Old 03-22-2018, 08:16 PM   #15
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I've got the non push button FR-S. The key I use all the time is still working fine for all the buttons and stuff.
The key that has been sitting on the key rack since I got it with the car doesn't work the buttons at all.
Turning the actual key starts it up every time though.
Old 03-22-2018, 09:19 PM   #16
Brink
Drives: 2017 BRZ
Haven't had this issue at all in one year of ownership.
I've even started the car, grabbed something to throw away, opened the door, walked 15 ft over to the trash bin, and walked back. All the while the car continued running without messages.
The car doesn't beep at you once you get out? Mine beeps constantly if I take the key outside of the car with me while it's running. I don't recall the exact message, it's something about key not present or turn off engine or something. I could be standing right next to the car and it will still go do this.
Brink is offline   Reply With Quote
Old 03-23-2018, 02:47 PM   #17
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I've had the "key not detected" issue when my keys are in my pocket with my phone. If my key is under the phone, it's a problem.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
tfp (04-01-2018)
Old 03-23-2018, 04:31 PM   #18
extrashaky
Drives: 2014 BRZ Limited
Mine doesn't beep like that until I close the door with the keys outside. As long as the door is open, it doesn't mind that the keys have walked away.
Old 03-23-2018, 04:52 PM   #19
Brink
Drives: 2017 BRZ
That might be it, I don't do it often enough to remember the details.
Old 03-24-2018, 11:01 AM   #20
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
Originally Posted by Benji View Post
Are you wearing anything particularly metallic?
No sir.
Sent from my SAMSUNG-SM-N910A using Tapatalk
tfp is offline   Reply With Quote
Old 03-24-2018, 11:03 AM   #21
tfp
tfp's Avatar
Never had an issue with this. I've started my car with my key in my shorts pocket, jacket pocket, or in a gym bag on the passenger seat and it always works. Often start with the driver's door open too. When it's in my shorts pocket it's always on my left side and there are about a half dozen keys with it but still no issue being detected.
Have you tried with your spare key, to see if the issue is with the key (battery maybe?) or something in the car itself?
Yep, tried with the spare key too and it still happens. But... Since you mentioned it... I'll try with the fib in my left pocket today!
Old 03-24-2018, 11:06 AM   #22
tfp
tfp's Avatar
My phone is 99% of the time on the passenger seat.
Old 03-24-2018, 11:09 AM   #23
tfp
tfp's Avatar
I bought the car brand new in March 17 so I wouldn't expect it to be the fob battery. If the left pocket trick doesn't work, anyone happen to know what batteries it takes?
Old 03-24-2018, 12:38 PM   #24
extrashaky
My first batteries barely lasted two years. Two years after that, I'm starting to get signs they may be failing again. Failure after one year is a bit shorter than expected, but it wouldn't surprise me.
Check your owner's manual, because they changed at some point and what people tell you here may be wrong for your year. Or just open the thing up and look. When I buy key fob batteries, I usually pop the fob open right there in the store to look at the number to make sure I'm getting a match.
The Following User Says Thank You to extrashaky For This Useful Post:
Summerwolf (03-24-2018)
Old 03-24-2018, 12:59 PM   #25
Brink
Drives: 2017 BRZ
Won't the batteries run down faster if you're actually clicking the buttons on the fob a lot, rather than just keeping it in your pocket and using the proximity/touch sensors on the car?
Old 03-24-2018, 04:30 PM   #26
spike021
spike021's Avatar
Just confirmed earlier that if I start the car and get out it does beep but once I’m about ten feet away the beeping stops, the car remains running, and when I get back in it’s like nothing happened. No message on my screen about it.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
tfp (04-01-2018)
Old 03-25-2018, 11:57 AM   #27
Willie Swoopes
Junior Pizza Joe
Willie Swoopes's Avatar
Drives: 2017 BRZ Limited Manual WRB
Both FOBs are supposed to last the same time even if you aren't using them because they are constantly putting off a signal, or so I've been told. Even if one stays in the drawer and the other is used daily.
According to the manual, the car should know when the FOB is inside the car, or outside the door or trunk. If it is in the car and you are getting the message then something is wrong.
That said, if it's a 17 then the dealer should know why you are getting the no key present message and fix the issue.
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too.
Willie Swoopes is offline   Reply With Quote
Old 03-25-2018, 12:00 PM   #28
Willie Swoopes
Junior Pizza Joe
When I wash the car, I can't keep the FOB in my pocket, because the doors keep locking and unlocking.
Keyless entry and start - Pros and Cons.
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help Johnders2586 Issues | Warranty | Recalls / TSB 9 04-04-2023 03:32 PM
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? darkbluemn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-05-2018 08:49 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
I just bought a 2017 86 and am having a slight issue with it. HachiRokuX Scion FR-S / Toyota 86 GT86 General Forum 34 03-31-2017 09:10 PM
2017 owners: does the front bumper still have the fitment issue after taking it off? HeadBanger BRZ First-Gen (2012+) — General Topics 13 03-05-2017 05:32 AM
