Old 03-12-2018, 04:36 PM   #4411
CSG Mike
CSG Mike's Avatar
Originally Posted by amcp1 View Post
This is a tough call, currently the car runs flawlessly. Is it worth the extra expense to gain some power and solve a problem that doesnt exist?
If it's not broken, you don't need to fix it!
Old 03-19-2018, 12:31 PM   #4412
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
After enough research, I am going to be going with this instead of Innovate. Thanks.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
The Following 2 Users Say Thank You to Lakitu For This Useful Post:
Jackson Racing (03-22-2018), twag4 (03-19-2018)
Old 03-19-2018, 01:53 PM   #4413
CSG Mike
CSG Mike's Avatar
Fantastic choice!
Old 03-27-2018, 02:44 PM   #4414
CxG
Drives: Pearl White '13 ZN6
So a buddy of mine had a C30 JR kit and the unit went kaput. He's giving me the rest of the kit since he went the JDL rout and all I need is the SC unit. Instead of going with the C30 I was going to upgrade to the C38 but then I saw this pre order for a C38R at a fraction of the cost. Can anyone tell me more about this? Also any word on a variable supercharger unit like the rotrex VC8 so we can get more low end output out of these centrifugal sc's?
CxG is offline   Reply With Quote
The Following User Says Thank You to CxG For This Useful Post:
PR138 (03-27-2018)
Old 03-27-2018, 02:57 PM   #4415
CxG
Originally Posted by mrg666 View Post
Just to update. 10K miles, no problems. Never refused to start in the extreme colds in upstate NY. Snow, ice, rain, or shine ... never driven anything else. Still running great. Oh, maybe just a bit on the cons side, it is a little more tiring to control the boosted car in snow ... maybe because I only had four-season tires
which oil cooler are you running and do you have problems hitting operating temps during the winter months?
Old 03-27-2018, 03:14 PM   #4416
CSG Mike
CSG Mike's Avatar
The C38R is not available for a FA20 application. PM to order a C30 or C38.
CxG (03-27-2018)
Old 03-27-2018, 03:28 PM   #4417
stlgrym3
What’s the difference between C30 and C38? Neither of them supports 2017 model yet correct?
stlgrym3 is offline   Reply With Quote
Old 03-27-2018, 03:51 PM   #4418
CSG Mike
CSG Mike's Avatar
Both fit on the 2017 BRZ.
C38 has more theoretical overhead than a C30 for big power.
CxG (03-27-2018)
Old 03-28-2018, 09:21 AM   #4419
rns294
Drives: 13 BRZ
I hadn't heard of this before but just looked it up. Is there a reason it wouldn't work on the FA20 if it is the same size as the C38? Does it have to do with the belt or power levels?
rns294 is offline   Reply With Quote
The Following User Says Thank You to rns294 For This Useful Post:
CxG (03-28-2018)
Old 03-28-2018, 10:18 AM   #4420
gtengr
Drives: 2017 BRZ
I think it's mostly the power levels. Rotrex is marketing the C38R's ability to support +900hp. That would probably put it in an inefficient operating range with most FA20 builds.
gtengr is offline   Reply With Quote
Old 03-28-2018, 12:51 PM   #4421
mrg666
pessimistic skeptic
mrg666's Avatar
I have installed OEM Subaru STI liquid-to-liquid oil cooler. It actually helps with warming up the oil quicker in the winter and then helps with keeping the oil temp at the coolant level. It is more like oil temperature regulator than cooler alone. I would recommend Jackson Racing Dual Radiator/Oil Cooler which is a more powerful liquid-to-liquid cooler. Air-to-liquid coolers are better for track and warm climate areas.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
CSG Mike (03-28-2018), CxG (03-28-2018)
Old 03-30-2018, 01:15 PM   #4422
Brzxton
Drives: 2015 Subaru Brz
Hey i got a hks bov that i plan on installing on the kit. I was wondering if it would make a difference whether i install it before or after the maf sensor? I marked x’s on the picture, a being before and b being after. I was planning on putting it on b but didnt know if it would interfere with the mad sensor or if both will mess with the maf sensor. Thanks!
Brzxton is offline   Reply With Quote
Old 03-30-2018, 02:45 PM   #4423
rns294
Drives: 13 BRZ
Neither because if you are going to use a BOV, it would replace the existing bypass valve.
Old 03-30-2018, 03:17 PM   #4424
Brzxton
No it wont im plugging that and welding a flange onto the cold side piping.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
