Old 04-06-2018, 05:13 AM   #1
adrianser
Drives: 2014 Monogram Series FRS
Tire Size Help!!!!!
I recently purchased some 18x9.5 +35 5x 100 rims and I don’t know what size tires to put on them, I want to look good and I’m also planning to lower my car about 1-3 inches. What tire size do you guys recommend?
adrianser is offline   Reply With Quote
Old 04-06-2018, 08:19 AM   #2
Cole
Not a troll
Cole's Avatar
275/50/19
Cole is offline   Reply With Quote
The Following 3 Users Say Thank You to Cole For This Useful Post:
bkharmony (04-06-2018), Leonardo (04-06-2018), Spuds (04-06-2018)
Old 04-06-2018, 09:38 AM   #3
Jordanwolf
Rice King
Jordanwolf's Avatar
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following User Says Thank You to Jordanwolf For This Useful Post:
Spuds (04-06-2018)
Old 04-06-2018, 09:43 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by Cole View Post
275/50/19
Old 04-06-2018, 09:43 AM   #5
Spuds
The Dictater
Spuds's Avatar
Originally Posted by Jordanwolf View Post
195/70/20
Old 04-06-2018, 09:48 AM   #6
Spuds
The Dictater
Spuds's Avatar
. There's a whole subforum and the answers you seek are there. Beauty is in the eye of the beholder, so don't ask others to tell you what looks good.
Old 04-06-2018, 12:30 PM   #7
Good day, adrianser .......
I see some of the guys were ah messen wich ya .....
The first thing I would suggest is to figure out what sized tires would comfortably fit your rims.
Then determine what type of tires you want (what you want the tires to do - DD, autocross, track).
I think you will find www.tirerack.com quite helpful.
Jordanwolf (04-06-2018)
Old 04-06-2018, 05:09 PM   #8
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
First of all, just recognize that while these rims will fit, they will actually slightly decrease the performance of the car due to weight, friction, contact pressure. That said, if that's the look you want, then go for it. Generally, for a 9.5" rim you want the tire width between 245 and 275. Smaller than that and stretch will not make a good seal and you don't need larger. Then you need to calculate the profile. You want a circumference of about 77.35". That would make a 245/35/18 a good fit. I would not suggest anything wider.
If you are also going to lower the car with that wide a tire, you may have some fender rub given the width and offset. There are some here with more experience with wide tires on the BRZ, and you'll have to ask them about it. You may need to roll the fender a bit with a large drop.
rvoll is offline   Reply With Quote
Old 04-06-2018, 05:27 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This is a good tool for determining tire size. What other mods on the car? That will effect tire fitment.
https://tiresize.com/comparison/
Old 04-06-2018, 05:52 PM   #10
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
tyler_win_photo is offline   Reply With Quote
rims, tire advice, tire size
Tire rack giving me a hard time on tire size, so please help! NOI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-03-2017 06:27 PM
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
Tire size help! brzee_vic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-09-2015 08:36 AM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 12:40 AM
225/35/18 Tire Size? stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-29-2013 08:09 PM
