Old 04-02-2018, 03:30 PM   #2759
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I did a track day a couple weeks ago and suddenly after I can hear the supercharger whine, whereas before it was almost silent. I've been running daily for almost 2 years now. Any thoughts?
B T is offline   Reply With Quote
Old 04-02-2018, 04:53 PM   #2760
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
So found out that most likely symptom for my situation of how I somehow lost power down to 235whp / 195wtq when I have:
- Edelbrock SC (3.00" Pulley)
- JDL 4-1 EL Header
- JDL 2.5" Overpipe
- Stock Front Pipe
- TRD CatBack
- DW 700cc Port Fuel Injectors
- Delicious Tune
Is because my cams are inactive when doing pulls. Is this a mechanical problem or can this be fixed with a tune?
Cuz I did a couple 0-60 times and these are my results. I'd say that 234whp / 195wtq on an AT, this sounds about right.
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 04-02-2018, 06:16 PM   #2761
gahooligan
Drives: 2017 BRZ Premium
Out of curiosity, how do your cams know they are on a dyno?
Sent from my SM-N950U using Tapatalk
gahooligan is offline   Reply With Quote
Old 04-02-2018, 06:52 PM   #2762
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Are you hearing the whining at idle? at a specific rpm or range of rpms? How much louder is it compared to before your track day? Maybe you can take a video?
It's hard to make an assessment since it can be anywhere from nothing to bearing failure.
http://www.thehighspeedlab.com/super...diagnosis.html
Old 04-02-2018, 09:25 PM   #2763
CSG Mike
CSG Mike's Avatar
- JDL 4-1 EL Header
- JDL 2.5" Overpipe
- Stock Front Pipe
- TRD CatBack
- Delicious Tune
Gotta let the cams activate first!
That being said, your dyno curve does not reflect that of a car without cam phasing. Got a log?
Old 04-03-2018, 02:49 PM   #2764
B T
The whine is more pronounced through the entire RPM range. It doesn't sound abnormal in nature just louder. I can hear it over my straight through uncatted exhaust. I'll try to get vids later, I'm out sick today.
Old 04-05-2018, 02:08 PM   #2765
StraightOuttaCanadaEh
Wes
So am I understanding this right.. if I already have ecutek on my car, I need to buy the version of the kit without the tune?
Instagram: @gt86ws
Old 04-05-2018, 02:45 PM   #2766
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
If you're going to a custom tune other than the CARB tune, then you'd buy the kit without the tune. Your current tune wouldn't be the right one to use I'm assuming, so you'll have to get a new one for the Edelbrock - either from them or someone else.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
StraightOuttaCanadaEh (04-05-2018)
Old 04-05-2018, 11:34 PM   #2767
CSG Mike
CSG Mike's Avatar
The tune is available for every owner. You'd be buying the kit "without tuner" as they put it, aka without ecutek.
StraightOuttaCanadaEh (04-06-2018), taiguy (04-06-2018)
Old 04-08-2018, 05:44 AM   #2768
AZ94
Drives: 2017 Toyota 86
Are there any updates regarding the release of the kit for the 2017+? I remember reading in this thread sometime last year that a kit for the 2017 cars was coming soon.
It's just that I will be in CA in a couple months or so near some of the reputable dealers/installers and I was hoping I could have the kit installed for the warranty...After that I probably won't be near any of the installers in the foreseeable future and I'd probably have to either do it myself or take it to a dealership or ASE tech who probably have less experience with superchargers than the installers.
AZ94 is offline   Reply With Quote
Old 04-08-2018, 09:48 AM   #2769
gtengr
Drives: 2017 BRZ
I haven't heard anything recently, and I've been waiting anxiously too. I assume they must be waiting on CARB approval or something because I don't think the hardware updates would have taken this long.
gtengr is offline   Reply With Quote
Old 04-08-2018, 10:26 AM   #2770
CSG Mike
CSG Mike's Avatar
We are still only being told "soon".
Old 04-10-2018, 06:45 PM   #2771
shr133
shr133's Avatar
Drives: 2013 FRS
- JDL 4-1 EL Header
- JDL 2.5" Overpipe
- Stock Front Pipe
- TRD CatBack
- Delicious Tune
Yeah you have to get up to temp first.....
Also that TRD exhaust will limit your power. It has a 2" section with a neck down to 1 3/4". Designed for a stock engine. I just replaced mine and was surprised how small it gets... Now I have full 2 1/2" all the way out.
You will need at least full 2 1/2" to to maximize the supercharger and the extra boost. Spend a little more and finish the exhaust...
Send delicious a data log to make sure every thing is cool.
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 04-11-2018, 05:13 PM   #2772
taiguy
Drives: 2013 Black BRZ Limited
Originally Posted by Silverfox View Post
Please keep us updated. My car threw a p2135 about 4 times now over 4-6 months. I had the same issue. Limp mode, stopped car, turned off for 5 minutes and then car started no issue but gauge read p2135. Out of the state but taking it to the shop once I’m back.
Edelbrock sent a replacement throttle body harness and it didn't have any change. The shop is waiting on a known good throttle body they can sub mine with to try and isolate the problem. Right now, there's a mismatch between the throttle position sensor and the throttle body. They're saying the first inch of travel with the pedal registers as a zero.
taiguy is offline   Reply With Quote
The Following 2 Users Say Thank You to taiguy For This Useful Post:
CSG Mike (04-11-2018), Silverfox (05-03-2018)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
