| Engine Swaps Discussion of engine swaps. |
Drives: Subaru Brz, Lifted Jeep Liberty, Mi
Hi everyone
I am planning to swap a 2015 brz but I am not really sure of which swap should I do. Do u have swap ideas ? I think about a ls3 or a 2jz. What do you think about these engines ? Thank you |
#2 |
I thought about the fuel consumption of a ls3 and I think the fuel tank is too small. The fuel consumption will be 19l/100km so I will only have 300km autonomy.
#3 |
Panda Trueno
Drives: No twin now.
Ls3 absolutely. Unless you HAVE to go with a Toyota motor the Ls swap is already well documented and reliable.
#4 |
Thank you for ur reply
I just think the 50l tank is a bit small for a big engine like this. Do you think it is possible to upgrade it and add something like 10 or 20 liters? |
#5 |
Panda Trueno
If its between those two motors, a 2jz should get even less mpg.
When doing an engine swap like this fuel consumption is generally not a main concern. Is there a specific reason you're swapping? Last edited by Summerwolf; 03-29-2018 at 07:46 AM. |
| The Following User Says Thank You to Summerwolf For This Useful Post: | DustinS (03-29-2018) |
#6 |
Fuel tank sizing will be the least of your worries with the swap honestly. lol
#7 | |
Drives: 2015 Raven V8
2011 Camaro gets 14.7 city and 9.8 hwy. FYI, the Supra 3.0L 2JZ gets worse economy. Even 2018 STI gets worse hwy economy than LS3. |
#8 |
Drives: '23 BRZ
I got 27mpg highway (8.7L/100km) with 6.0 LS2 in my FD RX-7 w/ 0.5:1 6th gear and 3:55 diff. With the 6.8 LS3 in it now and 0.64:1 6th gear I get 24mpg highway (9.8L/100km).
In town it does suck though, more like 14mpg (16.8 L/100km). No reason a 2JZ should get better fuel mileage, an LS3 Corvette gets slightly better city and significantly better highway mileage vs. a 2JZ Supra... |
| The Following 3 Users Say Thank You to ZDan For This Useful Post: |
#9 |
Ok thank you so I think I will go for a ls3.
No I don't have a specific reason, the FA20 has a bit lot of kms so when it break I will swap. |
#10 |
Drives: None
Buy another one and do both swaps.
#11 |
LMGTFY
Drives: 13 FRS, 91 Miata
Beams 3SGE
| Tags |
| 2jz, ls3, rb26, sti, swap |
