Old 03-26-2018, 12:30 PM   #2311
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Originally Posted by slow15frs View Post
For the price they are great tires, only thing i wish they were slightly stiffer for better turn in but no problems love them
Sent from my SM-G955U using Tapatalk
How were they when you first put them on?
I'm waiting for it to warm it before I go swap out my current tires to the ECS set
Alltezza is offline   Reply With Quote
Old 03-26-2018, 12:57 PM   #2312
slow15frs
slow15frs's Avatar
Drives: 15 scion frs
It was summer when i first put them on though they were sticky. But before i took them off it was in the 20s and couldnt tell that still had plenty of grip
2015 Scion FR-S-hot lava 6MT Perrin cai magnaflow cbe EFI LOGICS tuned 193whp
slow15frs is offline   Reply With Quote
Old 03-26-2018, 05:19 PM   #2313
Alltezza
Alltezza's Avatar
Jesus I just got them installed and they're amazing already. And a lot more quieter than the RS3s.
I also changed my Tein Flex Z damper adjustment from 5 clicks to 8 clicks all around and it looks like with these 2 combos. Everything is very...comfortable
The Following User Says Thank You to Alltezza For This Useful Post:
slow15frs (03-26-2018)
Old 03-26-2018, 06:10 PM   #2314
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Looking for some help. I picked up a new set of wheels 17x9 35 offset. Sitting all stock suspension. -0.05 left and right camber up front -2.10 left and -1.25 right camber in the rear. Will 245/45/17 Fit with no rub? If they do rub should I downsize width or side wall?
Thanks!
Elliotw is offline   Reply With Quote
Old 03-26-2018, 06:30 PM   #2315
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks!
245/45/17 is an inch taller then stock. Go 245/40 or 235/40. I don't think you will rub though as long as you are not lower then an inch over stock. At the ridge my front right rubs the inner fender a bit. I am 245/40/17 on 17X9 +38 at -3 camber in the front.
Elliotw (03-26-2018)
Old 03-28-2018, 01:08 PM   #2316
slacker221
Drives: 2013 BRZ Premium
Here is my meaty tire setup. Old Corvette C4 Z51 Enkei wheels I had laying around from a Z51 Corvette I had years ago. The wheels are made by Enkei in japan and have casting inside the rim showing the make and size, the cool thing is they came off my old 1986 Corvette. The more 86 related parts means more faster right?!?!?
Specs are:
16x9.5 ET. +38 all around
255/50 R16 BFGoodrich G-Force Sport Comp 2's all around
Front - 25mm spacer/adapter
Rear - 50mm spacer/adapter
Im using spacer/adapter to get the lug pattern correct, and to also space out the wheels to sit flush with the widebody kit.
I have only seen one other 86 with corvette rims so I thought I would share.
20180326_160213 by David Smith, on Flickr
slacker221 is offline   Reply With Quote
The Following 6 Users Say Thank You to slacker221 For This Useful Post:
BigFatFlip (03-31-2018), DuMa (03-24-2019), Jive Turkey (04-30-2018), Leonardo (03-28-2018), NAEightySix (03-28-2018), SuperTom (11-04-2018)
Old 03-28-2018, 01:24 PM   #2317
Leonardo
Country Boy 4 Life
Leonardo's Avatar
'Salad shooters' may not be for everyone, but I think that they look great! I also think it is really cool that they are off of your old car. SOOOO Meaty!
I LIKE TIRES!
slacker221 (03-29-2018)
Old 03-29-2018, 10:58 AM   #2318
slacker221
Leonardo - Yeah I have heard them called "Salad Shooters", "Sawblades", and a couple other things lol. I had them laying around and needed wheels when I went to the wide body kit so I figured I would just use them till I get a new set that fit correctly. But after putting them on, I am really starting to dig the way it looks. It is definitely a unique look on this car, not everyone likes it, but I dig it.
They are pretty meaty because I went with the OEM tire spec of 255/50 R16, mainly because there are only 4 tires that are made in a size that will fit these rims. And only BFGoodrich and toyo makes tires in that size. Basically the only things using that tire size now is the old C4 vettes, and older porches.
Old 03-29-2018, 11:21 AM   #2319
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
salad shooters are LT1 Z/28 wheels. Those are sawblades and why... they were terrible on c4's... they are still terrible today.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following 2 Users Say Thank You to Roadcone For This Useful Post:
batlwagn (03-29-2018), G-Man (03-29-2018)
Old 03-30-2018, 09:59 PM   #2320
Jay Grey
Jay Grey's Avatar
Drives: 2013 BRZ Limited DGM MT
Anyone running 18x9.5 +35 with 245 or 255’s. Flush fit or a little poke? Going to be running coilovers. I would like a nice clean look, no fender roll or crazy camber.
My Car Journal Thread: The GreyRZ Build
Jay Grey is offline   Reply With Quote
Old 03-30-2018, 10:42 PM   #2321
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
You'll be good on a 255/35
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-30-2018, 10:44 PM   #2322
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
My wheel and tire setup changed quite a bit... lol
Omar GC
Instagram: 2jzus
The Following 6 Users Say Thank You to OmarGC For This Useful Post:
batlwagn (03-31-2018), DuMa (05-11-2018), DustinS (04-04-2018), Jive Turkey (04-30-2018), Lust (04-01-2018), NAEightySix (04-02-2018)
Old 04-02-2018, 07:05 PM   #2323
nocoolname
Put some Avid.1 18x9.5 +38 with 255/35R18 Continental extreme contact sports. I'm running BC coilovers and dropped about 1.5". I need to lower it a little more, and maybe roll the front fenders a bit after I finalize the alignment.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
The Following User Says Thank You to nocoolname For This Useful Post:
Old 04-04-2018, 09:49 AM   #2324
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Got specs for these? Assuming you did a 5x114.3 swap
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
