Old 04-03-2018, 02:05 PM   #267
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
Originally Posted by Teseo View Post
Car will run smoothly, gas pedal will feel awkward at first unti you get used
Is there any way to get the throttle response to be a bit more sensitive again like the old v2 e85 tune? Can't stand how numb it is in the first 10% throttle now. When I had my v2 91 map it was always a little bland like this v4 e85 map, the v2 e85 was nice and snappy. We'll see what a few tanks of fuel does, usually takes a little time to see the full results
@steve99
cameronjones239 is offline   Reply With Quote
Old 04-03-2018, 02:15 PM   #268
Teseo
Drives: frs
@steve99
I did steve fast learning flash trick and still have that "lag" as you described. For me was the price to pay for get smooth rev engine. Also i noticed when shifting up or down the rev hang a litttle bit more than previous v2 tune so heel toe downshift is effortless. For me v4 tune is a grand slam
Old 04-03-2018, 04:37 PM   #269
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
my weird pedal went away after a day or 2. unless i got use to it
Old 04-03-2018, 08:00 PM   #270
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Might be updating from v2 sometime this month. Anyone know how up to date the definitions files are from openflash? I know the defs from openflash on v2 we're missing quite a few tables.
Old 04-03-2018, 10:54 PM   #271
Brzed85
Drives: Brz
You were right. Loving the beta tune! Haven't had any issues yet as far as CEL or rough idle.
Brzed85 is offline   Reply With Quote
Old 04-03-2018, 10:58 PM   #272
Decep
Drives: 2013 FR-S Series 10
Anyone get a rough idle on cold start for a few seconds? Has happened twice to me so far. Its rare but engine takes quite a few cranks to start and stumbles but runs normally after.
stage 1
Old 04-04-2018, 03:54 PM   #273
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Did 4.02 also fix the CEL for AT? Or do we still need to fix it ourselves?
Old 04-04-2018, 04:32 PM   #274
elBarto
elBarto's Avatar
Drives: Toyota GT86
So I think I've found out why the V4 K00D tune didn't work:
K01E is an MT Rom.
So I've created a K00D rom based upon the V3 version for a member on the Facebook group (he also gave me the V3 tune + def's).
If anyone wants to be a guinea pig also, pm me.
If it works, I will put them up for download.
Can't test them myself since I have an Euro MT car.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 04-04-2018, 05:22 PM   #275
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
I can't personally confirm as I don't have AT, but I downloaded the v4.02 tunes for my car and this fix is listed in the v4.02 release notes.
amaciose is offline   Reply With Quote
Old 04-05-2018, 05:01 AM   #276
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Do these maps benetif from the JDL header VVT tables?
Also curious about flexfuel V4.
Old 04-05-2018, 01:00 PM   #277
stlgrym3
I’m installing my catless header Monday, I’d do Stage2+ not Stage2 tune upgrade after the install even though my header isn’t OFH, correct? Stage2 is for catted, Stage2+ is for catless headers of any brand correct?
stlgrym3 is offline   Reply With Quote
Old 04-05-2018, 01:56 PM   #278
amaciose
amaciose's Avatar
Correct, you should start with Stage 2+ tune for catless headers.
I can't find the post right now, but I remember finding recommended modifications to the shelf tune if you're running something like a long tube header. I don't know if those were only recommended on the v2 tunes or if they still apply to the v4 tunes. @steve99 did you write that post?
Old 04-05-2018, 07:27 PM   #279
My Key
My Key's Avatar
Drives: 2017 Toyota 86 - Raven
I don't recall seeing the V4 K00D tune being part of the update???
didn't work:
K01E is an MT Rom.
My Key is offline   Reply With Quote
Old 04-06-2018, 12:36 PM   #280
elBarto
elBarto's Avatar
Drives: Toyota GT86
It was pulled from the 4.02 update because the problem still isn't fixed.
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
