Old 03-28-2018, 03:41 PM   #15
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
Update; changed the low pressure fuel pump assembly as a whole and kid still popping up. Anyone can direct me where the high pressure fuel pump is?
mulekr1 is offline   Reply With Quote
Old 03-28-2018, 06:45 PM   #16
ATaraxias
Drives: 1994 Geo Metro Hatchback
Here is a diagram that answers your question; you should not use it.
http://www.ft86club.com/forums/attac...0&d=1383348828
I would highly encourage you to follow Steve99's advice. He's a boss.
ATaraxias is offline   Reply With Quote
Old 03-28-2018, 08:56 PM   #17
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Thumbs down
Originally Posted by guybo View Post
If you play parts darts and start replacing things having no clue what the actual problem is, not only will you find the most expensive possible way to fix the issue, but you will spawn even more issues off the orig problem.
Yeah, I'll quote myself. You are on the first step & you probably replaced a good working part for a shittier one. Now do it right and find the problem
guybo is offline   Reply With Quote
Old 03-28-2018, 08:58 PM   #18
guybo
Huge E85 fan!
guybo's Avatar
I would not start randomly changing stuff.
You need to get a proper diagnosis done and someone to measure the pressure of low pressure fuel pump.
Maybe remove low pressure fuel pump from tank and check filter is not clogged.
Hell, I didn't see Steve99's post and I'll quote him too.
Old 03-28-2018, 09:42 PM   #19
steve99
Drives: FT86
Diagnosis of this issue will be complex
You need to look at all fhe codes thrown
Log the ecu fueling paramters pi\di ratios, injector opening times afr commanded afr
Our system is more complex thzn most as it runs both port and direct fueling and differnt percentages depending on rpm and load
Unless you understand fuel systems and diagnosis very will you will waste lots of time and money.
Take it to someone who understands brz\86 or a specilist subaru shop
See the link here it has some basic video linked on problem diagnosis, but out car is more complex due teo fuel systems and two pumps. The direct injection system runs at over 10000 psi, not 50 or so psi like the port system.
http://www.ft86club.com/forums/showt...01#post1842501
Old 03-28-2018, 09:51 PM   #20
mulekr1
mulekr1's Avatar
I don’t know why you’re saying it’s a shittier item I put back his car has less mileage than mine he only bought it to do a 2jz swap. My mechanic is the one who said to start there but I am listening to Steve99 and I told him I’m taking it elsewhere to someone who understands direct injection better
The Following User Says Thank You to mulekr1 For This Useful Post:
guybo (03-29-2018)
Old 03-28-2018, 10:00 PM   #21
mulekr1
mulekr1's Avatar
I’m gonna post in my regional forum about a specialist 86 shop but I took it to a much more conpentent shop
Old 03-28-2018, 10:01 PM   #22
mulekr1
mulekr1's Avatar
I literally replaced it because I don’t know how to check if it’s clogged.
I put a 2500 mile fuel pump in it...
Old 03-29-2018, 07:49 PM   #23
mulekr1
mulekr1's Avatar
Good news guys my new guy put my high pressure fuel pump on my fathers car and it started the same symptoms so that’s a clear indication it’s the high pressure fuel pump tomorrow he should complete the swap of the parts and it’ll be the moment of truth I suppose thats good news. To bad a high pressure fuel pump is around 600$ brand new but I think I’m gonna go used.
The Following 2 Users Say Thank You to mulekr1 For This Useful Post:
guybo (03-30-2018), steve99 (03-30-2018)
P0087 Low Fuel rail pressure GT86meMR2 Issues | Warranty | Recalls / TSB 17 05-15-2021 01:23 PM
Another CEL code whitefrs Forced Induction 20 11-27-2019 11:27 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 08:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 10:19 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 01:27 AM
