Old 04-02-2018, 09:27 AM   #85
Originally Posted by extrashaky View Post
IIRC you have the TRD springs on your car, right? Did you install camber bolts? Were there any alignment issues?
I have a set of the TRD springs sitting over there in the corner in a box. I didn't think I needed camber bolts, but your comment sounds like they might put it right at the limit.
I actually have RSRs which are a but lower than the TRD. They do not have camber bolts but probably should. As you said they are right at the limit and are fine as long as you are OK with that. I would think the same applies to the TRD.
extrashaky (04-02-2018)
Old 04-02-2018, 11:23 AM   #86
StraightOuttaCanadaEh
Wes
To drop anything over an inch you need camber bolts for the front and lower control arms in the rear. That is about it though. There are some very good write ups in the suspension sub forum here.
so are you saying since I have coilovers, I should have camber bolts and LCE as well? tried looking in the suspension forum but couldn't find anything. What's the rationale? I'm dropped about 1.2-1.5 inch (I think)
Instagram: @gt86ws
Old 04-02-2018, 11:27 AM   #87
Coil overs usually have adjustment built right in. As long as you can get the alignment you want then all is good.
Old 04-02-2018, 11:46 AM   #88
Wes
seems to be alright. But I don't have LCEs and was under the impression you need them if you want extra camber at the back, which I for sure would prefer not to have. However if it improves ride quality or anything else, then worth looking into maybe
Instagram: @gt86ws
Old 04-02-2018, 11:52 AM   #89
Riftur
Riftur's Avatar
I have a question that kind of fits in this thread. My 2013 FRS AT was built on 09/2012. I have heard something about bad seals and do not know anything more. Would someone please fill me in on what seals they are and if my car is affected from it?
Riftur is offline   Reply With Quote
Old 04-02-2018, 12:20 PM   #90
Teseo
Drives: frs
I guess that was of direct injection seal
The Following User Says Thank You to Teseo For This Useful Post:
Riftur (04-02-2018)
Old 04-02-2018, 12:21 PM   #91
From what I understand they are talking about the direct injector (DI) seals.
Some have had them blow out under high rpm, quick shifting.
I doubt your car with an AT would be affected as frequently as a car with a MT.
I'd figure that if your car hasn't had any problems by now ...... it likely won't in the future.
Riftur (04-02-2018), Teseo (04-02-2018)
Old 04-02-2018, 12:24 PM   #92
Riftur
Riftur's Avatar
Thanks for the info. Do you know if they cover the repair if something does happen?
Old 04-02-2018, 12:26 PM   #93
ermax
ermax's Avatar
Yeah it was DI seal failures. But it's a software problem not an actual flaw in the seal. The dealer can update your CALID to ZA1JB01D prevent this problem. I wouldn't be surprised if they already updated it during other visits to the dealer though.
The Following 2 Users Say Thank You to ermax For This Useful Post:
humfrz (04-02-2018), Riftur (04-02-2018)
Old 04-02-2018, 12:40 PM   #94
Teseo
Drives: frs
OFT tunes got rid of it too
Riftur (04-02-2018)
Old 04-02-2018, 12:40 PM   #95
See ermax 's post.
I would think that unless your car was FI, and it was within the warranty period, any repairs to defective DI seals, would be covered.
Riftur (04-02-2018)
Old 04-02-2018, 12:53 PM   #96
Riftur
Riftur's Avatar
Thanks all, The car has the latest software and I use the OFT tunes sometimes also. So i am good.
The Following 2 Users Say Thank You to Riftur For This Useful Post:
ermax (04-02-2018), humfrz (04-02-2018)
Old 04-12-2018, 04:51 AM   #97
9walker
9walker's Avatar
Drives: Toyota 86
I am at 45000km. The only problem I had is the squeaky clutch noise. They had to drop the tranny and grease the clutch fork to stop it. The TOB was fine in my case. It just funny to me how this problem happened this early and what it takes to fix it.
9walker is offline   Reply With Quote
Old 04-12-2018, 10:19 AM   #98
reeves
Mine's been squeaky the last 50K miles or so ... I just ignore it.
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
rom tuning for improved gas milage ganz954 Software Tuning 19 12-02-2014 11:08 AM
Does Turbo effect gas milage?? beesmiff07 Forced Induction 86 10-30-2014 11:25 PM
WTB: FRS/BRZ high milage cools20 Cars for Sale/Trade 0 10-13-2014 02:10 AM
Milage App. execoll Scion FR-S / Toyota 86 GT86 General Forum 11 09-14-2012 01:23 PM
