Drives: 2017 BRZ Premium w/ PP
Shopping list for installing DDX917WS in 2017 BRZ
I'm trying to get a shopping list together for adapters needed for installing this head unit in my BRZ, but cant seems to get a solid answer on exactly what to get anywhere. I know I need a camera adapter, USB adapter, and antenna adapter. I just cant figure out exactly which ones to buy.
Would the parts in this post work with my BRZ or do I need to find Subaru specific parts. P.S. I already have the Canadian face plate to get rid of the trapezoidal shape of the opening. |
#2 |
Drives: 2015 BRZ Series Blue (White)
I didn't have an OEM backup camera to deal with for my BRZ but these were a couple things I got off Amazon for when I installed this head unit:
USB Retention: AX-TOYUSB Antenna: Metra 40-LX11 Out of the box the head unit has most of the wiring harness handled (10, 6 and 28 pin plugs) for what you need. Park Brake: You will have to find a 16 pin plug or splice for the factory parking brake if you care to have it work as intended. I just put my park brake wire from the head unit to ground and didn't worry about the 16 pin plug at all. |
#3 |
Backup camera is what is the most confusing to me. I cant tell whether I need anything other than the AX-CAM6V for the backup camera.
Also I think I need an AX-SUBUSB2 for the USB instead of the AX-TOYUSB for my 2017. |
#4 |
Drives: 1949 UFO
On the BRZ the backup cam, AUX, Reverse signal and speed are on the 28-pin connector. So you gonna need AXSUB28SWC6V It comes with the 12V-6V converter.
#6 | |
#7 | |
Drives: 1949 UFO
#8 |
That sounds like what I'll do. Does the BRZ doing send the steering info to the backup camera? One the the biggest annoyances I have with the stock HU is that there are no steering lines when backing up. Just the distance indicators.
#9 |
Drives: 1949 UFO
Unfortunately, no. Both the 917WS/918WS have backup grid lines that can be turned on/off. I have then off since the backup cam has then already. However, there are no steering/turning indicator lines.
#10 |
Ok so I just got my radio in and am trying to plan for the harness coming in tomorrow. All I need to do with the antenna adapter is out the blue wire into the 8 pin on the ddx917’s 10 pin connector right?
Then for the axsub28 I need to transfer all the wires to the ddx917’s 28 pin harness and then connect them to where they belong on the ddx917s main harness? Any chance you have a picture of your completed harness? Last edited by Unholypanda; 03-30-2018 at 08:00 PM. |
#11 | |
Drives: GR86 Trueno Edition
I am sure you are aware of the ready to use harness they provide. Just wanted to mention. Thanks |
#12 | |
Drives: 1949 UFO
#13 |
Drives: 1949 UFO
This is good option. It will $218 AUD(177 USD) shipped. I had originally purchased this from them but after reading others post on how to wire it I cancel the order and ordered the parts needed from Amazon. Ended up paying $60 instead. The Post listed earlier should be dead on for those with a BRZ. I had to deviate from it because I Have an 86
#14 | |
I will get the 2018 86 gt and did my search for ddx917. since we have the ddx918 now, I will have to wait for Carbon systems to release a plug and play harness. It will be though for me to wire the HU with all features working properly on my own
| some FYI for 2017 Owners installing an FT86 Catted Header | Last Lemming Alive | Engine, Exhaust, Transmission | 9 | 06-19-2019 01:16 AM |
| Installing 2017 BeSpoke into a 2013 FRS? | batnick | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-07-2018 12:39 AM |
| 2017 WRX/STI Order List | HeubergerMotors | Dealer Cars | 2 | 06-18-2016 01:59 PM |
| Forged internals - shopping list help | ChrisD | Engine, Exhaust, Transmission | 22 | 07-19-2015 11:12 PM |
| Shopping List : building a faster car! | Philly | CANADA | 8 | 06-28-2012 08:58 PM |
