Old 04-03-2018, 08:48 PM   #15
lantsalot
Derp
lantsalot's Avatar
Originally Posted by Beachin86 View Post
Correction: A new TOB DOES come with Exedy kits. I bought an OEM clutch kit when my TOB went bad, and there was a new TOB included.
HOWEVER: DO. NOT. USE. EXEDY'S. TOB. You'll want to buy the newer one from Subaru or Toyota. They knowingly upgraded this part when this issue became common. Throw away the one that comes with the kit.
Why not the Exedy TOB? (Genuinely asking)
lantsalot is offline   Reply With Quote
Old 04-03-2018, 08:53 PM   #16
Originally Posted by WNDSRFR View Post
OK so it's definitely beyond any doubt whatsoever that it is the TOB. I drove the car today about 20 feet to put it on ramps and every time I depress the clutch petal you can hear it grinding and starting to smell. I'm really lucky it failed so close to home. So the damage should be minimal. It's also amazing how it happened with no warning at all. It was perfect for 129,000 miles, then it failed. Just like that. Oh well.
As far as American cinder blocks vs Chinese jack stands goes, I think I'm leaning towards the jack stands. If it doesn't go high enough maybe I can put the jack stands on solid concrete blocks. I don't know. We'll see how it goes.
I don't need to be in a hurry, I still have my GTI and it's still a lot of fun to drive.
Solid blocks or good heavy chunks of wood are a far better choice.
Mine blew 45 minutes away fro the dealer and I drove it there anyway. Can confirm that clutch-less shifts are indeed possible. Was an interesting drive.
Old 04-03-2018, 09:17 PM   #17
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Now the big concern I have with changing the clutch is...
How do I get the car far enough off the ground to remove the transmission?
I was thinking about jacking the car up and putting it on cinder blocks. Then put the jack on cinder blocks and jack it up some more and add cinder blocks until it's high enough to comfortably work under. But.........
Dude. Take a trip to Harbor Frieght, look for those tall SUV jack stands. Those are great I used those with zero problems on 5 engine swaps to date. Also a tranny jack is a god send.
Old 04-04-2018, 01:47 PM   #18
WNDSRFR
Drives: FR-S,GTI
This came with the kit.
Can anyone confirm that the Exedy TOB is a POS? I think I heard somewhere that the OEM clutch is an Exedy.
Old 04-04-2018, 02:16 PM   #19
Cinder blocks, bricks, etc. are a huge no-no. Never get underneath anything supported by them. You never know when they will fail.
Also, remember to support the engine to keep it from flopping forward when the transmission is separated from it. Otherwise, it will be a nightmare trying to get it back together.
WNDSRFR (04-05-2018)
Old 04-04-2018, 03:34 PM   #20
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
There is no known aftermarket TOB. The one that comes in kits will be a OEM TOB, but which one?
Spend the $40 and go to Subaru and get the upgraded one so you know.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
humfrz (04-04-2018), lantsalot (04-04-2018), Tcoat (04-04-2018)
Old 04-04-2018, 05:46 PM   #21
lantsalot
Derp
lantsalot's Avatar
Makes sense, thank you for the info! I'm just hitting 60k miles and anticipate this being pertinent information soon based on the number of threads I see about this...
Old 04-04-2018, 10:38 PM   #22
Good idea!
I have seriously considered buying one and keeping it in the glove box, so, if I'm out in the bush somewhere and the TOB goes bad, I'll have the right one for the local Bubba to just pop in there.
Sapphireho (04-05-2018)
Old 04-05-2018, 09:49 AM   #23
WNDSRFR
Drives: FR-S,GTI
I just looked up the DIY for clutch replacement and the pictures are gone! It says something about 3rd party hosting has been temporarily disabled. Something to do with Photobucket. Whatever that is.
What does this mean? Are the pictures gone forever or are they being held ransom by some third party?
I was really hoping to use the DIY as a guide but it will be a lot more difficult without the pictures.
Old 04-05-2018, 09:53 AM   #24
Photobucket is the service and indeed they are now expecting to get paid so most pictures are gone.
You can pull the procedure up in the service manual. https://demos.starbase7.net/t3Portal..._rm_index.html
humfrz (04-05-2018), WNDSRFR (04-05-2018)
Old 04-05-2018, 01:52 PM   #25
WNDSRFR
Drives: FR-S,GTI
You know, what you say makes a lot of sense. But if I go to the Subaru dealer and get a new one, how can I tell that it's the latest and greatest? How do I know if the one I have isn't the new one?
The way I look at it, the one that just blew was definitely the old version because the car was built in 2012. And they didn't know there was a problem at the time. And it lasted for 129,000 miles.
So I think I'll just roll the dice and take my chances with the one I have. When it does blow, at least I'll know what I'm up against to replace it. Plus when it blows it will probably time to replace the clutch anyway.
Old 04-05-2018, 01:55 PM   #26
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Different part number.
Old 04-05-2018, 02:14 PM   #27
Make sure it is part #SU003-07349. That is the upgraded one.
asdf (04-05-2018), bcj (04-05-2018), humfrz (04-05-2018), lantsalot (04-11-2018), WNDSRFR (04-06-2018)
Old 04-06-2018, 02:50 PM   #28
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
The main reason why these are going bad on earlier models isn't the part, per se, but the grease that was used. It doesn't withstand the heat it endures, so it breaks down over time and results in the TOB going out. I don't know what other changes were made to the new TOB, but I do know the grease was changed to a more heat-resistant one. There's no guarantee that the TOB that comes in the Exedy kits has this. By not spending the $40 on the updated part, you run the risk of this happening all over again later down the road.
Tcoat has referenced the new part. There's a Subaru branded one and a Toyota, but they're really the same thing. I would go with the proper brand just to be on the safe side if a warranty claim should arise in the future.
Beachin86 is offline   Reply With Quote
The Following User Says Thank You to Beachin86 For This Useful Post:
