Old 03-26-2018, 08:04 PM   #211
timmydatooth
Drives: Scion Frs
So today driving home my CEL came on. I checked what the code was on the OFT and it said p0420. This only happened after I updated to the new tunes. I was on the v2.076 tunes for a couple years with no CEL code ever. Do I just disable it on the oft and move on?
timmydatooth is offline   Reply With Quote
Old 03-26-2018, 09:00 PM   #212
John27
Drives: scion fr-s
dose any one have problem data log after the update to tablet because after i re-flash ecu with new tune 4.1 i can not data log i get error that say operation has fail
John27 is offline   Reply With Quote
Old 03-26-2018, 09:14 PM   #213
John27
Drives: scion fr-s
I guess it just was a glitch cause now it working fine I guess does thing happen once in while :bonk
Old 03-26-2018, 09:25 PM   #214
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What tune did you use? It has been found that stg2 and stg2+ A01D does not have the deff for P0420.
NoHaveMSG is online now   Reply With Quote
Old 03-26-2018, 10:23 PM   #215
John27
Drives: scion fr-s
stag 2 ZA1JD00D
Old 03-26-2018, 11:37 PM   #216
timmydatooth
Drives: Scion Frs
This is my calibration code for my tubes <ZA1JA01D.ori> and I use the srage2+. So are they fixing this problem and will it damage my car?
Old 03-27-2018, 12:56 AM   #217
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It will run fine. If you have a catless header that will throw a code and disable cruise control.
Old 03-27-2018, 01:05 AM   #218
Ebush
Drives: 2017 Hot Lava 86
Originally Posted by Walla Walla View Post
anybody know if we can still modify timing like in the older tunes to support the Crawford PowerBlock?
my car is in storage right now so i can't test it, but i wonder if it could interfere with any new modification done to the V4 tune
It still works the same, I adjusted the timing tables the same as before and it all looks good. I’ve tested the stage 2+ 93 tune and the e85 tune.
Ebush is offline   Reply With Quote
The Following User Says Thank You to Ebush For This Useful Post:
Walla Walla (03-27-2018)
Old 03-27-2018, 01:07 AM   #219
steve99
Drives: FT86
On auto 2012-2016 looms like oft guys forgot to disable p0420 code and tge supplied def doesnt reference P0420
I put defs attached to first post, you will need sticght mod to def tgen you will ve able to accesx p0420 in the V4 auto tunes
Old 03-27-2018, 01:20 AM   #220
irxproductions
irxproductions's Avatar
Drives: 2013 FR-S, 2015 Speed Triple
I absolutely love my Open Flash tablet!
I flashed my '13 FR-S with the Stage 2+ tune (no E85 because I live in hell) and... it may be all in my head... but I swear my car ROARS now.
I recommend the OFT to everyone who will listen (and owns a compatible car).
When I first bought it, I only had a new exhaust so I was Stage 1. Then, I added a CAI and UEL catless header and moved to Stage 2 (2+ was years away), and now I'm stage 2+.
Each stage brought the same fantastic seat-of-the-pants excitement; like I got an all-new car.
Thanks, Shiv, and the rest of the OFT team - your work is outstanding.
irxproductions is offline   Reply With Quote
Old 03-27-2018, 08:46 AM   #221
bdtbdtbdt
Drives: 2015 Scion FRS
I'm running OFt V2 stage2 on an auto 2015 frs. Love it. What are the advantages to the V4 tune?
bdtbdtbdt is offline   Reply With Quote
Old 03-27-2018, 09:34 AM   #222
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Has anybody requested a flex fuel tune based on V4?
yelsew is offline   Reply With Quote
Old 03-27-2018, 10:24 AM   #223
timmydatooth
Drives: Scion Frs
Sorry but I really don't know about defs and tunes too well. I just put them on my OFT and write them to my car. Is shiv and the OFT guys fixing this for the v4 tunes? Is it better for me to just switch back to the v2.076 tunes just so that I do not get that CEL to come on anymore? Just don't want to leave the v4 tune on if it is hurting my car...
Old 03-27-2018, 11:33 AM   #224
John27
Drives: scion fr-s
I am running v4 tunes no cel has came up
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
