Old 03-25-2018, 04:43 PM   #15
Impureclient
Drives: 2015 FR-S
Originally Posted by ZDan View Post
I ran MPSS on the FD for a while. Initially they were OK, after less than 2 years on the car they lost all grip. Weird experience that I haven't had with other higher-performance tires.
I had the same thing happen on mpss, but only about 8k-11k miles/2 years during that time and leading up to that they were sliding all over.
I bought the car with 3k and the previous owner might have used them the entire time of the 3k when je had it or possibly put them on right before selling.
I swapped them out with plenty of life in them at 11k because spinning out doing a u-turn wasn't fun if I didn't have control.
Old 03-25-2018, 08:44 PM   #16
reeves
IMO, even at their best they're somewhat overrated. Personally I went back to the Extreme Performance category for street usage. Actually on the FD I went to Nitto NT01 DOT race tires for street/track...
Anyway, me, for street only usage on 7", I'd be looking at Hankook RS4 in 215/45-17. In Max Perf category I'd look at Conti ExtremeContact Sport and B'stone S04 before PSS. Actually I wouldn't even be considering PSS...
MPSS supposedly excels in the wet as well as dry... How does the Extreme Performance tires you've tried handle in heavy rain/puddles? I'm tempted to just buy a 2nd set of cheap wheels + summer tires, and save my all-season tires for winter time.
Old 03-26-2018, 07:45 AM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
Mine were fine *until* they went "off", after which time they were the absolute worst tires for grip I've experienced.
How does the Extreme Performance tires you've tried handle in heavy rain/puddles? .
Not bad at all. Of course with less void in the tread they are more susceptible to hydroplaning, replacing before getting to the treadwear indicators is a bit more important. And of course slowing down for standing water is always a good idea! Honestly it hasn't been an issue for me.
reeves (03-26-2018)
Old 03-27-2018, 08:46 AM   #18
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Should keep in mind the unique characteristics each tire has as well. If you just want more grip, you don't need the craziest tire, just something better. I run the Falken Azenis RT-615K+ as long as it's above 50 degrees f. Better than stock in the rain, better than most non r compound tires for flat out grip when heated. I've been running different revisions of this tires since 09. I've had the Dunlop StarSpec Z1 (before they became priced like a Michelin tire), I've ran Nitto NT05 and Yokohama S. Drives. There's one conclusion I've come to. You need to run them to find out the characteristics you enjoy most. I have no doubt that from watching people run the PSS it's the best all around tire. I love the sidewall stiffness on my Azenis for turn in, I also like that it does not gradually give away and slide prematurely, but it's very bad if you don't know the limit of the tire.
I'd honestly recommend going through some cheaper tires with different characteristics, and see if jumping from one set to another, you find yourself noticing nuances you enjoy or don't enjoy. $350 a set for cheap tires that will grip better than stock will be a better investment than $750 for a set you don't like and can't really re sell.
Old 03-27-2018, 09:54 AM   #19
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by Cal3000 View Post
I'm sick of the stock tires, especially in wet conditions. I know the highest width you can run are 225 on these wheels. I need grip. What tires should I get?
Just got some Bridgestone 225s on mine... well, 2 months ago; and man what an improvement.
It does make the car so much better all around - particularly in the wet!
I’m told these particular Bridgestones are a bit soft and won’t last as long, but I got a greeeeaaaaat price on them (35% discount) so I can live with that.
I like driving!
86 South Africa is offline   Reply With Quote
Old 03-28-2018, 01:16 AM   #20
Cal3000
Drives: Panda FR-S
Nice
Man this thread is old. lol.
I've been running 225 Michelin PSS since the OP. They stick like glue.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
86 South Africa (03-29-2018)
Old 03-28-2018, 11:06 AM   #21
jslack
Drives: 2017 Red subaru BRZ Limited
OK Group. I can get any tire at 5% over cost and want to spend around 450-500 or so on a new set of summer tires. What you all got out there that you like?? Either a A/S or summer tire is fine too. I'm in the midwest so it does get hot out in the summer.
jslack is offline   Reply With Quote
Old 03-29-2018, 08:06 AM   #22
JD001
JD001's Avatar
Drives: Subaru BRZ
As the MP4s is unavailable in the UK in our OEM size I have decided to contact Michelin UK to see what's happening...
Response from Michelin:
Unfortunately the MICHELIN Pilot Sport 4S is not available in 215/ 45 R17 , and it does not appear that they will be launched in this size any time soon either.
MICHELIN is happy to accompany you on every journey and would like to thank you for your confidence.
Best regards,Dora
MICHELIN Customer Care
Passenger Car & Light Truck Tyres
Tel: 0845 366 1590
E-mail: contact@tc.michelin.eu
Contact us: http://www.michelin.co.uk/contact
Web: http://www.michelin.co.uk
[IMG]http://www.ft86club.com/forums/data:image/png;base64,R0lGODlhoQAzAHcAMSH+GlNvZnR3YXJlOiBNaWN yb3NvZnQgT2ZmaWNlACH5BAEAAAAALAAAAAChADMAhgAAAB8bL xwZNxoXPhYTThIQXBQRVRgVRgsKcw8OZA0MawkIewAAmQICkQc GggQEihAQnyIfICMfICMeICQeID87HCIiIiQgICYiIjQwMTMvM D87PCIgIDIuLzEtLi8rNj87LC0pPTUxMzw5RDAwrCAgpkA9PkI/QFpXWExJSlhVX09MTUBAs1BQuXNzU3ZzdGhlZmBgv3BwxpGPEJ KQEJGPkIOBgp+dnZGPj4+P0oCAzJ+f2a2rDK6sDLq5ua2rq6+v 37+/5cjHx9bV1c/P7N/f8v//AOLiBPHx8eTj4+/v+f///wECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwE CAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECA wECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwE CAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECAwECA wECAwECAwf/gAAXAISFhoeIiYqLjI2Oj5CRkpOIETU2GY8aKBsclJ+goaKjky ZISUISKYscGz5LSS8SpLS1treLEkmwNkMTih1IQkNDQjWeuMnK y5JLSEs/QosvSz4+P0k2zNvc3QAUxDXPJ4o3SzUpNig/q97u76QwsEtLKMiGEs83veI+g/AAA0Z68UxYO3z01KVAsUSawIcQE7lydq4DhkM/6A2xgQQJjH8RQz4Ut6uhkA0RJEyQgMIDvZdJaqATSRNgimewdv mwIQQGzpdA6QlJEaGm0W0bhPgQUlBIEh9IMgYNiqRX0aNYcQkB +mqJua5T6SX5gQ1F1rO1OmArhjOjMbJC/+IKiYaNHju0eEHRw1FjSMklxUxqjPv3JYwbDMMqXsy4sePHkCN LjgxgCYMGAaTCMlftp+KqS1IwGE26tOnTqFOrXs26tevXsFcvq Ty6AYENh8GCXXzDHIrYwIMLH05c+GzLpB18uPEsSe+tioUwr5H EQ4Pi2LNr3676uOkHBAKg6Or8x42416zhrHHjBwHu8OPLh+39N ILEkGvQE3B9vv//89V3mgScOebDELC8wB+ADDZYnICm5XNDYWH5QA0Sr9SQgIOnkc DChyyUwOGIDEBYmgRCXUPhU9jU4JRQBZQGQVhKkDAaC4rFMBoQ QelIWgkyBBEWEaMVAZQSo+UQlP+NDBjJmI4zAlXEaSUENSUDJA wJAQMxABWEaSaO9oAHuxmzlA8uvpQCUDUoUFqXYekwGhE0jhbl S0jauQNjMmAZVA5FSjlalowpsSWcL8lpmg5/JqlYnzy+5CNpYTJgQDQINvaDBC8kkcQQPozg5mhCxskAo2HtMJ oMQamKpRKNbbknUDbiCBSgDMy6mKulviSiaU6+xGSwQelQJVBb llbpAFsN8UOmUzmXxAAJDJAYEikswMCxcRIaFgtzBgUuCbAGRY QO6Bbharn0XKkrPb+yu0QQIIIoIrf0EGmarS/p28JiLbD6kqvK0nYaAWA5255MNVzT7AEMLODiMz68J3D/WDLQGdaV+C4xJQTyLqEEuD+K+K+UQQQhr76Itpvyyz6iKulp7y 7RZ65HAsWCxvS0cFqYDWygWVC7LQEDAqMJ8GwxEBP7bq8804Or krcycLGwqUXamI9aKzZsUMmWFvKWd9Lz7tV5gmlwaQpwBC1Qmi GxkbaXjYDCAAM44G3PNMoMb6BAidgrPV+iVjZjZDd25d5LEExa y0sAMVrL5wIVNa5qI1daAfoJ8xMSLhLjVz0OkPbAA6S9OzLGUf tr7mhT1Yga5IpJbnWr6ObuM85A6VCvjV0v4ePgMVAdFpOZn9b2 S6AqNUSBYgmgmrw58PtSEB37WLOPIROuQxBEXBm1/6G3A7V71EvknjvJ3d96eJ4dQzC45amFqcBNU4H+UxIolI7aycK ynsgg4LclkG1so6nZVPrUMVcRK0+MOx6XGgOkVo3Gb6qa30tu9 rO1jUYBEoiLZ0AHC7kg4TdZo9/VluAzYtkOcrZjAATQFxQRGY8e42oUA264sR0xhkjoIxmxfKbBv 6EGQg34QFwAMwylJMUzS9gA6k5zuD75TXKM213wdkcaHRBrYIB rl6NoFcZHybAxMmDc4o5EqrDEsIOaixg1oPOSTVUjU6ioQYxIJ KN6/YqPJIKQxHLyEmwJoDlk2UWbAMnIRiaPNAmQhzOKcSAUIMAGVBl BfxzJST4ex/8IoDQCCEYHFCRUYAbUwUksaBDKVrrylbCMpSxnScta2vKWrYzP J0F5BIaQkh4v4AEP9DMWqNSgB7hMpjKXycxmukCXawsaPTAUFx S4qQEj8IwmO8nNQHrwALtBQgiSkwL0qMB/3UwngyD0gCfCIgVI+yAmY/IeddrzP8cBCg548gMYwOBtOIDOSYo2mYIa9KAITShlDlFOGNhg A4kAC+hEkJeKkkIDxY***xRhCqD44hCzsSghQooLkm5jAtA7yC FWAJQkzMIQ9EiESRFB0pkyw6a1wGkyUAQUG4DEEBwgSENsQAGY 4vQlhUBqZUIa05HGVKlJrcxSncrUkYJUqlBybepxpOpUqlJVp7 jgAEkAA1FFUEACaAUpVKPK1KZy9a1ZpSlQklrTt0bVqm2lq1Lj itd3XAAFNYDBSyexVZpy1a17zWdd5ZpYrR6VrV3Fa1sXi1WRWv WyV8UsZsGqiMLe1a6f3WwjwMpZy4aktKYtRCAAADs=[/IMG]
Old 04-01-2018, 08:48 AM   #23
mrg666
pessimistic skeptic
mrg666's Avatar
I have General G-Max AS-05 245/40-17 size. Winter was just fine, rain traction is great. Summer driving is good too. Price is great, I would buy again.
Old 04-05-2018, 06:55 PM   #24
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
Had MPSS, just got Firehawk Indy 500's. Awesome value.
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Wheel Directory: Effect Sengen 17x7.5 +40 Leonardo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-14-2013 02:18 PM
FS: Stock 17x7 wheels from BRZ w/ Primacy tires zoomzoomers Wheels and Tires 0 05-28-2013 07:53 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
Wheel Directory: Enkei WTE II 17x7.0 +41 stout90 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-06-2013 10:18 PM
OZ wheels 17x7.5 best fit with which tires? newkid185 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 08-19-2012 12:36 AM
