Old 03-22-2018, 07:42 PM   #141
timmydatooth
Drives: Scion Frs
Originally Posted by BFIFE22 View Post
The V4's are compatible with the 2017's, but also the 2012-2016's
Not questioning your knowledge but where did you get this info from? I do not see it mentioned at all on the v4.0 release notes or on the open flash website...
timmydatooth is offline   Reply With Quote
Old 03-22-2018, 08:15 PM   #142
Decep
Drives: 2013 FR-S Series 10
Originally Posted by Teseo View Post
Tried to download latest open flash manager but doesnt download
mine was really wonky until i disabled my anti virus (stock windows defender in win10)
Old 03-22-2018, 08:20 PM   #143
timmydatooth
Drives: Scion Frs
Originally Posted by guybo View Post
Unless it's E85 which SHOULD be labeled Stage 1 but are misnamed as Stage 2+
So the stage 2+ tunes are not for the cars with catless headers?
Old 03-22-2018, 08:56 PM   #144
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
just flashed to v4 and damn feels good. off a dead start it feels a lot more healthy, at low rpms in traffic it feels better, the cold start remove is a great QoL enhancement too. Also tried out launch control, ive never had a car with it and holy shit it was fun. 2 questions tho, 1) how does flat foot shifting work? it seems like it just stays at the rev limiter and never drops. 2) is it me or is the pedal deader than the v3 and you have to press it down a lot more to blip and match a downshift?
The Following 2 Users Say Thank You to Breadman For This Useful Post:
smg1138 (03-22-2018), SuperTom (03-22-2018)
Old 03-22-2018, 08:57 PM   #145
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
No worries, I know you're just trying to be sure
When you download the V4 files there are ROMS for each CalID including the 2012-2016 ones. I have flashed the correct one (A01C) for my car and have been running it for 2 days with zero issues.
Also, from Steves first post: "New v4.01 Beta tunes now available for all USDM GT86s (including 2017+ which now have Launch Control/Flat-Foot-Shift)"
Just be sure if you are going to be modifying the ROM you need to use the updated definitions, if you are just flashing then just make sure you use the one for your CalID
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
The Following User Says Thank You to BFIFE22 For This Useful Post:
Teseo (03-22-2018)
Old 03-22-2018, 09:00 PM   #146
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I've had the same experience with the deader pedal feel. It doesn't seem to be getting any better which is a bummer. I prefer a very sensitive throttle.
smg1138 is offline   Reply With Quote
Old 03-22-2018, 09:02 PM   #147
BFIFE22
BFIFE22's Avatar
Mine seemed to get better at least to the point where I don't notice it anymore. The car seems smoother when I'm on partial throttle in low gears now so maybe it is just a tad less sensitive
Teseo (03-22-2018)
Old 03-22-2018, 09:13 PM   #148
Breadman
Breadman's Avatar
i kind of like it off a stop but shifting 2->1 on a steep hill or going like 4-3-2 on an off ramp its definitely harder to match. probably because i need to get good but thats a totally separate issue
Old 03-22-2018, 10:20 PM   #149
ricrod
Drives: 17 BRZ MT
What effect would a stage 1 flash have on a stock MT 2017 BRZ?
ricrod is offline   Reply With Quote
Old 03-22-2018, 11:14 PM   #150
stlgrym3
does V4 OFT have flex fuel tune?
stlgrym3 is offline   Reply With Quote
Old 03-22-2018, 11:43 PM   #151
smg1138
smg1138's Avatar
It can only make it better. Stock tunes are pretty garbage. At least on the 2013 - 2016 models.
Old 03-23-2018, 05:16 AM   #152
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just so the info is here as well.
The Stage 1 MT has 10 changed tables:
2x MAF Correction After Start (Cold Start Adjust)
5x Idle Speed Changes (Cold Start Adjust)
Target Throttle Plate Angle (Only changed above 6400)
Ignition Timing Post Start (Cold Start Adjust)
P0420 Code is disabled
The Stage 2 has, in addition:
Open Loop Fueling (Richer at high load low RPM, Leaner at high load high RPM)
LTFT Limits (Reduced to +/-2%)
Base Timing B (Less Timing at high load high RPM)
Knock Correction Advance (More Timing at high load high RPM)
Timing Comps Per Cylinder A & B (Now all 0)
FBKC Range (Enabled now set above 3k RPM)
Intake and Exhaust AVCS Changes
The AT is pretty much the same as the above, just no P420 defined and P0700 code is disabled.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 4 Users Say Thank You to Kodename47 For This Useful Post:
BFIFE22 (03-23-2018), D_Thissen (10-09-2018), nikitopo (03-23-2018), Spuds (03-27-2018)
Old 03-23-2018, 08:24 AM   #153
Submarinesonce
Drives: Frs
You have to set up flatshifting in romraider
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 03-23-2018, 09:36 AM   #154
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
So there is no way to fix P0420 on my AT? I didn't see the option to turn off in romraider I had to flash back to my old V3 this morning because the cel was making downshifting ugly.
Weigaldo is offline   Reply With Quote
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
