkaholiks's Avatar
Drives: DMG Subaru BRZ
Hey guys, I've got an Australian 2013 BRZ AT with a calid ZA1JA01I catless UEL
So I would use @steve99's OFT V4 Auto 2012-2016 base is A10I.xml
But which stage 2+ tune file do I use? Does it matter just as long as I use the right definition?
tha_alkaholiks is offline   Reply With Quote
Old 04-07-2018, 05:07 AM   #286
steve99
Drives: FT86
If you have oft is not going to work unlass you calid hack the roms
The xml is just a definiton ie index file not a tune file
If you pm me i can help you
Old 04-07-2018, 09:11 AM   #287
elBarto
elBarto's Avatar
Drives: Toyota GT86
I have the A01I V4 edition as well (I have most G and I Rom's with the V4 changes).
Old 04-07-2018, 11:39 AM   #288
John27
Drives: scion fr-s
is it normal for adv ignition to be at 0 when car start ? it take like 2 min so up to 10-12
John27 is offline   Reply With Quote
Old 04-07-2018, 03:58 PM   #289
redhalo
Drives: MY20 Hakone Toyota 86
I'm new to OFT so go easy on me. I tried to read my ecu and get "Error occured while reading data from ECU". I am able to read ecu info (K00D) and log data. Did I forget to do something? I realize for whatever reason there isn't a tune file for my ecu yet, but I haven't even been able to get that far.
redhalo is offline   Reply With Quote
Old 04-07-2018, 06:50 PM   #290
John27
Drives: scion fr-s
disconnect your battery for 15-20 min so you can reset your ecu
Old 04-07-2018, 06:53 PM   #291
N_AL_spyder
Drives: 2013 10-series, 2004 MR-2
So is the adv multiplier supposed to reset the 0.7 every time you start the car?
Sent from my SAMSUNG-SM-J120A using Tapatalk
N_AL_spyder is offline   Reply With Quote
Old 04-07-2018, 07:26 PM   #292
Jasonb
Drives: 17 Series Yellow BRZ
Yes. If you're running 93 100% of the time you can safely change it to .90, maybe 1.0 if you really want.
Jasonb is offline   Reply With Quote
Old 04-07-2018, 07:32 PM   #293
N_AL_spyder
I always run top tier 93. It seems to settle at 0.98 or 1.0, but it takes forever. I'll probably set it to 0.9 and test again.
Thanks.
Has anyone had hot-start erratic idle issues on the v4 tune? My cal ID is A01C.
Old 04-07-2018, 08:30 PM   #294
Jasonb
Thanks.
I have mine set at .9 on startup and it's usually at 1.00 within 2-3 minutes of driving.
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
